Old 11-28-2011, 07:05 PM   #29
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Originally Posted by Aki View Post
Here's smoking only the chrome portion:
I prefer this over the full black, but the thing with stuff like taillights is that you need to really look at it from multiple angles to make sure it doesn't look odd from some sides/lightings.
The 86 for example has a very apparent bulge in the taillight that you can see from the side shot and the front 3/4 shot. If it looks like a random black thing from that angle, then that kind of ruins it.
But nevertheless, this shot looks great! Good Job!
- The Ancient BRZ Sacrament
by Zaku
Old 11-28-2011, 07:06 PM   #30
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
Ever get pulled over in Florida with those tails?
Zgrinch is offline   Reply With Quote
Old 11-28-2011, 07:24 PM   #31
celicajim
celicajim's Avatar
Drives: ZZT231 Celica
If this is the BRZ, the tails look to be the same except smoked or black housings. Simple swap...
celicajim is offline   Reply With Quote
Old 11-28-2011, 07:27 PM   #32
Aki
Drives: '96 beater Corolla
Originally Posted by RRnold View Post
That's what I was planning to do, only paint the chrome trim with either the testors black transparent paint or if VHT has a similar color available.
http://www.testors.com/products/136122
For great tinting, I highly recommend Tamiya's smoke color:
http://www.google.com/products/catal...ed=0CCcQ8wIwAA
Not only does it give great color, but the spray mist is very fine, giving you lots of flexibility with how much you want to tint the housing.
Aki is offline   Reply With Quote
Old 11-28-2011, 07:28 PM   #33
BootpTraphik
loading in progress
BootpTraphik's Avatar
Drives: Genesis Coupe 3.8 M/T
@ celicajim. If that's the case then thats a pretty simple option! You would just have to find someone who wants to trade! Will have to wait until more BRZ info is released.
BootpTraphik
Resident GenCoupe lurker and FT-86 fan
BootpTraphik is offline   Reply With Quote
Old 11-28-2011, 08:19 PM   #34
xantonin
Mr. Detail
xantonin's Avatar
Drives: 2003 Celica GT-S
It doesn't matter how you color them, the design is still ugly as sin. I miss the FT-86 rear.
Everytime I see the GT86 rear I think of the bottom two pictures:
rar
xantonin is offline   Reply With Quote
Old 11-28-2011, 08:25 PM   #35
rideontwo
Drives: Twin Turbo
Ever think the R6 looks like an alien??
rideontwo is offline   Reply With Quote
Old 11-28-2011, 08:45 PM   #36
xantonin
Mr. Detail
xantonin's Avatar
Yeah but what's that have to do with anything?
rar
Old 11-28-2011, 08:52 PM   #37
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
I agree, paint for lexan bodies would be a lot better!
Especially the last one! Then get a custom license plate that says M GUSTA!
I thought it looked like a Praying Mantis!
Old 11-29-2011, 04:48 PM   #38
RRnold
2 wheel member
RRnold's Avatar
Looks like there might be options...
Old 11-29-2011, 05:16 PM   #39
Slide
Drives: Toyota Aristo
They look great noticed that in the other thread too :P
Looks like there will be more options then we can poke two sticks at!
Slide is offline   Reply With Quote
Old 11-29-2011, 06:42 PM   #40
BlueFlag
Drives: Thunderbird Turbo Coupe
Just a bit of a warning before anyone attempts to "open" a set of tail lamps. Many, if not most, modern lamps (excluding headlamps which are always glued) are assembled through the means of plastic welding. Two common methods are vibration welding and hotplate welding.
Regardless of the process used, the tail lamps are designed to never come apart after assembly. Baking in an oven will not weaken the bond, in fact during the hotplate method it is not uncommon to have the contact temperature near 300C. Trying to break apart the weld will result in cracking the lens and destroying the assembly
The company I work for builds the tooling used in welding tail lamps and I am responsible for doing customer runoffs and debugging such equipment. We break hundreds of lamps a year to determine if the part is properly sealed and once it breaks, it will never go back together.
PS, I cannot wait for this car to finally come out!
BlueFlag is offline   Reply With Quote
Old 11-29-2011, 08:21 PM   #41
FT-86Mike
FT-86Mike's Avatar
Drives: S-13
Originally Posted by switchlanez View Post
Wait for the kouki (mid-generation refresh/facelift) version for revised tail lights. Toyota does it on every car they make.
You mean chuki?? I always tought it went like this: First models(zenki) Mid models(Chuki) and late last models (Kouki)???
FT-86Mike is offline   Reply With Quote
Old 11-29-2011, 08:50 PM   #42
xc
xc's Avatar
Drives: Tacoma
i like that! blackout headlights and I'm tinting the tail lights!!!
xc is offline   Reply With Quote
How UGLY will toyota make it ???? dunnojack FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 95 04-09-2013 08:31 AM
dual injection is just a long overdue solution to carbon build up? Hasjwandje Engine, Exhaust, Transmission 19 11-08-2011 05:53 PM
