Old 03-23-2013, 05:27 PM   #169
2forme
Originally Posted by ph0en1xtk View Post
Does anyone have any idea what to do if your unit just shows a white screen all of the sudden? I took mine out to make a modification to the dash kit and when I plugged the harness back in, its unresponsive and just has a white screen. I can turn it on and off with the volume knob, but nothing else works
Any help would be great!
I've ripped mine out a dozen times, never had this issue. Did you accidentally short something???
Old 03-23-2013, 06:10 PM   #170
ph0en1xtk
ph0en1xtk's Avatar
Drives: Raven MT Scion FR-S
Im not sure how to tell if I did or not. I may have when hooking up the rear view camera. If I did, how can I tell, and how can I fix it? I'm not quite experienced enough with wiring to know
ph0en1xtk is offline   Reply With Quote
Old 03-24-2013, 11:20 AM   #171
ph0en1xtk
ph0en1xtk's Avatar
well im guessing that i did short something in the harness. i hooked the HU up to the battery directly and it worked just fine. Guess ill have to order another harness?
Also, i guess now that the scare is out of the way, i cannot find any possible way to fit the dash panel over the HU with the metra dash kit installed. I sanded down the small lip on the top and bottom of the HU and am able to get the dash panel over the HU by itself, but once i put the dash kit on, i cant seem to figure it out anymore.
@2forme, any ideas how to make this fit? If im ordering another harness, im gonna go ahead and grab the beatsonic kit to test out fitment there.
Old 03-24-2013, 11:44 AM   #172
privfaith
Drives: RX8 -> 2013 FRS
I've accepted that the metra kit will require a lot of dremmeling to make work. Presently the deck is in the car with these nice gaps on either side
Sent from my SGH-T999 using Tapatalk 2
privfaith is offline   Reply With Quote
Old 03-24-2013, 12:10 PM   #173
Yruyur
Yruyur's Avatar
I have access to a water jet and can probably make plates to take up the space if someone wants to send me a template.
Old 03-24-2013, 12:23 PM   #174
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Is the radio catching on the top or bottom of the panel? I've found that you need to get the angle of the radio just right else it won't fit. No dremmeling required.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 03-24-2013, 12:29 PM   #175
sav
sav's Avatar
Not the best pic but this is without modifying any of the edges:
95RON SAV Tuned
Old 03-24-2013, 01:02 PM   #176
briang0901
briang0901's Avatar
Drives: 2024 MT Toyota GR86
For mine bro, i dremmeled off the top and bottom lip of the head unit and used the beat sonic bracket, i had to wiggle the bezel for it to fit flush but it works
2024 Toyota GR86
2013 Scion FR-S
briang0901 is offline   Reply With Quote
Old 03-24-2013, 01:35 PM   #177
privfaith
Oh thats interesting how you put the dash panel behind the bevel on the headunit. Hmm.
On a sidenote, does anyone have shitty quality sound when they connect their phone to the HU and play music through it? Is that a result of the garbage internal amp?
Old 03-24-2013, 01:57 PM   #178
2forme
I dremeled the sides and trimmed the front of the Metra kit. They sit in frontt of the side tabs on the head unit. Trim off the the little lip on the front of the Metra pieces to make them "skinnier" (when looking at them installed). Does that make sense.
Old 03-24-2013, 02:06 PM   #179
briang0901
briang0901's Avatar
@privfaith I was getting frustrated at that point and decided that I am satisfied with the look. I thought about dremmeling the bracket but didnt want to go to far on it and not have it look flush.
2024 Toyota GR86
2013 Scion FR-S
Old 03-24-2013, 04:04 PM   #180
ph0en1xtk
ph0en1xtk's Avatar
i had mine sitting in front of the side bevel of the headunit (not behind, like the picture posted a few posts above) and the dash panel was hitting the left and right sides of the metra kit. It was as if the HU with the metra kit was way too wide to fit in the space that the dash panel allows. Nearly a quarter inch it seems from looking at it.
Also as for the sound quality through bluetooth, it really isnt very good, but i found that lowering the volume on your phone has a major effect on the quality.
Old 03-24-2013, 06:37 PM   #181
2forme
Yup, it's too wide, the metra kit has a small protrusion on the front inner faces. I dremeled them down to flush with the rest of the piece and it fits perfectly.
I've noticed BT quality vary from phone to phone.
Old 03-24-2013, 09:24 PM   #182
ph0en1xtk
ph0en1xtk's Avatar
I just purchased the beatsonic kit with harness and dash kit, is there anyone that can speak of their kits fitment, compared to the metra?
Also, @2forme, given your experience with this unit, do you know if there's a way to get it to resume an app such as mx player or winamp instead of the built in music player? Kinda a pain to have to shut one off and open the other every time, then select the music
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-19-2013 11:51 PM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 10:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 03:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 05:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 10:47 PM
