#43 |
Drives: 2013 WRB BRZ Limted
I've installed the rears and yes, you have to drill the hole out a little.
Moto-East Tune, Perrin drop-in, P&L Catless Header and Overpipe, Motiv HFC, Invidia Q300, 17x9+35 Enkei RPF1, 245/40 PSS, RCE & Koni Yellows
| The Following User Says Thank You to wgnzlz For This Useful Post: | SVThis (03-09-2013) |
#44 |
Drives: Scion FRS
In picture #7 of the instructions is there a metal protrusion in the body of the OE strut that needs to be filed down?
We're not happy till you're not happy 2013 Scion FRS Whiteout 6MT SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover. |
#45 | |
Drives: ND2, formerly BRZ (MT/CBS)
I went ahead and installed all four corners and Sam's bar. The local weather was too good to pass up (unheated garage), even if I do have to go back and install shims at the front upper mounts later. No real issues to report. It took a good while (way more than 2 hrs), but compared to the DIY, I was using compressors to disassemble and reassemble. So far, random driving on winter tires and at full soft all around, it is hard to tell any difference from stock, which is good and as expected. cheers! |
| The Following User Says Thank You to jdrxb9 For This Useful Post: | SVThis (03-14-2013) |
#46 |
Drives: Scion FRS
Here are Koni's instructions for the spacer. There's a bunch of slop without it in there.
| The Following User Says Thank You to SVThis For This Useful Post: | Ninjin (03-16-2013) |
#47 |
Drives: SWP BRZ 6MT
I received the spacers yesterday, but it looks like the instructions show the strut off the car. Will the spacer go on without taking too much apart? I'm thinking that using a spring compressor like the instructions say isn't compatible with the strut being on the car still.
| The Following User Says Thank You to Ninjin For This Useful Post: | DAMotorsports (04-06-2013) |
#48 |
Drives: Scion FRS
Koni really goes the extra mile with clear and concise instructions.
#49 |
Drives: SWP BRZ 6MT
Well, I guess I can try to slip them on without removing the struts. What's the worst that can happen?
Wait, don't answer that. Sent from my Nexus S using Tapatalk 2 |
#50 |
Drives: Scion FRS
I'm thinking you might have a problem with the shaft not being centered perfectly through the top hat hole. Good luck and let us know.
#51 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Ah yes, that. I noticed when adjusting them, how much the nub moves around, it did worry me.
#52 |
Drives: Scion FRS
I cut my donor struts today. Everything went pretty smooth. There was very little spray drilling the small bottom hole. I pumped the oil into jars my wife uses to drain grease. I never told her I did that. Hope she doesn't decide to use the grease for anything.
Used a band saw to cut the tops off and got a nice clean cut. Torqueing the bottom bolt to 55 ft/lb took a little more effort than I was expecting. The insert dropped right in with no need for pounding. Since I didn't have a 14mm drill bit I used a 9/16 and it worked fine. I'm going to get a 12mm for the rear top hats as I don't want any slop there.
#53 |
Drives: 2010 Mustang GT , Miata
I was able to install the spacers by taking the top nut off, slipping the spacer on, then jacking the car slowly until the hole and the strut were centered. A deep well socket the same OD as the spacer and a few taps put them in place.
#54 |
Drives: SWP BRZ 6MT
@rapid, may I ask what tool you used to remove the nut? It looks like the center adjuster nut is supposed to be held still while the outer nut is turned. I couldn't find anything in my limited tool chest that could do this while the strut is on the car.
#55 | |
Drives: Scion FRS
#56 | ||
The center hole is just big enough to fit a deep 9mm 1/4" drive socket. Also, you can use the go-thru socket with a 3/4" crowfoot and torque wrench. They come in handy for sway bar end links as well. No idea how long they will hold up, though. |
| Koni Suspension Components | dale.m | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 76 | 06-20-2013 10:00 PM |
| Adjustion compression on a Koni 8612 insert? | Evil86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 03-05-2013 06:01 PM |
| Tein Street Basis coilover, Koni struts and shocks | JoeBoxer | Brakes, Suspension, Chassis | 6 | 12-25-2012 10:43 AM |
| GTS owners... difference between 'sports' abd 'vsc sports' button? | UnLeasHer | AUSTRALIA | 5 | 07-26-2012 04:22 AM |
