Old 03-23-2013, 09:03 AM   #29
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by BRZranger View Post
Right on, glad to see you got your kit! I'm interested in seeing the final product on your end.
You might as well move up to WA since your favorite vendors are all up here!
Subd!
I know right?? It's like WTF?? Why do I need to choose to like all vendors from the farthest possible location?? And believe me, there are some shitty shops down here...
Shitty like:
Me: "Hi, I hear you guys have a Mustang Dyno and I want to use it. I will bring my tuner down to tune it. How much do you charge to use it and when is it available?"
A-hole: " Yes, we have a Mustang Dyno what car do you have?"
Me: "I have a Subaru BRZ"
A-hole: " Oh, we are not interested, we only do BMW's."
Me: "Oh, but I am not asking for you guys to tune it, I'm just asking to use Dyno Time"
A-hole: "No, we are not interested, we only do BMW's"
Really.... WTF???? I'll pay your rate to use, just let me use it.....
(True Story... sadly)
Edit: BTW, it was this shop
AVIOD them at all costs!!
Active Autowerkes 9940 SW168th Terrace
Miami, FL 33157
(305) 233-9300
Mustang Dyno MD-250
The Following 7 Users Say Thank You to Sportsguy83 For This Useful Post:
BRZranger (03-23-2013), DC2R (06-05-2014), eurominican (04-05-2013), ftc~brz (03-23-2013), killerkid08 (05-11-2013), lbroskee (03-23-2013), Pete (03-27-2013)
Old 03-23-2013, 09:35 AM   #30
Turbowned
Turbowned's Avatar
GBS MAFIA, now sporting Turbo power!!
The Following 2 Users Say Thank You to Turbowned For This Useful Post:
Laika (04-14-2013), Sportsguy83 (03-23-2013)
Old 03-23-2013, 09:38 AM   #31
MannyO
Night Owl
MannyO's Avatar
Drives: 2013 Subaru BRZ
MMMM AVO! Nice build so far man. Will the AVO kit bolt right up to the Nameless OP/DP?
MannyO is offline   Reply With Quote
The Following User Says Thank You to MannyO For This Useful Post:
Sportsguy83 (04-05-2013)
Old 03-23-2013, 12:31 PM   #32
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
After 8 months, I can definitely say it is a dream come true! I initially thought I was going to keep the car stock (looking back, who was I kidding??? What a joke!).
I'm with you bud. I've had mine since launch and still feel childish excitement every time I take it out to drive. Comment from my neighbor when he saw me wrenching from underneath my jacked up car: "That car is so new and you're already ripping it apart!" They just don't understand.
The Following 3 Users Say Thank You to switchlanez For This Useful Post:
350zgoingFRS_lol (05-03-2014), ftc~brz (03-23-2013), Sportsguy83 (03-23-2013)
Old 03-23-2013, 01:08 PM   #33
ftc~brz
Done
Drives: WRB BRZ
subscribed
ftc~brz is offline   Reply With Quote
The Following User Says Thank You to ftc~brz For This Useful Post:
Old 03-23-2013, 10:18 PM   #34
Sportsguy83
Drives: Limited BRZ
Yes, both were designed to bolt up to the stock location. Vubaru has it already. Some loosening up and adjustment needed to be made but that is to be expected because the AVO turbine comes pre-assembled.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
MannyO (03-23-2013)
Old 03-23-2013, 10:23 PM   #35
Sportsguy83
Drives: Limited BRZ
Good amount of progress was made today. HUGE thanks to @jazztennor. He helped me knock out a lot of things today!!!
Two pics for turbo and bottom engine headerless:
The install is not hard. It is time consuming, but you can follow instructions right along. Paul @AVOturboworld has been extremely helpful, even on a Saturday when he is off. I'm close to completing the install, now waiting for some more parts to arrive. I expect to finish the install next Friday. Thanks a lot for all the nice comments, it makes this thread very worthwhile!!
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
akuhei (03-23-2013), jazztennor (03-23-2013), raul (03-25-2013)
Old 03-23-2013, 10:26 PM   #36
OrbitalEllipses
Drives: Attitude
My parents and friends say the same thing; they really don't understand at all.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
Chewie4299 (04-11-2013), switchlanez (03-23-2013)
Old 03-24-2013, 11:19 AM   #37
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Great progress man! Thank you for sharing. Very interested in how the plumbing is run (where oil and coolant are sourced/returned, etc). Subbed!
Jeff86 is offline   Reply With Quote
Old 03-24-2013, 11:24 AM   #38
Sportsguy83
Drives: Limited BRZ
I didn't take pics of that, (I can find one give me a few minutes) but basically to the left of the throttle body (when looking into the engine standing in the front of the car), there is a coolant line that runs towards the back and right of the engine. That one line is replaced with two lines for turbo water intake and return.
The oil return to the oil pump in the back of the block, (it goes in place of that triangular plate that people have had leak oil because it came loose from factory). The oil feed is a block bolt plug located in the front part of the left side injectors.
Edit: throttle water line:
Name:  Water line throtle.JPG
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Jeff86 (03-24-2013), raul (03-25-2013)
Old 03-24-2013, 11:31 AM   #39
Sportsguy83
Drives: Limited BRZ
@2forme, here is the plastic part that needs to be modified.
Name:  Cut plastic.JPG
There are two plastic deflectors in the bumper. their function is to route air towards the radiator. The need to be modified to fit the IC inlet and outlet pipe. The are still left in place and still do their function. Here are mine with the pipes installed:
There's two more things to be modified, but extremely simple stuff. The windshied water tank rests in a hole and that hole was made bigger to make it sit lower and be able to rout the IC piping on that side. Lastly, the bar that runs top to bottom middle of the radiator needs to have the bottom part flattened out. That's it. The rest is just installing parts.
raul (03-25-2013)
Old 03-24-2013, 01:37 PM   #40
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Looks great, thanks for sharing!
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
Sportsguy83 (03-24-2013)
Old 03-24-2013, 08:07 PM   #41
Calum
That Guy
Drives: 2013 asphalt FRS MT
Hey man, would you mind taking and posting some pics of the IC mounting?
Old 03-25-2013, 06:18 AM   #42
Sportsguy83
Drives: Limited BRZ
I'll do my best to remember. It bolts on to the back of the bumper beam.
Calum (03-25-2013)
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 04:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 10:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 02:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 07:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-12-2012 11:35 PM
