Old 03-22-2013, 03:20 PM   #29
NorCalRider
Drives: 2009 Toytoa Tacoma 4x4 Dbl Cab LB
Can't wait to see a few drag strip passes. Looks like a fun car. Congrats on the numbers.
2013 SWP BRZ Limited(on order)
2012 Vw Jetta Sportwagen TDI 6mt Navi and Pano
2009 Toyota Tacoma 4x4 Double Cab Long Bed
1994 Honda Civic HB TurboCharged Track Car
NorCalRider is offline   Reply With Quote
The Following User Says Thank You to NorCalRider For This Useful Post:
Pure Automotive (03-22-2013)
Old 03-22-2013, 06:19 PM   #30
Black86
Black86's Avatar
Drives: 2013 Raven Black FR-S
nice car and ive been following this turbo kit for awhile i picked up a 13 raven black fr-s and would like to go this route along with e85 and full kill mode how much do you have in the car not including wheels and suspension? you put down more than dynosty and accelerated only put down 460hp on a gt30 im impressed and this kit is so much more price negotiable! congrats and props to FBM!
Black86 is offline   Reply With Quote
Old 03-22-2013, 06:35 PM   #31
djdnz
1337
Drives: 2013 BRZ WRB S/C
Crazy power out of a stage 1 setup. And lol @ the music.
djdnz is offline   Reply With Quote
Old 03-22-2013, 06:36 PM   #32
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
I've always wanted to see a car/dyno video with some hardcore in it, lol. So I did it!
Pure Automotive is offline   Reply With Quote
Old 03-22-2013, 06:38 PM   #33
Pure Automotive
Maybe next time I make a video I'll go with some Britney Spears? lol
The Following User Says Thank You to Pure Automotive For This Useful Post:
Justin91M (03-23-2013)
Old 03-22-2013, 06:52 PM   #34
Black86
Black86's Avatar
haha ^ that will make the video of course
Old 03-22-2013, 07:43 PM   #35
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
If you don't like emmure GTFO :P
Tansey86 is offline   Reply With Quote
Old 03-22-2013, 07:52 PM   #36
tisb0b
Drives: Grey GT86 MT
If you feel the urge at least compromise on the Children of Bodom cover ;D
[ame="http://www.youtube.com/watch?v=WGtXlBbWeB4"]Children Of Bodom - Oops I Did It Again! - YouTube[/ame]
tisb0b is offline   Reply With Quote
Old 03-22-2013, 09:16 PM   #37
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
- Full Blown Stage 1 w/ e85 upgrade- $5,000
- ACT 6 Puck clutch with 10.5lb Prolite Flywheel- $900
- Greddy Evo3- $800
- Motiv Overpipe- $275
- J2 Engineering Front Pipe- $100
- Front Bumper Inlet- $40
- Cusco Engine Mounts- $250
- Whiteline Transmission Mount- $40
- Whiteline Rear Subframe Bushings- $40
- Vacuum block/Manual Boost Controller/Boost gauge- $300
- Mishimoto Catchcan- $110
- Perrin Light Weight Crank Pulley- $100
- Lots of Dyno time and Datalogging- $200
These are all estimated amounts. Tires/Wheels are a major supporting mod for this car.
Up next:
- FBM Oil Cooler
- FBM Ford diff upgrade
TyperRspec789 is offline   Reply With Quote
Old 03-22-2013, 09:24 PM   #38
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Is this necessary?
Old 03-23-2013, 03:35 AM   #39
TyperRspec789
Originally Posted by whitefrs View Post
Is this necessary?
Definitely necessary if you track the car. The stock engine mounts can't handle 400whp. At the track, the shifter would bounce side-to-side from the engine moving back and forth under load. The Whiteline parts are extra security to make sure as much power is making it to the ground.
All three parts also increase feedback dramatically in the car. The engine mounts really make you feel ever vibration coming from the motor. Better communication mods if you will.
Old 03-23-2013, 07:22 AM   #40
benster
Drives: none yet
Originally Posted by diss7 View Post
Nice results.
But starting a dyno at 4000rpm? Seriously?
It sure does make it look less peaky I suppose.
did you expect a 4 cylinder engine pushing 17 psi to start boosting at 2600 or 3000rpm? if so, you better start reading more on engines buddy. even high psi v8 engines don't spool up till 3000. you want power out of a small engine? make sure you're ready to lose some of that power down low.
I'm not saying driveability sucks now since I haven't had a ride in one, but im sure it's not the same as stock anymore puttering in city.
and btw, that's awesome pushing out that much out of a stage one kit
benster is offline   Reply With Quote
Old 03-23-2013, 07:52 AM   #41
diss7
Drives: AE86, 2x GT86, TE27
I don't need to read up on engines, buddy.
I expected this turbo to kick in where it has. My point was to highlight that posted a graph starting at 4000rpm could be seen as misleading. Would you see any issue with putting a t67 on the car, and just showing a graph starting at 5500rpm?
I'm not knocking the kit or the results in any way.
diss7 is offline   Reply With Quote
Old 03-23-2013, 07:58 AM   #42
diss7
Also, for anyone interested in the turbos expected performance at this output. A friend of mine ran this turbo for two seasons of drifting on a unopened sr20 at 440rwhp. The motor popped and he has since replaced with a built motor. Using the same turbo but now tuned on e30 it made 460rwhp, but he's really pushing the turbo to the limit now, tbh I think he's just looking for a reason to replace it.
Full Blown Motorsports Stage 1 Turbo Kits PROVEN POWER!@ Pure Automotive Performance Pure Automotive Forced Induction 86 11-26-2013 08:27 AM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! Pure Automotive Forced Induction 181 03-12-2013 02:11 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Forced Induction 68 02-25-2013 12:06 PM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Pure Automotive Mid-Atlantic 22 02-12-2013 10:13 AM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Mid-Atlantic 61 01-30-2013 08:38 PM
