Old 03-24-2013, 01:08 PM   #183
LPC_FRS
LPC_FRS's Avatar
Drives: Scion FRS
Originally Posted by Pure Automotive View Post
I installed my Jdm fog light bezels and then filled them in with the same mesh that's in the grill
got some airflow on your brakes and rotors?
LPC_FRS is offline   Reply With Quote
Old 03-25-2013, 10:20 AM   #184
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Just picked up a ton of new accounts for parts! Here are just a few!
Pure Automotive is offline   Reply With Quote
The Following User Says Thank You to Pure Automotive For This Useful Post:
VoiD (03-25-2013)
Old 03-25-2013, 10:31 AM   #185
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Very good! The picture is kind of dark on my screen, so it's hard for me to see anything but the vaguest outline of the fog light hole.
Grimlock is offline   Reply With Quote
Old 03-25-2013, 10:35 AM   #186
Pure Automotive
ScionFamily (03-25-2013)
Old 03-25-2013, 10:40 AM   #187
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Ok, that is seriously cool. Great work! Functional, too!
Old 03-25-2013, 10:41 AM   #188
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
The Borla UEL Header would cause a CEL without a tune, correct? It's catless, correct?
Old 03-25-2013, 10:46 AM   #189
Pure Automotive
I haven't installed one without a tune yet. But I have installed it on cars that have a stage 1 tune that is set up for stock header, and they didn't throw a light. So honestly, I don't know yet, I do stock adapters that move the O2 sensors out of the direct stream that usually work on other cars, haven't tried one on a twin yet.
Old 03-25-2013, 08:22 PM   #190
Pure Automotive
Installed my Clutchmasters FX400 Today! Details coming soon!
The Following 2 Users Say Thank You to Pure Automotive For This Useful Post:
RedAlert (03-25-2013), Sargy (03-26-2013)
Old 03-25-2013, 08:25 PM   #191
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Keep us posted
Old 03-25-2013, 08:29 PM   #192
Areddi
Areddi's Avatar
Drives: Firestorm FR-S
I know for me the light is the big caveat. I'm interested to see how this shakes down.
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
Areddi is offline   Reply With Quote
Old 03-25-2013, 10:22 PM   #193
Pure Automotive
Originally Posted by RedAlert View Post
Let us know how it feels/acts. And how does it compare to the six puck clutch? Do you think the new Vortech running 9 pounds of boost will need a clutch?
As most of you know, the weather today is garbage, so after install all I have done so far is run it through the gears around the parking lot. My first impression is that it's very manageable! I didn't stall or really even come close to stalling. It was quite surprising. A couple of notes: I did not have to adjust the clutch pedal at all, however, I never did the easy clutch grab adjustment, so that probably explains that. I have whiteline trans bushing and Perrin engine mounts, so the normal negative effects such as shuddering and chattering, are not noticeable as much as they would be in stock car. Overall, so far I'm excited to put some real miles on it and see how it goes. I want to get my clutch fully broken in and get a good feel for how it acts and sounds etc before I get my turbo kit on.
I'm pretty much all ready for the turbo kit now. Perrin Mounts, Whiteline Trans Bushing, Whiteline Rear Subframe Bushings, Vibrant Vacuum Manifold, Push Lock Fitting Setup for Wastegate and Blow Off Valve, Cusco Catch Can, 275 Rear Tires, Coilovers are on the way. I'm going to be ready to rock when the kit goes on, which was my goal.
@RedAlert, At the 280 range the stock clutch is going to be in question, you can go 1 of 2 ways, 1) Replace the Clutch Ahead of Time to Prevent Slipping or 2) See how far stock gets you and then replace later, it will eventually need it, I'm sure.
RedAlert (03-26-2013)
Old 03-26-2013, 02:25 PM   #194
Biggins
Drives: Yes
I know it's been said a few times already, but I also have to thank @Pure Automotive for helping get my FR-S set up for the autocross season and also doing some routine maintenance on my old beater BMW. Now to decide which mods come next...
Biggins is offline   Reply With Quote
The Following User Says Thank You to Biggins For This Useful Post:
Pure Automotive (03-26-2013)
Old 03-26-2013, 03:13 PM   #195
Pure Automotive
Just placed a stock order, here's what's coming!
Perrin Over Pipes
Perrin Trans Support Bushings
Perrin Master Cylinder Braces
Perrin Shifter Bushings
More Borla UEL Headers!
In Stock Now:
Perrin Catted Front Pipe
ACT 6 Puck With Prolite Flywheel
Hyper Rev 300+ Page Special Edition Magazines Devoted to the Twins
Five Axis Spoilers
Boost Gauges, Boost Controllers, Vacuum Manifolds
Mocal Oil Sandwich Adapter Plates
Coming Very Soon:
Pure Oil Cooler Setup!
Old 03-27-2013, 02:28 PM   #196
Pure Automotive
Come and get em!
IloveBaldEagles (03-27-2013), thejevans (03-27-2013)
Pure Automotive Performance's Full Blown Stage 1+ Install Is In Progress! Pure Automotive Forced Induction 37 07-25-2013 12:09 PM
Gauging Interest for a Tint Install Day @ Pure Automotive Performance Pure Automotive Mid-Atlantic 71 03-03-2013 11:22 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Forced Induction 68 02-25-2013 01:06 PM
Review of ACT 6 Puck @ Pure Automotive Performance Pure Automotive Mid-Atlantic 3 01-10-2013 03:06 PM
