Old 03-24-2013, 04:27 PM   #659
UncleFester
Yep I managed it first for these cars with the sprint kit I believe sorry for the large pic.
I spy a cracked disc
UncleFester is offline   Reply With Quote
Old 03-24-2013, 05:37 PM   #660
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yep. Time to order up some spares
Maybe I should rethink my late braking antics.... Or add brake ducts.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-24-2013, 08:46 PM   #661
UncleFester
Made me go check mine. No cracks. I wouldn't say I brake too late or hard. Fascinating.
What pads have you been running?
Old 03-24-2013, 09:06 PM   #662
D1cker
Drives: B9 S4/ND2
how many days and which pads are you using?
D1cker is offline   Reply With Quote
Old 03-25-2013, 12:20 AM   #663
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Ummmm... Could you please elaborate on that?
I thought these brakes were supposed to be able to handle much faster/heavier cars with out a problem. I appreciate there are many variables involved.
Old 03-25-2013, 12:21 AM   #664
D1cker
Drives: B9 S4/ND2
Brake rotors are a wear item, the harder you are on them, the faster they wear.
Old 03-25-2013, 12:24 AM   #665
Captain Snooze
Drives: Red Herring
Sure sure sure ,understood, but is cracking considered "wear"? Is cracking a disc an acceptable event when given a hard time?
Old 03-25-2013, 12:28 AM   #666
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
CL RC6E. I have confidence in the brakes to the point that I brake pretty late, and very hard. Not the best technique probably to save parts but I've also been trying to push it further and further to see just how late I could go. The RC6E's are sintered fully metallic pads and generate quite a bit of heat, more than semi-metallics from the temp data I gathered. These rotors saw north of 1,200 degrees in less than 20 minutes.
Also, I was driving three cars this weekend, there were a few times when I came off the track and switched cars, which is, IMO what caused the crack in the first place. Normally I give the brakes more cool down and roll the car a bit to reduce hot spots, I didn't do that every time this weekend.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
Captain Snooze (03-25-2013), D1cker (03-25-2013)
Old 03-25-2013, 12:28 AM   #667
D1cker
Drives: B9 S4/ND2
On track cars, the wear is from the stress applied to the rotors, and they tend to crack far before they become thin like you would see on a street car. Once they crack like this you replace them. I'm curious to see what kind of life he is seeing out of these though (number of track days and which pad was being used)
The Following User Says Thank You to D1cker For This Useful Post:
Old 03-25-2013, 12:30 AM   #668
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
C300 and CL RC6E. The CL's are much better at high temps, and they stay consistent.
With the brakes, probably 8 days or so. I got 2 days out of the OEM rotors.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
D1cker (03-25-2013)
Old 03-25-2013, 12:33 AM   #669
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
They can. Rotors are going to go and I have been pushing my braking points further and further to see just how much I could do before I missed the turn in point. I found that on a few turns, but not others.
Sebring isn't the easiest on brakes either, and most of my track time is there, including this weekend.
I've been staying HARD on the brakes until the end of braking, instead of letting up over time. In other words, my technique is generating higher temps.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-25-2013, 12:34 AM   #670
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yes, very acceptable. We've cracked rotors worse than this on the race car in 5-6 hours...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-25-2013, 12:38 AM   #671
D1cker
Drives: B9 S4/ND2
8 days at sebring is like 20 days out west, glad to see they're holding up to so much abuse.
Old 03-25-2013, 01:19 AM   #672
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
do you think greater heat capacity may have prevented this? or does this make you rethink your choice of pad? I tend to brake late myself. Or is ducting the answer?
Huehuecoyotl is offline   Reply With Quote
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 11:34 AM
SS Racing Brake Line K1 Motor Works Brakes, Suspension, Chassis 5 06-29-2012 03:36 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 02:32 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
