Old 03-22-2013, 11:15 PM   #1
soros151
SorosMotorsports
soros151's Avatar
Drives: Whiteout Pearl
Smile Sample Data Stock FR-S
I just wanted to share my amateur log. This is my first time writing about this. Pardon if it is irrelevant or serves no purpose. I just wanted to share.
I know that all FR-S are different to a certain degree, but they all share the same baseline mapping configuration. I have taken some sample data logging in stock configuration. Here is part of the study. Please note that not everything will match in every run. I have compiled most of this information out of a handful of data recordings. This points were taken during a time period of 1 month. Ambient temperatures where between 2*F and 9*F of difference. Do not take this data to heart, it is just an example. I am not responsible for how this information might be used.
NOTES:
Data Acquisition Tool used: Torque PRO
At a steady idle the A/F ratio stays at around 14.6-14.5-14.7
Intake Temperature starts dropping 2*F immediately. Ambient Temp: 77*F. Continous temperature drop down to 93.2*F
At idle you have a 30% Engine Load.
The average CFM is 30.
The app shows that VE of 100% can and does exceed after 5,771 RPMS. At this RPM range you are at 11.7-12.2 AFR.
The theorical Naturally Aspirated engine VE is 137%.
[LATEST DATA WILL BE ON THE TOP]
04-09-13
RAW DATA - Stock Configuration [Long Idle and Steady ~2k RPM]
03-26-13
RAW DATA
- Fixed Auto Profile in Torque Pro
Sample Graphs:
All Data points prior to 3-26-13 <<<Invalid due to miscalculations
Sample Data:
Again this is just samples of data and some notes that I have gathered. Thank you guys.
soros151 is offline   Reply With Quote
The Following User Says Thank You to soros151 For This Useful Post:
AlexTheGreek (04-08-2013)
Old 03-23-2013, 03:53 AM   #2
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
How were you able to pull up those sample data using torque pro?
LeeMaster is offline   Reply With Quote
Old 03-23-2013, 04:13 AM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
You do know that VSC sport doesn't change the way the engine runs? Thanks for those figures though. I take it CFM is the MAF reading?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-23-2013, 07:47 AM   #4
soros151
SorosMotorsports
soros151's Avatar
I was just indicating that I had those settings at the time of testing. and yes CFM would be the MAF readings.
I only told Torque what I wanted to record and then I had it automatically export the info from my phone to my email. Then I just read it,organized it, and broke it down.
Sent from my HTC VLE_U using Tapatalk 2
Old 03-23-2013, 08:20 AM   #5
arghx7
Drives: car
Can torque pro export data to .csv or Excel format? I'd like to see some of your raw data.
Also, for comparison purposes most people use the metric unit for airflow... grams/second .
The Following User Says Thank You to arghx7 For This Useful Post:
soros151 (03-23-2013)
Old 03-23-2013, 02:33 PM   #6
soros151
SorosMotorsports
soros151's Avatar
I can try to post them in my google docs later today.
Old 03-23-2013, 07:04 PM   #7
soros151
SorosMotorsports
soros151's Avatar
RAW DATA Random Samples
Hopefully that helps somewhat.
Old 03-23-2013, 10:15 PM   #8
arghx7
Drives: car
Looks like Torque exports data in a somewhat useless format... if I'm interpreting correctly, it's lining everything up to a 1 second sample rate. There isn't a nice neat timestamp or elapsed time column though. The vehicle speed is in meters/second (mostly useless) and direct injeciton fuel pressure is in psi (practically useless for GDI & diesel pressure).
After a little processsing though, I got some charts going for the Nov_15 file at what looks to be 5:42 PM...
Old 03-23-2013, 10:30 PM   #9
soros151
SorosMotorsports
soros151's Avatar
Thank you. What should I do to improve the data stream on my phone? I was thinking of using a dedicated phone with a lighter ROM to have as a dedicated data logger. I want to keep posting more data, specially when I start modding my FR-S.
Old 03-24-2013, 12:12 AM   #10
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
FYI....CFM stands for Cubic Feet per Minute...not Cubic Feet per Meter...
It's a measurement of Volume over Time...kinda impossible to measure Volume over Volume.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
The Following User Says Thank You to Sony For This Useful Post:
soros151 (03-24-2013)
Old 03-24-2013, 09:30 AM   #11
arghx7
Drives: car
I'm unfamiliar with Torque (I use PC software called OBDWiz, which has its own set of advantages and disadvantages). I don't know all the little options for the app. Having the GPS data is a nice thing to have. Generally speaking though I would:
1) change the parameter list you are recording. Add vehicle speed for one, and if possible see if you can take out some parameters and improve your logging speed. A 1 second sample rate is way too slow for performance driving. If it's possible, record only data from the ECU on some runs.
2) switch to metric units. Certain types of parameters are harder to use with metric, and certain things are easier. I find metric more usable overall though.
3) If there's any way to change the way the timestamp records, try to have an elapsed time column
4) Label your data files with some kind of description after you export them
Old 03-24-2013, 11:16 AM   #12
soros151
SorosMotorsports
soros151's Avatar
Fixed and in my Blog too. Thank You.
Old 03-24-2013, 01:28 PM   #13
zooki
Drives: waiting on a 2021...
If these parameters are true(and I'm not doubting you, just maybe the data), then having a VE over 100% on a stock car should really lay to rest the notion that the stock air intake is not adequate. I personally find it hard to believe a VE of 128% on a N/A motor, especially a mass produced factory stock motor, with stock intake and stock exhaust, and all the compromises that come with them. 963 CFM is more in line with a large displacement V8 motor. These motors are only 121 cubic inches.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 03-24-2013, 04:30 PM   #14
soros151
SorosMotorsports
soros151's Avatar
I completely understand. I have tried using those results in a reverse formula to see displacement and the theoretical VE. I have failed to duplicate the results on paper. All I can say is that there mist be something off in the FR-S' Torque profile. I'll see if I can verify the results.
Also, I was able to get a phone to use as a dedicated Data Logger. Let's see what other data I can gather.
data logging, engine, rpm, volumetric efficiency
GTMat Automotive Sound Deadener - Free Sample GTMat Audio/Visual, Electronics, Infotainment, NAV 85 03-05-2013 10:57 AM
FR-S vs 1998 240SX, looking at the data regal FR-S / BRZ vs.... 28 12-14-2012 08:07 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
DOT Crash Test (non) Data for FR-S/BRZ Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 15 03-24-2012 04:21 AM
FT86/FRS Data Sheet WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 62 11-27-2011 04:12 AM
