Old 03-13-2013, 08:16 AM   #43
merlin2111
merlin2111's Avatar
Drives: Widebody '94 Miata R-Package
Could these be the guidelines for creating a spec 86 series? Sounds like it is a very well put together vehicle.
I <3 my Miata.
But I <3 my new BRZ even more!
merlin2111 is offline   Reply With Quote
Old 03-13-2013, 09:58 AM   #44
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Originally Posted by Darryljr11 View Post
If those wheels are less than 20lbs each i'm definitely buying them. I hope that TRD intake goes on sale here soon for under $300.
Not likely...
The TRD badge alone costs $200!
Seriously though, I would guess-timate this intake will cost more in the area of $500. Fact of life, if you want TRD goodies for your car, be prepared to pay a premium for it.
Scott
naikaidriver is offline   Reply With Quote
Old 03-16-2013, 02:22 AM   #45
kyolml
Drives: STI 2008, M3
looking at the coilovers, it seems has decent travel with no helper springs, which is likely the spring rate is not too high. I wonder how much they are shorter than stock in travel, doesn't look as long as the KW (RCE) ones.
kyolml is offline   Reply With Quote
Old 03-25-2013, 12:01 AM   #46
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
Originally Posted by brianlo622 View Post
Does anyone know what this is?
That is a master kill switch that disconnects the battery from the car. It is mounted next to the passenger side window, so that safety workers can kill the electricals on the car after any incident to prevent fires, kill the fuel system, and all electrical ignition sources during a race.
Moto Miwa
R&D Driving Engineer, Product Designs
Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance.
Moto-P is offline   Reply With Quote
The Following User Says Thank You to Moto-P For This Useful Post:
brianlo622 (03-26-2013)
Old 03-25-2013, 12:06 AM   #47
Moto-P
Moto-P's Avatar
The purpose of any helper spring on a set of coil-over is to take up the slack of spring perch against the spring travel when the spring does not match the shock stroke range. It does not alter or ease any stiff spring as it stays compressed fully when the car is loaded and on the ground.
These are properly designed from the start to be specific to this car, so there is not a need for a spring helper as stroke range and spring length are perfectly designed against each other as a custom build with Eibach/TRD Celebrity Race units.
Moto Miwa
Old 03-25-2013, 12:12 AM   #48
Moto-P
Moto-P's Avatar
Originally Posted by turbocat View Post
Great read!
Is there info on these celeb racecars using oil coolers. From the pictures of the engine bay it doesn't appear so. I know there is mention of 0w-20 oil. I assume the oil gets changed after every race. That may be the reason they didn't bother with an oil cooler?
Thanks OP for the thread. The cars are very interesting with a nod to a well rounded club sport style setup.
What they told me was that this is only a 10 lap race, and oil cooler was not absolutely necessary for the duration of the race. Another point you might consider for the Celebrity Race is that it is held just 2 hours before a INDYCAR race on the same track, and therefore the less chance of having failed or crashed oil cooler core and lines, and spilling oil on the precious race surface is possibly more critical to the event...
I am sure they would be considering the oil cooler addition if it was more like a 30min+ or endurance race where engine oil can actually start to deteriorate in performance during the race.
Good eye and thinking!
Moto Miwa
turbocat (03-27-2013)
Old 03-25-2013, 12:16 AM   #49
Moto-P
Moto-P's Avatar
Originally Posted by jkonquer View Post
are they using cusco control arm? suprise they didn't make their own
The craftsmen at Toyota Motorsport had been given a very short time-frame to build these cars, and since the parts on this car is not made with full consideration for actually making them for sale, there was a bit more freedom in selecting quality parts from aftermarket companies who already make what the cars needed. Cusco is no foreigner to Toyota or racing, as they have been racing for over 40 years, and have worked with FT86 Project well before launch.
Moto Miwa
Old 03-25-2013, 12:21 AM   #50
Moto-P
Moto-P's Avatar
Originally Posted by naikaidriver View Post
Not likely...
Scott
With Scion Optomize or TRD parts, what you are paying for is the ability to have it not void warranty, the extra testing needed to make it pass all quality and safety/reliability standards needed to qualify as a Toyota product that can be sold through dealers and with full warranty and dealer serviceable item. So if you don't need ANY of such assurance, you can seek similar parts in the aftermarket world... That's the difference in price.
It didn't matter to most of us when we worked on a 20 year old AE86, that's out of warranty... But for some, with FRS/BRZ being very fresh with 40+ payments left, this might be something to consider, I suppose.
Moto Miwa
Old 03-25-2013, 09:30 AM   #51
naikaidriver
Valid point and very true. However, is it not also fair for the consumer to expect comparable performance gains in relation to other aftermarket additions?
Scott
Old 03-26-2013, 02:05 AM   #52
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Tow Strap?
Great write up Moto!
Do you or does anyone here know who makes the orange tow strap shown in the picture below?
stevo_12v is offline   Reply With Quote
Old 03-27-2013, 07:53 PM   #53
toysub
Drives: DGM
Great writeup. Hope to see some of these mods in a release series.
toysub is offline   Reply With Quote
The Following User Says Thank You to toysub For This Useful Post:
Moto-P (04-01-2013)
Old 04-01-2013, 01:44 AM   #54
kyolml
I know that. it's either it's a shorter travel/stiff design or not really stiff with good travel. once it's available for the market we will know what the measurements and spring rates.
The Following User Says Thank You to kyolml For This Useful Post:
Moto-P (04-01-2013)
Old 04-01-2013, 05:25 PM   #55
Moto-P
Moto-P's Avatar
Scott
Exactly, and any product with price structure that is partly compasating things other than the hardware itself, whether marketing, R&D, warranty, extra measure of certifications, etc... It's hard to say one is better than another if consumers only look at Price/Performance.
Let's just say we have it better off than women, who get really bad ratios on cosmetics and fashion. Chanel and MAC lipstick costs $1.67 each to make, and they pay $24.00 because $15 of that goes to the magazine ads and big budget events... LOL!
Moto Miwa
naikaidriver (04-01-2013)
Old 04-01-2013, 05:30 PM   #56
Moto-P
Moto-P's Avatar
Yes, and valve and tube design also alters the requirements for how much of the piston side components can be allowed to travel within a case. So shorter piston/short case can sometimes have longer travel than another makers setup that's actually longer in external dimensions.
So yeah, it's all ultimately in the overall design, and costs of components being used. Often that balance is difficult in consumer products as cost is a huge barrier. While for something like this where there is reasonable healthy budget that's well beyond the reach of most consumers to make something very specific to the car.
Moto Miwa
Tuned Scion FR-S Chosen as Next Toyota Pro/Celebrity Race Car for Long Beach GP Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 62 03-07-2013 04:25 PM
Cerritos/Long Beach ggpaul Southern California 12 11-12-2012 07:53 AM
Toyota's Next Celebrity Race Car groupb Scion FR-S / Toyota 86 GT86 General Forum 5 10-23-2012 06:41 PM
First 86 Long Beach Last Supper fieryhooligan Scion FR-S / Toyota 86 GT86 General Forum 1 04-09-2012 05:47 PM
Non First 86 Streets of Long Beach FT86Club.com get together poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 1 03-13-2012 01:56 PM
