#15 |
Drives: GT86
Skippman- My design, someone else fab (team principal). Fibreglass ain't my bag!
#16 | |
Drives: Whiteout FR-S
#17 | |
Drives: Argento 6spd FR-S
#18 |
Drives: GBS BRZ Limited
I'm planning on having my tuning done by Josh at JML Audio here in St. Louis. He has an EXCELLENT reputation and hearing some of his projects makes me trust him even more. Of course, tuning like that doesn't come cheap.
Is it bad that I have about $6,000 planned for a car I don't even have yet? |
#19 |
Drives: GT86
No, of course not, not when it comes to audio
#20 | |
Not if you are getting your monies worth, but that seems steep for what you listed you are gonna do. |
#21 |
#22 | |
Audio & Bacon Junkie
Drives: 2013 WRB BRZ Ltd
Currently, I was thinking of doing the following: Wide: Seas Prestige FU10RB Midbass: Peerless 830946 SLS Bass: Seas L26RO4Y DSP: RF 360.3 The only thing I'm really worried about is depth for the Peerless drivers. Even with the spacers, I'll cut it really close. http://www.subaruaudio.net/subaru-sp...nd-scion-fr-s/ Do you think I will have an issue? I'd like to open the door, seal it, install the driver, close it. The less panel modifying, the better
#23 |
Ok, after careful research I think I've finally decided what I'm going to use for my build.
Source: Fujitsu Ten Stock, eventually replace with Ca-Fi Knock-Off DSP: Audison BitTenD Amp: Audison Voce AV 5.1k Interconnect: Audison AV bit IN Drivers: Audible Physics NzA Duo's Other than a sub I think that will do it. I plan to utilize the factory mounting locations with adapters. As for the transducers I may A pillar mount those, or attempt to fab a bracket to use the factory tweeter location. Using the BitTen gives me quite a lot of options for tweeking. This will hopefully give me excellent staging. |
#25 |
Drives: Galaxy Blue BRZ
I'm considering the Audible Physics NzA Duo too. Pretty good value for high-end gear according to people that I've spoken to.
The hardest part is knowing what amps/processors and where to put them without losing most of the trunk space. My last build was in a big sedan back in the day when almost nobody had processors and you could just hide some big-ass amps under the seats.
#26 |
@Redmist there's plenty of threads on great installs here on the forum. Not all of them are MECA grade mind you but they're very good starting points and I'm certain sound excellent. A couple I'd recommend you review are:
2forme's build curzinbill's build GaN-MaN's build Sorkov's build Wheelhaus's build That should give you some excellent starting points for how to build your system. Be sure to check out the audio directory sticky threat as Rupert does an excellent job of linking to new threads as they become available. Also consider checking out DIYMA's forums and search for "Bing Install." Bing's become something of a minor celebrity for his BRZ/FRS installs and has a wealth of knowledge. |
| The Following User Says Thank You to Skippman For This Useful Post: | Redmist (04-20-2013) |
#27 |
Drives: Firestorm FRS
I have run the Founteks and currently have the Audible physics NZ3A-at paired with AP Arians and waiting on the new 8" drivers to arrive.
For the money the Founteks are very good, loved them. The APs are better of course, but way more expensive. I think you will have to do a bit of custom work to fit a 4" in there, but its probably doable. I might try to squish a L4SE in dash at some point. Getting down to 150hz in the dash would be excellent. One thing with this car I notice with having the highs in the dash, both with tweets and widebands, is bad reflections. This makes it fatiguing fairly quickly. I will be wrapping my pillars and attempting to make a suede dash mat this week and see if that will help |
#28 |
Skippman, I will be looking to sell my Arians this week, used about 2 months, and possibly the whole NZA Duo set for a good price. PM me if interested.
| Tein Active EDFC?? Yes please :) | RallySport Direct | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 91 | 04-14-2014 09:44 AM |
| 3 Way Active without a Subwoofer | stea1thbear | Electronics | Audio | NAV | Infotainment | 42 | 10-14-2013 02:03 AM |
| Active ft86 car club in socal | aced86 | Southern California | 170 | 02-28-2013 01:42 AM |
| A more active mid alantic | _F-R-S_ | Mid-Atlantic | 37 | 11-12-2012 07:19 AM |
