#15 | |
Drives: Honda Fit
The Service Department at Santa Monica Subaru told me something similar. |
#16 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Can't be any worse than a 4th Generation Camaro...
And seriously, more effort compared to an I4 for changing the spark plugs would keep someone from owning this car? After a test drive and getting some seat time with one you'll change you mind... "This isn't a normal handling car - it's a sublime and exotic handling sports car that stock feels better than modded "sporty" cars... |
| The Following User Says Thank You to Vracer111 For This Useful Post: | Timmy_Jones (04-10-2013) |
#17 |
Drives: 2013 Scion FR-S Raven
Just need rachet extensions
#18 |
Drives: 2017 Subaru BRZ PP
This car has Iridium spark plugs. They don't need changed until 60-100k miles unless you plan to heavily modify it into a different heat range. And if you plan to modify it, you have bigger things to worry about. If you don't feel like changing them yourself every 5-10 years, then have a mechanic do it for 50 bucks.
It's ridiculous to say you don't want this car anymore based on the spark plug location!
Toyota + Subaru =
#19 |
form follows function
Drives: RIP '13 BRZ
Say what you want about BMWs and maintenance, but at least on the older ones they did a great job of putting every right where you wanted it for maintenance. Even the oil filter was remote mounted right up in front of the engine so you could replace it standing over the car.
#20 |
Drives: Matte Black STI
Ya, I read that you had to jack up the engine too. That is crazy, but we will have to see if there is a way around that.
Also for those looking to change the plugs out to something colder, that may not be something I would do right away. These direct injection engines are super picky with their spark plugs. A shortened electrode can cause misfires, too cold and misfires. It may not be something to mess with for a long time. |
#21 |
Drives: 2006 Subaru Liberty EZ30 S/charged
Probably no more difficult than the rear plugs on a EZ30 Subaru engine, now they are HARD to do.
The EJ20/25 SOHC engines are the easiest thing on the planet to change sparks in, DOHC WRX engines a bit more work |
#22 | |
Drives: 2013 Hot Lava Scion FRS
I am amazed at how much room is in the engine bay of the FRS/BRZ. |
| The Following User Says Thank You to Saab2Frs For This Useful Post: | Marrk (03-25-2013) |
#23 |
Spun
Drives: 23' Supra
| Car won't start, no spark? | #87 | Other Vehicles & General Automotive Discussions | 5 | 12-19-2011 12:29 PM |
| Jowett Jupiter/spark plugs | aspera | Engine, Exhaust, Transmission | 6 | 02-25-2010 05:47 PM |
