Old 03-18-2013, 03:29 PM   #11397
kanundrum
Drives: 2013 Whiteout FR-S
http://imgur.com/8L6BwYG
kanundrum is offline
Old 03-18-2013, 03:31 PM   #11398
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
is the Oh lawd a good or bad thing lol
Good....very very good.
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline
The Following User Says Thank You to 6-Shift For This Useful Post:
kanundrum (03-18-2013)
Old 03-18-2013, 03:31 PM   #11399
kanundrum
The Following 3 Users Say Thank You to kanundrum For This Useful Post:
6-Shift (03-18-2013), Giccin (03-18-2013), Shagaliscious (03-18-2013)
Old 03-18-2013, 03:32 PM   #11400
6-Shift
Señor Member
6-Shift's Avatar
BACON STRIPS AND BACON STRIPS AND MORE BACON STRIPS. AND SOME GAY BACON JUST FOR GOOD MEASURE. WHAT YOU KNOW ABOUT HEART ATTACKS HATER?
6-Shift is offline
Old 03-18-2013, 05:01 PM   #11401
Porsche
Drives: 2013 BRZ Ltd. MT
Biggest con of AWD is the tires. One for all, all for me. If one blow, gotta replace other 3 too. Also extra parts to maintain than FWD (like CV axle, rear diff, hub bearings, & so con).
One must replace all four tires at once, despite only one tire being damaged beyond repair?
I’ve considered the AWD Subarus, but this is new to me. I don’t like the sound of that.
Is the AWD system so sensitive to minor differences in tread depth and, thus, rolling circumference?
Can you explain, please?
Porsche is offline
Old 03-18-2013, 05:06 PM   #11402
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
TBH, I don't have exact explanation for this. Maybe it's an "old saying" (like oil change every 3k)... but it's always been like that
ichitaka05 is offline
Old 03-18-2013, 05:14 PM   #11403
Porsche
This is new to me.
If this is because the diameter of a new full-tread depth tire differs enough to cause a problem, then there's a simple solution.
Take the new tire to a shop that can true tires concentrically and have them shave the tire to equal the tread depth of the other three tires.
Many racing classes employ street tires. Those tires are typically shaved to 3/32" tread depth before use. Just about "worn out," in other words. Tire shaving is commonplace in performance circles.
If anyone else can confirm that there is a problem with this, or explain why one must replace all four tires when only one is damaged irreparably, I'd appreciate it. If this is a real problem, then it's a real deterrent to me and may cause me to dismiss AWD in the future.
Porsche is offline
Old 03-18-2013, 05:20 PM   #11404
Porsche
Originally Posted by Allch Chcar View Post
Well, I finally gave up on the Mazda3.
Sorry to hear that. May I ask why? Was the financing too big of a hurdle?
How much were you putting down, and how much was the selling price? If one has enough down, I'd think the car itself would serve as collateral; the equity you have in it should cover the lender's costs should you default on the loan and they then repossess the car.
Porsche is offline
Old 03-18-2013, 05:21 PM   #11405
Porsche
Originally Posted by Snoopyalien24 View Post
Are you kidding me? That is obviously a great deal but I am poor as heck lol. I can't afford a $5000 beat up NA miata lol
Oh college, so swell.
Ah, you're in college then?
Porsche is offline
Old 03-18-2013, 05:24 PM   #11406
Giccin
Giccin's Avatar
If it's for camping so forest stuff then I would recommend keep it in NA (3 or Impreza). It's cheaper & better mpg. Not worth having that snail under the hood.
I'm power hungry right now. Lol :P
I don't want NA once I have the money for something more powerful. Both somewhat fit my needs right now. The tire thing though... that definitely sucks. :l
Differences between the WRX and STI: Wheel bearings/hubs (5x100 WRX, 5x114.3 STI), turbo chargers/placement, transmission (5spd WRX vs close ratio 6spd STI), and differentials (WRX: open front and rear with viscous or MPT center; STI: Driver-Controlled Center Differential and front/rear LSD), and finally brakes (WRX: same brakes we have; STI: 13" Brembo brakes). The $10000 has been less worth it to people since the WRX got the bump to 265hp, but you're paying for the more advanced transmission/differential setup, and those Brembo brakes.
3" turboback exhaust and a Cobb AP with a pro-tune. $2000 for a crap-ton of power.
I'm still curious if that 6th gear is really necessary. Lol
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Giccin is offline
Old 03-18-2013, 05:28 PM   #11407
ichitaka05
Site Moderator
ichitaka05's Avatar
I understand your power hunger... but after how fast that turbo will suck your money out of your wallet, you'll think twice
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
Giccin (03-18-2013), M-17 (03-19-2013)
Old 03-18-2013, 05:35 PM   #11408
OrbitalEllipses
Drives: Attitude
6th on the STI and 5th on the WRX are going to put you at the same RPMs. 1-5 on the STI is close-ratio, unlike 1-4 on the WRX.
OrbitalEllipses is offline
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
Allch Chcar (03-18-2013), Giccin (03-18-2013)
Old 03-18-2013, 06:06 PM   #11409
Calum
That Guy
Drives: 2013 asphalt FRS MT
Mazda Speed 3**** Not the regular mazdas. My bad guys! lol
Mm... The prices between the Speed 3 and Impreza WRX Limited is about 4k.
Impreza has the 20HP+ difference on the SPD 3. Spd3 has torque kick alot higher for obvious reasons.
I could enjoy the FWD but I want a powerful AWD for traveling purposes (camping and such). Yea it'll be used for "motorsport" but it'll be going into the forest with me. Lol Plus... in Rainy conditions it'll work better here. lol
The impreza also weighs about.. 80lbs/38ish kg less than the spd3.
Insurance should be both relatively the same.
MMMM... More like I can't tell the difference between the WRX and the STi. LOL.
So I'm wondering what I could add to make it have that little kick. :P
Oooo... thanksies!
I dont get the WRX. Ok, I get 90% of it, but that transmission would be considered sloppy is it was installed in a 1978 Ford diseasel. I fucking hate shifting that transmission. The EJ isn't anything to marvel at either, but neither is the force fed ranger engine.
Calum is offline
The Following User Says Thank You to Calum For This Useful Post:
Giccin (03-18-2013)
Old 03-18-2013, 06:08 PM   #11410
Porsche
This link will allow you to compare various Subaru models with competitors:
http://www.subaru.com/tools/compare-...13&trim=4-Door
Note that the price difference appears to be closer to $5,000 more for the WRX Limited vs. the MS3, making the MS3 that much more attractive. (Ignoring local discounts, which may be greater for the Mazda.)
Read what the major auto mags have to say about these two cars. I'd say they tend to favor the MS3 for value and fun, but they're both good cars.
The WRX has a 2 hp (two) advantage, 265 hp vs. 263 for the MS3. Insignificant.
The MS3 has 280 ft-lb torque vs. a "mere" 244 for the WRX. Significant.
The MS3 has more grunt; the boost comes in at 3000 rpm and the thing "will get your attention." It's fun, and quick. It has so much torque that Mazda has a limiter on it in first gear, and I think second, too. One cannot exploit all that power and torque in those gears anyway because you'll just spin the front wheels.
You'll learn to respect the throttle in the wet.
I don't understand. Could you explain, please?
Perhaps, but I decided for our purposes that AWD would be a benefit we'd rarely benefit from. I might like it, but I'm unwilling to spend an additional $4k-$5k for it. YMMV, of course.
Forty pounds difference according to the Subaru website, I believe.
The MS3 is quicker.
One may be able to find a much greater discount on the Mazda than on the Subaru. That was the case here, recently. Your area may be different.
Insurance may be equally TOO HIGH. Be certain to confirm the cost before buying the car, since it might be more than is worthwhile on these cars, especially if you're young and just starting out. You face many expenses as you get your start in life. This would be a particular concern were you to opt for the STi.
You cannot tell the difference from behind the wheel?
In that case, that extra 40 hp is hardly worth the $10,000+ premium on the STi. There are a few other improvements as well, as noted in another post.
The STi looks attractive, but many auto mag reviewers question whether it's worth the hefty premium for the STi vs. the WRX, never mind the MS3, just as I do.
The Mazdaspeed 3 is a real bargain.
Your money, of course, but I would't do that. The costs and risks outweigh the benefits. These cars are plenty quick enough for most anyone, especially a "beginner."
I'd recommend spending the money upgrading the driver. Go to a racing school up at Laguna Seca or Sears Point (or whatever it's called these days.)
Porsche is offline
The Following User Says Thank You to Porsche For This Useful Post:
