Old 03-20-2013, 04:25 PM   #1
steve87j
steve87j's Avatar
Drives: Scion FR-S RAVEN
Android Knockoff Headunit D.I.Y REQUEST
So since this is the best option (ebay android headunit) I was hoping someone can provide everything that's needed to perform the install?
what tool is needed to remove dash bezel?
brackets?
harness?
how easy is it?
what to look out for?
I'm about to make the purchase and I want the install to go as smooth as..... something really smooth.
Anybody that instlaled it plse provide feedback on installation
steve87j is offline   Reply With Quote
Old 03-20-2013, 09:31 PM   #2
Fonzi
Drives: 2013 White FRS
I got one off ebay. You need the harness, you need a lexus antenna adaptor. I forget which one, you can find it in search. There is a lip on the black plastic that will need removed by a razor knive on top and bottom.. There is a space on each side of the unit once installed. Haven't had time for that yet.
Fonzi is offline   Reply With Quote
Old 03-20-2013, 11:42 PM   #3
steve87j
steve87j's Avatar
wait how do u fix that space? i wont be happy with that
Old 03-21-2013, 06:36 AM   #4
2forme
Metra dash kit.
The Following 2 Users Say Thank You to 2forme For This Useful Post:
Fonzi (03-21-2013), kharn83 (04-03-2013)
Old 04-03-2013, 01:42 AM   #5
kharn83
Drives: S15 Silvia
hi 2forme
does the android kit have a external gps antenna or microphone? if so how did u wire these through the dash?
if not, sounds like a fairly easy install hopefully!
thanks
robert!
kharn83 is offline   Reply With Quote
Old 04-03-2013, 06:20 AM   #6
2forme
Originally Posted by kharn83 View Post
hi 2forme
thanks
robert!
The GPS is external and included. It is magnetic so I just stuck it on top of the metal frame that sits below the vents. Works fine through the vents.
The microphone is internal in the front of the unit. I haven't tried an external one.
Old 04-03-2013, 07:09 AM   #7
kharn83
Drives: S15 Silvia
thx 2forme - by vents and the metal frame, do u mean the air vents for driver and passenger? if so isnt there the soft plastic dash which covers those vents? i cant see a metal frame that you refer to.
Also, i got the unit today thanks to your advice
So I am wiring it up, although I'm not sure what to do with the following wires from the head unit:
p.cntr (amplifier signal input) wire
p.ant (auto radio antenna) wire
I've hooked the rest of them as appropriate into the metra wiring harness, and the only wires that I haven't connected from the metra harness (and I'm not sure what to do with) are :
power antenna wire
amp turn on wire
amp ground wire
dimmer wire
phone mute wire
I also purchased the 40-LX11 antenna adapter. I assume the Headunit p.ant wire links to the blue wire of the 40-lx11 antenna adapter, leaving the metra harness power antenna wire unused?
your advice as always would be much appreciated, and sorry if it was heaps to read >< !
Old 04-03-2013, 07:17 AM   #8
2forme
In the dash where the head unit goes (under the center vents), there is a metal frame that essentially frames where the head unit sits. I stuck it on top of that.
p.cntr (amplifier signal input) wire - This goes to an amp signal wire if you have one.
p.ant (auto radio antenna) wire - This goes to the antenna power wire on the antenna adapter you bought.
power antenna wire - See above
amp turn on wire - See above
amp ground wire - Ground
dimmer wire - Orange with white stripe on the metra
phone mute wire - Unused
I also purchased the 40-LX11 antenna adapter. I assume the Headunit p.ant wire links to the blue wire of the 40-lx11 antenna adapter, leaving the metra harness power antenna wire unused? Yes
Answers are in the quote
The Following User Says Thank You to 2forme For This Useful Post:
Old 04-03-2013, 08:02 AM   #9
kharn83
Drives: S15 Silvia
awesome mr 2forme u rock ^_^ haha.. if u had a donate button id donate u a beer !! lol
Old 04-03-2013, 08:09 AM   #10
2forme
Haha thanks, I don't drink, but appreciate the thought!
Old 04-03-2013, 09:31 AM   #11
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
How do you both like this headunit? Reviews please!
Lee358 is offline   Reply With Quote
Old 04-03-2013, 11:31 AM   #12
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
Which unit? @2forme already did perhaps the most indepth reviews I've ever seen on a car stereo head unit for the two main Android based units available here.
Skippman is offline   Reply With Quote
The Following 2 Users Say Thank You to Skippman For This Useful Post:
Lee358 (04-03-2013), Mr.Jay (04-03-2013)
Old 04-03-2013, 11:54 AM   #13
2forme
@Lee358, did you want a review on the knockoff?
Old 04-03-2013, 12:08 PM   #14
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
I got the same unit and its great for the price and I really enjoy having torque setup on it as well. Boot up is a bit slow and if nothing is on the unit itself is a bit loud but for cost I have no complaints.
I routed my gps to the roof where my oem mic is.
Real easy install tho some thongs have to be modified to fit
Out of the FRS game
Mr.Jay is offline   Reply With Quote
The Following User Says Thank You to Mr.Jay For This Useful Post:
2forme (04-03-2013)
Chinese Ca-Fi knockoff has been rooted! Torque works! 2forme Electronics | Audio | NAV | Infotainment 1267 09-05-2015 06:18 AM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
New Parrot Android based headunit iNcHeS686 Electronics | Audio | NAV | Infotainment 20 11-12-2012 10:39 PM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 05:32 PM
Android vs iOS vs BB os...which is best? Raiden Off-Topic Lounge [WARNING: NO POLITICS] 19 02-02-2011 10:37 PM
