#155 |
Drift King
Drives: '13 Firestorm FR-S 6MT
Thank you for the clarifications, I didn't realise torque wasn't able to run on that version of android without root, are you guys using the usb to obd adapter or wifi obd Adapter?
'13 6MT Firestorm FR-S
#156 | |
Torque can run on 3 types of connections; Bluetooth, WiFi, and USB. Bluetooth - There is no restriction on the OS, per se. It can run on devices all the way down to Android 2.2 that have bluetooth. The problem with head units, is that the bluetooth itself is limited to just connections with phones or A2DP. You can't connect ancillary devices such as an OBD2 scanner. WiFi - WiFi is only supported in AdHoc mode, which only available with root. Since I think all Android devices have WiFi capability, including this head unit, this isn't a physical limitation. However, root is required to run the WiFi adapter in AdHoc mode. You will lose the ability to have internet unless you are running the 3G adapter. WiFi OBD2 adapters are also more expensive (40-50$). USB - USB requires host mode in the OS. This is only supported officially by Android on 3.0 (Honeycomb) and above. Ca-Fi managed to modify it's Android build and include it, which is why they use USB adapters for Torque on their head unit. What this rooting/firmware solution does, is enable root and install firmware which allows the OS of these knockoffs to run a USB Bluetooth adapter as part of the native system. As I showed in the video, it's an external USB adapter that is plugged into a USB hub that runs off the USB port coming from the rear of the unit. I find this is a superior solution to using something like a nexus 7 because the refresh rate in Torque is much faster. I think the Bluetooth adapters built into tablets are low powered or something. Hope this clarifies everything! Last edited by 2forme; 03-19-2013 at 04:36 PM. |
#157 | |
Drift King
Awesome.
#158 | |
#159 |
Drift King
What apps are needed after root to do this? Or is it as simple as PnP after it's rooted? Also what dash kit/harness are you using for the HU, would the beatsonic one work?
#160 | |
Beatsonic will need modifications like anything else. I actually prefer the Metra dash kit myself. It's cheaper and has better mounting. Wiring harnesses are standard toyota harnesses, and the lexus antenna adapter. Made by Metra. |
#161 |
Drives: Raven MT Scion FR-S
after rooting my HU, it would appear sygic is no longer installed? Do i just download it again from the play store?
#162 |
Drives: RX8 -> 2013 FRS
Naw its still on the deck. Use the file manager to look through the folders. You should find an apk
Sent from my SGH-T999 using Tapatalk 2 |
#163 |
Drives: GBS BRZ Limited
On the XM thing, as these units have an Aux In you could get an external XM/Sirius tuner and wire it into these head units using standard RCA connectors. I know this isn't as clean an install as it would be if the HU supported it nativily but it is an option and shouldn't result in any loss of fidelity/SQ.
#164 | |
Drift King
#165 |
ill probably get a DIY up for my audio install once its all complete. I plan on using a separate siriusXM receiver since this HU doesnt support integrated.
The rest of everything is pretty straightforward, ill be installing my rear view camera this weekend as well So far im loving this unit.
#166 |
I'm curious where you're tossing that camera
#167 | |
[ame="http://www.amazon.com/Waterproof-Vehicle-Backup-High-definition-Viewing/dp/B005CTKYB4"]Amazon.com: Waterproof Car Rear Vehicle Backup View Camera High-definition Cmos 170 Degree Viewing Angle E363: Electronics[/ame] the camera has a thin mounting plate that happens to fit perfectly in the space between the 2 license plate lights on the trunk, directly below the emblem. Nice and hidden, with room behind to drill a hole for routing the wires. Ill have some pictures up once everything is finished. |
#168 |
Does anyone have any idea what to do if your unit just shows a white screen all of the sudden? I took mine out to make a modification to the dash kit and when I plugged the harness back in, its unresponsive and just has a white screen. I can turn it on and off with the volume knob, but nothing else works
Any help would be great! |
| Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) | JPxM0Dz | Canada Classifieds | 2 | 01-20-2013 12:51 AM |
| chinese man sues wife for being ugly: wins | wrxgoose | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 11-07-2012 11:58 AM |
| Counterfeit Chinese Airbags | @Art_Mighty | Other Vehicles & General Automotive Discussions | 11 | 11-03-2012 04:20 AM |
| JDM Vs. KnockOff | SIRvive | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 03-05-2012 06:32 PM |
| Gang of Chinese kick, yell, and drag a little caucasian boy | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 34 | 01-20-2012 11:47 PM |
