Old 03-23-2013, 10:28 AM   #617
ph0en1xtk
ph0en1xtk's Avatar
Drives: Raven MT Scion FR-S
are the lights listed here for the outback black housing or is it just the forester thats black?
http://www.subarupartsforyou.com/cp_...p?partid=19073
ph0en1xtk is offline   Reply With Quote
Old 03-23-2013, 10:48 AM   #618
terrypm
First86 & burning gas!!
terrypm's Avatar
Drives: Asphalt 2013 Scion FR-S
Here is a discount code for Subaru parts good until March 28. The email I received from them states it is good for up to a 35% discount off msrp. Maybe it can help someone.
http://estore.subarupartswarehouse.c...&siteid=217823
terrypm is offline   Reply With Quote
Old 03-23-2013, 11:22 AM   #619
terrypm
terrypm's Avatar
Those are the fog lights I ordered and they are black.
I believe someone else ordered the JDM Toyota 86 fog lights and they had chrome surroundings.
Old 03-23-2013, 11:24 AM   #620
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
correct, but be prpared to pay 3x per fog. i found em from 140-150, so unless your a baller i'd b happy with black realistically because that is absurd
lbroskee is offline   Reply With Quote
Old 03-24-2013, 04:18 AM   #621
mr. slim
SoCal86
mr. slim's Avatar
Drives: '13 Whiteout FR-S
So nice!
Thanks! Just did this DIY it so helpful!
I used the Nigel harness and tapped into the side marker leaving the button and other wires on the passenger side of the inside bumper. I covered it up with eclectrical tape so no issues during the rain.
Thanks again and good luck!
.: SUPER KAWAII :.
.: BUBSQUAD :.
.: LivinLow :.
.: FRS86 :.
mr. slim is offline   Reply With Quote
Old 03-24-2013, 01:39 PM   #622
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Installed:
No knock on Nigel, in fact I considered his harness, but I didn't like the construction or the cheesy fog light switch that's larger than the other switches. I suppose you can call me a perfectionist.
So I opted to go with TRS relay harness. It's plug and play for ballasts but not halogen. I cut off the ballast ends and soldered on H11 pig tails. It uses a 2 relay design such that each lamp is powered from it's own relay.
It also incorporates a light on each relay so if one were to fail, you only need look at the relay and replace it.
As for a signal, I tapped into the passenger side marker so the lights only come on with light switch in the parking light position and headlight position.
While I was at it, I removed the DRL junction box.
There is no designated top or bottom to the fog lamps. So I designated the lamp such that the writing on the lamp was right-side-up. I modified the fog lamp housing fit flush and remove all gaps. Maybe someone has the gypsie magic to fitting flush without modification but I couldn't. I know some wouldn't feel comfortable modifying brand new lamps they paid $100 for but oh well, it worked.
Onto the pics...
Passenger side
Drivers side
Fogs off
Fogs on
Double relays
(right headlights)
(left fogs)
Relay with fogs on
Headlights & Fogs on
Relay with fogs & headlights on
ecko04 is offline   Reply With Quote
Old 03-24-2013, 03:41 PM   #623
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Ecko assuming you dremeled down the diameter of the house? Or the inner portion of the lamp? More details please... I have no problem modifying brand new parts lol
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 03-25-2013, 03:34 PM   #624
calis5nest
calis5nest's Avatar
Drives: scion frs firestorm
Dont want to go with HID's for the fogs. Looking for some white LED's. Would this fit the Outback fogs?[ame="http://www.amazon.com/AnzoUSA-809008-Super-White-Bulb/dp/B004037IL2/ref=sr_1_28?s=automotive&ie=UTF8&qid=1364239462&sr =1-28&keywords=h11+bulb+white+55w"]http://www.amazon.com/AnzoUSA-809008-Super-White-Bulb/dp/B004037IL2/ref=sr_1_28?s=automotive&ie=UTF8&qid=1364239462&sr =1-28&keywords=h11+bulb+white+55w[/ame]
-Alan
calis5nest is offline   Reply With Quote
Old 03-25-2013, 03:41 PM   #625
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Get Nokya bulbs
Old 03-25-2013, 03:54 PM   #626
calis5nest
calis5nest's Avatar
Originally Posted by whitefrs View Post
Get Nokya bulbs
I wanted those but the white Nokya's have a blue housing. I dont think blue will look right on the fog light when off
-Alan
Old 03-25-2013, 04:04 PM   #627
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Why don't you guys just buy H9 bulbs and harnesses? I'm growing more impatient with my order as the weeks add up.
post_break is offline   Reply With Quote
Old 03-25-2013, 04:08 PM   #628
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Something about white or blue fogs just seems so wrong.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
Old 03-25-2013, 08:08 PM   #629
YDNA
YDNA's Avatar
Drives: Raven FR-S
my switch broke easily... probably just gonna find a different one. once you push it to turn on, it wont push again to turn off. you have to pull it. and the harness also isnt long enough either, im doing my best to stretch the wire and it might barely fit
YDNA is offline   Reply With Quote
Old 03-26-2013, 09:43 PM   #630
ph0en1xtk
ph0en1xtk's Avatar
I am too, my order was placed on february 18th, and its still not shipped =\
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
FINALLY - Got my FR-S SkitterSkotter Scion FR-S / Toyota 86 GT86 General Forum 28 08-03-2012 05:16 PM
FINALLY GOT IT! Ayaz2589 NY / NJ / CT / PA 8 07-28-2012 02:52 AM
Finally got it!! percyng CANADA 21 06-17-2012 01:50 AM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 07:29 PM
