#29 | |
I'll tell them to PM you. IMO, just reuse your stock rotors till you have to replace them. That's what we did. |
#30 |
Drives: Whiteout Scion FR-S
Really, wow! XP8's were overmatched in my 1999 M3 for the track, but my FR-S is ~500 lbs lighter, so I may need to readjust my thinking a little for this car. Thinking WAY back, my ~2700 lb 318ti did fine on the track with Carbotech Panther Plus pads (out of date, but < XP8).
My cars always dress formally. They all wear black tires.
#31 | |
#32 | |
Drives: Slow and ugly
#33 |
Thanks, I ordered a set of CL RC6 pads for use with the stock brake calipers and rotors [aftermarket tires] for June when, hopefully, the mounds of snow currently on the ground here in MN will be gone.
#34 |
#35 |
Drives: FR-S Whiteout
I think they do come in a 5w-30 in their standard Mobil 1 formula and a 0w-30 in a racing formula that is cost about double the standard formula. May consider running the 5w-30.
#36 |
Just watch your cats (if you still got 'em) if running the mobil 1 racing. If you do go 5w-30 go with the extended performance vs standard or advanced fuel economy.
#37 | |
http://www.bobistheoilguy.com/motor-oil-102/ Perhaps Amsoil 0W-30 Signature (what I will be using on the track) or Redline 0W-30 would cost less. I think the Mobil 1 M1-104 oil filter is one of the best out there for our car for the track right now, and it's not too expensive.
#38 | |
#39 |
Drives: 4Runner
There's some great info and opinions here. I'll happily add my own.
For oil, I'd stick with the recommended Weight. Brand is open really. Any synthetic is decent, especially if doing service more often then spec'd. I ran a couple of track days on stock pads and a few on Stoptechs. With stock tires, both work fine. No fade, no issues, but disabling the traction control makes a big difference, otherwise you'll definately overheat your pads and fluid. For pressure I run about 30psi cold. I check pressure immediately after getting off the track and adjust accordingly. I would recommend some crash bolts for the front to dial in some negative camber.
diirk
waiting on a Neptune Premium MT |
#40 | ||
What were your hot temps F/R for reference? While driving my car at a spirited pace after work today, I noticed a bit of push at turn in, so I'll definitely be looking into dialing some of that out before hitting the track. I'm sure the crash bolts and some adjustment with the front tire pressure should help with that. Although I'm sure the stock michelins has a lot say about that as well. As far as the pads go, I'm set on the Stoptechs for now. With a 1200 MOT (according to D1cker) they should handle track duty much better than the stock's 600-700 MOT (according to CSG Mike). They will be running CW on SoW at the trackday. Shouldn't be to hard on the brakes from what I can tell. Pretty amped. This will be my first track day in a car since the 90's. LOL EXCITE! ![]() Edit: I think I saw somewhere that the stock strut bolts are 16mm diameter? If so, this would be the same size as the RSX. I happen to have access to some RSX camber bolts that should fit. Last edited by solidONE; 03-23-2013 at 09:59 AM. |
#41 |
| BRZ trackday at Laguna Seca | orthojoe | Tracking / Autocross / HPDE / Drifting | 89 | 03-18-2013 01:09 PM |
| [TRACKDAY] Footage - Australian Tracks Only | nathank | Australian Meets & Events | 5 | 03-12-2013 05:34 AM |
| 2nd trackday in FR-S | icemang17 | Tracking / Autocross / HPDE / Drifting | 4 | 09-24-2012 04:40 PM |
| 1st trackday in FR-S | icemang17 | Tracking / Autocross / HPDE / Drifting | 10 | 09-01-2012 10:02 PM |
| New GT86 pics on trackday | Harinjo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 21 | 01-08-2012 03:16 PM |
