Old 03-17-2013, 05:07 PM   #337
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by SMOKETREES View Post
With a 35mm offset and you add a 5mm spacer in the rear with a tire with of almost 9" the back wheel will sit perfectly flush with the natural camber. Hope this or last post helped!
With a +35 offset would the 8.75" rims with 225-235 tires not poke up front? I don't want any. Rather have it sunk in but can't find +38's anymore.
Old 03-17-2013, 05:37 PM   #338
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
35 will poke some if on stock suspension. Camber bolts will fix that
SMOKETREES is offline   Reply With Quote
The Following 2 Users Say Thank You to SMOKETREES For This Useful Post:
DAEMANO (07-09-2013), SkAsphalt (03-18-2013)
Old 03-18-2013, 06:12 AM   #339
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Yes you may do camber bolts, crash bolts, you can put a spacer in the rear to make a more staggered look but reality it's a square setup. Lower the car on some springs. Eibach pro kit should eliminate about 2-4mm and same with rear due to natural camber in the rear. I have a 35 offset and lowered on eibach pro kit and have about maybe less or a tad but more than 2mm. Camber bolts will work cause you can dial the front to about -1.5 and also you can get some LCA or whitelines rear bushing camber kit and dial the rear to just -1.0 and the car will have same look (super clean looking, trust me)
Thanks for this info.
Just out of curiosity, how does a 1" drop (from the Pro Kit) increase the offset? The Flush Wheel Offset Chart says that to be flush with a 1" drop, front wheels that are 8.75" wide need an offset of 42-48.
My offset is 33 so looks like there'll still a way to go! I was also told not to change camber as it will wear out tyres.
white_knight is offline   Reply With Quote
Old 03-18-2013, 10:00 AM   #340
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
With an inch drop it still changes a lot within the suspension. I noticed people that are on stock suspension that the front wheels sticks out way more than mine that is dropped which is why I came to the conclusion. Now changing camber, if you go past -2 camber you will start seeing lots of wear but with your camber at about -1.25 to -1.5 that's not much camber. I will say that you might wanna rotate front tires back n forth and flipped them to even wear out but from what I have been told been many friends who are running crazy camber that a -1.25 in the front won't do anything to wear and you'll have a better response in turning . Now another route you can take is just simple crash bolts! Those you can get some camber, I believe about an inch the most and those are used anyways for if a car gets into an accident and alignment shop can't get it into factory spec so they put those on to fix it up. If you don't wanna go thru tread wear go this route. But if you can put up with rotating tires a little bit more than go with camber bolts so you can have the ability to change out some camber if you decide to autox
The Following User Says Thank You to SMOKETREES For This Useful Post:
white_knight (03-20-2013)
Old 03-19-2013, 06:07 PM   #341
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Attachment 29542
Attachment 29543
Attachment 29544
New shoes out on today! Thanks again @JoeBoxer. Running 527 18x8.75 35mm offset with 225/40/18 all around
bump for @SlvrFrs
Old 03-21-2013, 02:16 PM   #342
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
Decided i couldnt wait any more to put my wheels on so thats what i did yesterday
530s 18x8.75 et 33 with 225/40/18 all around.
Instagram @admsevi
sevi21 is offline   Reply With Quote
The Following User Says Thank You to sevi21 For This Useful Post:
tripjammer (03-22-2013)
Old 03-21-2013, 02:31 PM   #343
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
looks nice, good choice
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
sevi21 (03-21-2013)
Old 03-21-2013, 02:35 PM   #344
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
Thanks man, i love them
Instagram @admsevi
Old 03-21-2013, 03:20 PM   #345
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Thats beautiful, same set up I want, but I assume stock suspension? That seems to poke out more than I like, I'm planning on some eibach or H&R's I'm hope that with some camber bolt will fix the poking. I love the concavity though.
Old 03-21-2013, 03:42 PM   #346
GregV
Drives: Kia Stinger GT2
Got my 527s mounted and balanced today... will probably mount them on the car late next week. Still expecting another day of snow here
GregV is offline   Reply With Quote
Old 03-21-2013, 04:15 PM   #347
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
Yah its on stock suspension, but when i have some change laying around
i will drop it on some eibachs and like you said get some camber bolts for the
front. But im very happy with the specs i went with
I love the wide stance!
Instagram @admsevi
Old 03-21-2013, 04:59 PM   #348
white_knight
530s +33 look much better with Eibach Pro Kit
The Following User Says Thank You to white_knight For This Useful Post:
Old 03-21-2013, 09:14 PM   #349
Wes
Wes's Avatar
Yeah that does look much better, how's the poke up front? Would you say camber bolt is necessary?
I like your thinking :happy0180:
Are you going with pro kit of sportlines? Pro kit looks just fine, but I wonder if sportlines will make just flush enough
The Following User Says Thank You to Wes For This Useful Post:
sevi21 (03-21-2013)
Old 03-21-2013, 09:33 PM   #350
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Yeah I will be purchasing coils for more drop. Car would look soooo good with the 530 and 527 when car is slammed. I am running eibach pro kit also so those might be for sale soon
Wes (03-21-2013)
17 wheels
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 03:55 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
