Old 03-17-2013, 07:10 PM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
going forced induction
I plan on going with forced induction soon (most likely supercharged) so my question is if i should go with a header or wait for the forced induction kit and go with the manifold that comes with the kit? I already have a test pipe and catback. Sorry if this question is elementary. Thanks for the input guys!
ft86me is offline   Reply With Quote
Old 03-17-2013, 07:16 PM   #2
wbradley
Sarcastic SOB
wbradley's Avatar
If you're going turbo you will get a header with it. At least with the AVO you do. Don't know whether you would want to keep the stock catted unit with any other kit.
With SC, do whatever you want to open up the engine.
Old 03-17-2013, 07:21 PM   #3
Noob4Life
86 Noob
Drives: Firestorm FR-S
Yeah a SC just changes the intake manifold, so you're free to mod your exhaust just like you would NA. If the SC bolts up to the OEM intake (such as innovatives) you can get an upgraded intake as well.
If you go turbo I wouldn't buy anything because you'll get an exhaust manifold for the turbo and an intake. You'll also want a full 3" exhaust.
Noob4Life is offline   Reply With Quote
Old 03-17-2013, 07:22 PM   #4
ft86me
ft86me's Avatar
Drives: 2013 FRS
Thank you for the awesome input. exactly what i needed to know.
Old 03-17-2013, 07:24 PM   #5
ft86me
ft86me's Avatar
Drives: 2013 FRS
well since i have already a test pipe and catback, i'm assuming i should go with a sc or that stuff is a waste. the piping now is 2.5. well i could go with the turb but then i would be restricting the flow quite a bit.
Old 03-17-2013, 07:25 PM   #6
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Most complete turbo kits will have a header. But you can get gains if you get a header with your SC.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 03-17-2013, 07:26 PM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
I thought the exhaust ports are 2.5" where the header bolts on, so widening beyond the narrowest point is ineffectual on back pressure.
Old 03-17-2013, 07:32 PM   #8
Vukodlac
Vukodlac's Avatar
Drives: Asphalt FR-S
Wanting to do the same in the futurr, waiting for header.
-2013 Scion FR-S-
K&N drop in.
Motiv overpipe, hfc. Perrin unresonated. Stage 1 NA Tune ( Thanks Drift Office )
Vukodlac is offline   Reply With Quote
Old 03-17-2013, 07:57 PM   #9
ft86me
ft86me's Avatar
Drives: 2013 FRS
vortech supercharger looks very appealing. apparently some good gains so perrin is stating. i wonder if john @Visconti will be able to do something with this.
Old 03-17-2013, 09:25 PM   #10
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
He has a vortech kit listed in his signature, right above the banner. There are conflicts between Perrin's claims for power and everyone else's claims on power though, so might want to see how it all sorts out before taking action.
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 03-17-2013, 09:30 PM   #11
Noob4Life
86 Noob
I ran a small KO3s on my GLI and ran a full 3" exhaust. You can run a 2.5" on a small turbo just fine but a lot of people will choose just to run a straight 3" in case they ever decide to upgrade, you want as little back pressure as possible after the turbo anyways so it doesn't do any harm to run that big. If you already have a 2.5" exhaust you can use it on your turbo build.
I just checked and full blowns kit comes with a 3" dp so you'd need to make a reducer to run it with a 2.5" system and it wont be as free flowing.
Old 03-17-2013, 10:16 PM   #12
Hawaiian
That guy
Hawaiian's Avatar
The P&L, Avo and accelerated kits all run 2.5 exhaust just fine i'm pretty sure full blown is the only 3" but they use the same basic kit parts for the base and premium kits. It's all about designed upgradeability.
That's also why P&L put the vband on their header. It allows you to upgrade to their turbo without you having to buy a new one.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 03-17-2013, 10:24 PM   #13
Noob4Life
86 Noob
I think the full blown makes more power than avo and p&l too I could be wrong though. I know when I go fi itll be a fullblown stage 1 with the upgraded turbo so I wont plan on keeping any 2.5" exhaust parts I buy.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Old 03-18-2013, 06:12 PM   #14
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Just food for thought.
Accelerated's kit (EDIT: also Ptuning's kit) retains the stock exhaust manifold.
So any aftermarket header should work with that kit, if you choose Turbo.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 03:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 07:17 AM
6AT (+) Forced Induction RYU Forced Induction 18 09-09-2012 11:14 PM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 07:50 PM
Will you make your BRZ/FR-S Forced Induction? koyv90 Scion FR-S / Toyota 86 GT86 General Forum 12 12-04-2011 09:31 PM
