Old 03-21-2013, 01:37 AM   #1
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
hit a pothole doing 70mph
^see thread title.
Was on the way to work and drove over a pothole I couldn't see well (since it was underneath an overpass whose shadow obscured the pothole)
Now my steering doesn't feel tight like it used to, which I noticed immediately after hitting it. Overall the car feels 'softer' and turn in response is not as sharp as it was.
Car doesn't pull in either direction really.
I checked the tires when I parked at work and they all looked okay.
Didn't check the tire pressure yet (didn't have time) but I'm going to check in the morning and report back.
But does this sound like an alignment issue? Or did my tires just get some air kicked out of them from the impact?
dori. is offline   Reply With Quote
Old 03-21-2013, 01:44 AM   #2
Pete156
I like to eat!
May have broke an end link (sway bar).They're a weak point.
Pete156 is offline   Reply With Quote
Old 03-21-2013, 01:45 AM   #3
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
put your car up the rack and check if anything got bent. then do a full alignmet
86_ZN6 is offline   Reply With Quote
Old 03-21-2013, 01:45 AM   #4
Spicer66
Spicer66's Avatar
Drives: Raven 6 MT
Lift the front off the ground, make sure you use the frame as a lift point. Try to move the wheel up and down, side to side. If there is any play at all you should be able to feel it, that would be a good indicator something got boinked a bit too hard.
Spicer66 is offline   Reply With Quote
Old 03-21-2013, 01:51 AM   #5
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
take it to your dealer and see what they can do for you
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 03-21-2013, 07:06 AM   #6
Blue86
Drives: Sonic Blue 86GT Manual
Drive over the pothole again but a bit faster to knock everything back into place
Blue86 is offline   Reply With Quote
The Following 12 Users Say Thank You to Blue86 For This Useful Post:
aceangel (03-22-2013), azngolfur (03-22-2013), boonFRS (03-21-2013), D1cker (03-21-2013), dori. (03-21-2013), Ganthrithor (03-21-2013), jmaryt (03-22-2013), jstans84 (03-21-2013), lazyluka (03-21-2013), sklimo (03-21-2013), was385 (03-21-2013), zaptorque (03-21-2013)
Old 03-21-2013, 09:02 AM   #7
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
IN Michigan we have a lot of potholes. Since one has to find a pothole that would impact the OTHER side of the car to correct the deficiency, it should be easy. Can't comment on other states. The same speed and similar size pothole isrecommended.
BRZfan is offline   Reply With Quote
Old 03-21-2013, 09:06 AM   #8
White64Goat
and the posted speed limit where said pothole was hit is?............
Old 03-21-2013, 09:19 AM   #9
GregV
Drives: Kia Stinger GT2
No no no no no.... everyone knows you're supposed to hit it at the same speed on the other side of the car and it will even the suspension out.
GregV is offline   Reply With Quote
Old 03-21-2013, 10:18 AM   #10
NYNOMAD
Drives: BRZ WRB LTD MAN
Yes but do it in reverse to knock everything back.
NYNOMAD is offline   Reply With Quote
The Following User Says Thank You to NYNOMAD For This Useful Post:
ProjectD (03-21-2013)
Old 03-21-2013, 11:17 AM   #11
Jayde
Jayde's Avatar
Drew, no!!!!! I hope she's ok! I take it we won't be seeing you tomorrow night.
Jayde is offline   Reply With Quote
Old 03-21-2013, 12:05 PM   #12
GNS
Drives: .
Drive over the pothole at 88mph, then remember to take the other lane so you don't hit it the first time.
GNS is offline   Reply With Quote
Old 03-21-2013, 12:10 PM   #13
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
lol at hitting pothole again.
Old 03-21-2013, 12:31 PM   #14
dori.
Señor Member
dori.'s Avatar
55
The Following 2 Users Say Thank You to dori. For This Useful Post:
Ganthrithor (03-21-2013), Zaku (03-21-2013)
Chirp at 70mph markitect Issues | Warranty | Recalls / TSB 15 12-05-2012 09:30 PM
Hit pothole blew tire.... now have odd sound clayrush Issues | Warranty | Recalls / TSB 15 08-24-2012 12:57 AM
