Old 03-20-2013, 03:09 PM   #43
XPR Small Block
Drives: Scion Frs
Originally Posted by FullBlown View Post
we have tons of these kits on 2.0L-2.2L making 800-1000hp+ without any issues. These cars are going anywhere from 10's - 8.50's in the quarter.
I'm sure a lot of big block domestic guys are breaking these , but this has been tested and proven for what we are doing.
well whats the difference big power is big power no matter where you go??? launch 800-1000 hp on a drag strip is gonna do the same damage to the diff, i have a corvette with 500+ hp to the wheels with a small block chevy motor i have blown 1 ring an pinion on 15 hard launches i would love to see a 8.8 keep up with a dana 44
XPR Small Block is offline   Reply With Quote
Old 03-20-2013, 03:21 PM   #44
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Well, torque + a heavy car breaks things. I don't want to get in a whole big debate on which is better. This has been working for us for years, that is the reason we stuck with with it.
FullBlown is offline   Reply With Quote
The Following 3 Users Say Thank You to FullBlown For This Useful Post:
crook (03-20-2013), No Limit Motorsport (03-20-2013), ravenblackfrs (05-31-2013)
Old 03-20-2013, 03:23 PM   #45
XPR Small Block
Drives: Scion Frs
my vett only weighs 200 lbs more than a frs..
Old 03-20-2013, 03:33 PM   #46
FullBlown
FullBlown's Avatar
Drives: Scion FRS
we'll let you know when we break it
Old 03-20-2013, 03:35 PM   #47
XPR Small Block
Drives: Scion Frs
haha good deal shouldnt be too long with your 607 hp mark
Old 03-20-2013, 04:22 PM   #48
Tunagoat
Drives: 2004 GTO
The 04-06 GTO gys are switching to these.. a couple of themm are into the 8s at 3800+lbs.
Tunagoat is offline   Reply With Quote
Old 03-20-2013, 04:30 PM   #49
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
This setup may be a 8.8 IRS but will be built with stronger parts than a factory mustang IRS. This rear in a 2700lb car will handle whatever you throw at it.
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
Enalband24 (03-08-2016)
Old 03-20-2013, 05:07 PM   #50
EZWood
BAMF
EZWood's Avatar
In the jeep world the 8.8's are stronger than the 44's, but the 44a with the aluminum housing for IRS are stronger than the ones with tubes attached. With the tubes connected it stresses the housing and it flexes breaking the r&p. So I'm not sure how the irs 8.8 compares to the IRS 44, but I've been told by reputable sources that the internals for the 8.8 are sturdier, so in the end it depends on the weight, power and application and sometimes a little trial and error are necessary for these kinds of things. Instead of saying this is better than that, let's get some numbers for weight power and tire info for where these break instead of saying I wouldn't buy this, or that is better. Pics or it didn't happen!
Old 03-20-2013, 06:04 PM   #51
XPR Small Block
Drives: Scion Frs
ok so tell me why toyota guys go dana 44 with chromoly shafts?? thats all i see in nor-cal same for jeeps either dana 44 or 60's.. never see ford running gear under any rig but a ford..." except the 9 inch" im just repeating what ive been seen and told for years from hundreds of people, ive never seen anyone get excited about putting a for 8.8 in there car or truck i even have ford guys saying they wouldnt do that swap
Old 03-20-2013, 06:40 PM   #52
silverlegacy
Drives: Turbo Miata-Fairmont drag project
Comparing solid axle versions of Dana 44 and Ford 8.8 isn't relevant to this, not in the least. There are different variables at play there.
The Dana44 ICA or Dana 44 IRS used in Corvettes and Vipers are a little bit weaker in overall design than the Ford 8.8 IRS. The Corvettes and Vipers have stronger axle shafts, but that is not included in the argument here. Most of the 44 IRS units you will find are from Corvettes which use the 8.5" ring gear which is slightly (very slightly) weaker than the Ford 8.8" ring gear (I've seen some with the Chrysler 8.75" as well, there may have been years where those were used as well). Now the Vipers use a 8.9" ring gear which can be retrofitted into the Corvette housing if you know what you are doing. It might be stronger than Ford, but it will be very, very slight. You can also get a 8.75" ring gear for the Dana 44. When it really comes down to it the strength difference between the 8.5" and 8.9" ring gear are not going to be apparent until you are well into the 9's.
Where the Dana 44 is weaker is the case design. In general they have a lot more flex in them. The case will actually twist on hard launches and crack. The cast iron ones will even do it, and that is assuming you can find one of those easily. The aluminum ones will flex even worse (most all semi-modern Vettes and all Vipers have aluminum cases). Still this isn't a problem until you get in the high 800s in RWTQ on a heavy car. There is also a weak casting where the ring gear attaches to the housing, I have seen this break before, but was on a way more powerful car than any of these will be.
The Ford's biggest weakness isn't the case or gears, it is the differential itself. Most are 28 spline and will simply break axle shafts or spider gears. Those can easily be upgraded to 31 or 33 spline and there shouldn't be a problem until big power.
So in the end, without getting technical, the ford 8.8 axle is a better, stronger design you just need to get rid of the stock diff. Though the difference is very very minor. Then, it also has the availability advantage. I could go a junkyard today and pull 3-4 aluminum version and 10+ iron versions for $25. I probably couldn't even find a dana 44 for under $6-700.
silverlegacy is offline   Reply With Quote
The Following User Says Thank You to silverlegacy For This Useful Post:
EZWood (03-20-2013)
Old 03-20-2013, 06:56 PM   #53
Wes B.
Automotive Enthusiast
Wes B.'s Avatar
Totally pumped about this! Ford 8.8 diffs (including the IRS ones) are fantastic.
Wes B. is offline   Reply With Quote
Old 03-20-2013, 07:00 PM   #54
bpracer
Drives: Asphalt FR-S
I would think this kit will now make the transmission the weak link in the driveline so the rest of the discussion is a bit academic.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 03-20-2013, 07:01 PM   #55
Wes B.
Wes B.'s Avatar
But hasn't the transmission been shown to withhold somewhere around 450hp under forced induction?
Old 03-20-2013, 07:34 PM   #56
Tansey86
Tansey86's Avatar
Just because a piece of the car has withstood 450hp for X amount of time doesn't mean its reliable.
The Following 2 Users Say Thank You to Tansey86 For This Useful Post:
civicdrivr (04-06-2013), Dustin (03-21-2013)
Video and short review on the Cusco Engine Mounts and Rear Diff Brace RallySport Direct Engine, Exhaust, Transmission 24 07-23-2018 03:43 AM
Rear diff service JoeBoxer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-06-2012 10:23 PM
T1R Rear Diff colars ! AJ PwR Engine, Exhaust, Transmission 0 10-09-2012 10:00 PM
Cusco Rear Diff. Jewelry Blaaaack-BRZ Engine, Exhaust, Transmission 24 05-12-2012 03:28 PM
