Old 12-26-2012, 12:35 AM   #85
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by civicdrivr View Post
Maybe saying "this kit requires modification to work" wasn't the correct thing to say. I was a bit confused with your picture as it's the back of a stock headlight, so by modification, I meant that you need to take the headlamp apart.
The two rubber boots/caps should have been included with your kit.
Ok, this answers my question. I do not have those. I took my headlight apart and installed the projectors, but couldn't find how to attach everything behind the headlight because I seem to be missing that, so now I'm without low beams. I have to call TRS and have them mail me the boots if that's the case.
raul is offline   Reply With Quote
Old 12-26-2012, 02:00 PM   #86
raul
Lap time enthusiast
raul's Avatar
Ok, TRS is sending me the rubber cap. I knew something was missing! :P
Old 12-26-2012, 03:00 PM   #87
ohbebe80
That's unpossible!
ohbebe80's Avatar
Drives: 2013 Scion FR-S, 6 MT, Asphalt
I just installed, and at the very end realized that my kit was missing the rubber boot too! Their shipping them today. Too bad it was the very last step. I've had my car in pieces for several days now. Between celebrating the holidays and cutting up the old halogen projector to make a new custom drl housing, it's taken me forever. Always seems to be the case when I take on a project!
ohbebe80 is offline   Reply With Quote
Old 12-28-2012, 03:02 AM   #88
ohbebe80
That's unpossible!
ohbebe80's Avatar
THANKS!
Thanks for the great DIY!
Old 12-28-2012, 09:54 AM   #89
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Please explain the high beams
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 12-28-2012, 02:45 PM   #90
Aznek
Drives: 2013 White Scion FRS
That looks incredible.
Aznek is offline   Reply With Quote
Old 12-30-2012, 06:05 PM   #91
raul
Lap time enthusiast
raul's Avatar
Finally! Mad props and millions of thanks to @civicdrivr for his assistance today! Found out TRS sent me some extra wiring for the bulb that was confusing me! It's all good now!
Old 12-30-2012, 06:48 PM   #92
raul
Lap time enthusiast
raul's Avatar
To help out, I took some pictures during the install to supplement the DIY.
They show the orientation of the bulb and spring, grommets and some wiring tips.
Old 12-30-2012, 09:15 PM   #93
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I'll add those pics to the main post once in back on my computer, if you're cool with that.
Sent via telepathy
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 12-31-2012, 09:39 AM   #94
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
@raul - Looks like the passenger side beam can come up just a bit to be in line with the driver side.
Parting out HERE
Old 12-31-2012, 02:24 PM   #95
raul
Lap time enthusiast
raul's Avatar
Sent via telepathy
That's why I took them in the first place. Feel free to resize them as you see fit and such. Glad to help others.
Old 01-04-2013, 10:39 PM   #96
raul
Lap time enthusiast
raul's Avatar
Got em aligned.
Old 01-05-2013, 01:00 AM   #97
ohbebe80
That's unpossible!
ohbebe80's Avatar
Old 03-17-2013, 12:21 PM   #98
thorlius
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
Whoever's done this, can you answer what this extra stuff is that came in each projector box? Or the nut behind the projector lamp mounting bracket (which just doesn't seem to serve any purpose)? Nobody has mentioned any of this in any guides I've seen.
The top four items I know what to do with. The screws and other things seem useless, but then why would they be included?
Edit: Also, should I have gotten 4 bulbs, or just 2? There are 4 bulb holes total, and I only got 2 bulbs. I'm assuming I use the OEM bulbs for the inside lights (high beams/DRLs? I don't even really know what the inside ones are for...), but then they won't match the other headlights.
thorlius is offline   Reply With Quote
Morimoto Retro-Quik Xenon Retrofit System for FR-S Xenocide117 Cosmetic Modification (Interior/Exterior/Lighting) 63 07-18-2014 07:37 PM
The Retrofit Source Bi-Xenon FR-S Retro-Quik Conversion Andrew @ TRS Exterior Parts - The Rest 84 07-23-2012 09:43 PM
OEM Fog Light install! ON and working! 86design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 07-04-2012 07:11 PM
How to install Homelink mirror? Grimlock Electronics | Audio | NAV | Infotainment 10 06-10-2012 06:07 PM
Five axis limited retro Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 28 05-18-2012 03:16 PM
