Old 02-08-2013, 07:04 PM   #1
mact
Drives: 13 GTI
My Free tow hook license plate mount
Well almost. I need to find another cheap tow hook in case I need to use one. I've always been a fan of home projects and a tow hook license plate frame seemed like something I could easily tackle.
Originally I had been looking for a suitable bolt/rod that came with M16x1.5 thread pitch which is what the tow hook for this car is, but they are pretty rare. So I decided to just use my factory tow hook. See photos below:
Basically, I cut the ring off the hook, drilled and tapped for a 10mm bolt, and made the bracket from some scrap angle iron (I think that's what it's called), and used some hardware from the factory license plate kit.
mact is offline   Reply With Quote
Old 03-21-2013, 12:10 PM   #2
mact
Drives: 13 GTI
Going to take it off one of these weekends and paint it flat black.. So far it's holding up well.
Old 03-21-2013, 12:23 PM   #3
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
You should paint the bracket, you dont want rust forming prematurely sneaking inside the threads and into the engine bay. But other than that, looks good!
LeeMaster is offline   Reply With Quote
Old 03-21-2013, 12:58 PM   #4
Jayde
Jayde's Avatar
Jayde is offline   Reply With Quote
Old 03-21-2013, 01:06 PM   #5
Xdragonxb0i
Drives: ex500r
Should be moved to the DIY
i think we could probably source the correct size bolts at Lowes and do this, wouldnt have to tamper with the tow hook
Xdragonxb0i is offline   Reply With Quote
Old 03-21-2013, 01:17 PM   #6
mact
Drives: 13 GTI
I searched every home improvement and hardware store in my area, and even went to Fastenal. None if them carried m16x1.5 threaded bolts. Fastenal could have ordered one but it would have been cheaper just to buy a used tow hook.
Old 03-21-2013, 01:40 PM   #7
sklimo
What length do you need? m16x1.5......... I have some here in my shop
Old 03-21-2013, 03:12 PM   #8
mact
Drives: 13 GTI
I didn't get a measurement of the length but I made the cut right at the start of the loop on the factory tow hook.
Old 03-22-2013, 10:26 AM   #9
gily25
Drives: Silica BRZ 6MT
Custom colored tow hooks are showing up on ebay...you should be able to pick up an inexpensive one...jic...there are a few 86 cars being parted out on ebay, you may be able to message them and get the oem one cheap.
gily25 is offline   Reply With Quote
Old 03-22-2013, 03:15 PM   #10
Mpowered
Drives: BR-Z
I dont understand wanting to go with a tow hook mount instead of the factory mount. To me, the centered factory mount looks better and the drilled holes are on a part of the bumper that cant be seen.
Mpowered is offline   Reply With Quote
Old 03-22-2013, 03:43 PM   #11
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
The reason is some people don't want holes in their bumper. Like me, I had the dealership not drill holes. So my front bumper is flawless.
FRSfan111 is offline   Reply With Quote
Old 03-22-2013, 03:49 PM   #12
mact
Drives: 13 GTI
This is where the holes go.
To answer your question as to why. IMO, having the plate in the middle reminds me of.... teeth.
Old 03-22-2013, 03:56 PM   #13
Mpowered
Drives: BR-Z
ah. for some reason i thought the holes went underneath. guess it makes more sense but ive always thought tow hook mounts were ugly.
Old 03-22-2013, 04:33 PM   #14
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
I couldn't agree more. The tow hook mounts look cheesy.
iLuveKetchup is offline   Reply With Quote
Drilling a Hole for Tow Hook or License Plate Hanakuso DIY (Do-It-Yourself) Guides 28 04-12-2019 05:02 PM
Now available!!! PTUNING Adjustable Front License Plate Holder w/ Tow Hook Mount Mrc@ptuning Exterior Parts - The Rest 24 03-14-2013 11:50 AM
Now available! PTUNING Adjustable Front License Plate Holder w/Tow Hook/ camera mount Mrc@ptuning Exterior Parts - The Rest 29 12-07-2012 02:37 PM
[For Sale] Rho-plate Tow Hook Mounted License Plate rack pizzahead20 Canada Classifieds 0 08-23-2012 12:06 AM
Tow-hook license-plate template? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 5 06-24-2012 12:51 PM
