Old 03-15-2013, 12:09 PM   #561
b$m1th91
b$m1th91's Avatar
Drives: 2013 Asphalt Scion FR-S
Really? How come?
Current Mods- [Fog lights, Takeda CA Intake, LED swaps(Dome, Reverse, Trunk)..., Painted Calipers Red, Beatsonic Shark Fin Antenna] Future Mods- Takeda Exhaust, Perrin Crank Pulley, Reverse Fog light, Rota torque wheels, Custom Sound System:happy0180:
b$m1th91 is offline   Reply With Quote
Old 03-15-2013, 12:15 PM   #562
calis5nest
calis5nest's Avatar
Drives: scion frs firestorm
Originally Posted by b$m1th91 View Post
Really? How come?
The button switch was design to stick out a bit if you make a whole big enough for the button to flush the button wont be supported on the panel
-Alan
calis5nest is offline   Reply With Quote
The Following User Says Thank You to calis5nest For This Useful Post:
b$m1th91 (03-15-2013)
Old 03-15-2013, 03:23 PM   #563
wootwoot
Drives: FRS
Anyone know when Nigel will have the bezels in stock? It has said "pre-order" for several weeks now...
Old 03-15-2013, 04:28 PM   #564
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
I ordered mine around a month or so ago and he told me a few days ago they're coming in March 20. Hopefully he'll get a good amount in
abutterman is offline   Reply With Quote
Old 03-16-2013, 02:30 PM   #565
Willsonk
Drives: Scion FR-S Asphalt AT & XB
Just got my order in from Subaru. 2 glass fog lights, BRZ stalk which is stamped toyota on it. Now just waiting for Nigel for wiring harness and bezels. So ready to install this!!!!
Willsonk is offline   Reply With Quote
Old 03-16-2013, 02:51 PM   #566
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
how much were ur fog lamps? i assume u ordered from the dealer from what it sounds?
lbroskee is offline   Reply With Quote
Old 03-16-2013, 03:07 PM   #567
Willsonk
$42 for each light (2) And it comes with bulbs.
$60 stalk
Total order shipped $164
http://www.subarupartsforyou.com/cp_...p?partid=19073
Old 03-17-2013, 10:26 AM   #568
CoRi J
Xenogear
Drives: 2013 Scion FR-S, Ultramarine
Thanks to the OP, thread and DIY I wired mine up..I didn't do the switch I just wired them to the side marker.
I did nokya yellows with mine
Sent from my SGH-T889 using Tapatalk 2
CoRi J is offline   Reply With Quote
Old 03-17-2013, 10:29 AM   #569
lbroskee
lbroskee's Avatar
Attachment 30983
Attachment 30984
so these bulbs will give the exact same effect as tinting the lens yellow?
Old 03-17-2013, 10:31 AM   #570
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
well, he has them on in that second picture. you really won't see as much yellow on the fog light when it's off as you would if you tinted it. although you'd see the bulb color reflecting in there so maybe you would, but probably not as much.
mezdup is offline   Reply With Quote
The Following User Says Thank You to mezdup For This Useful Post:
lbroskee (03-17-2013)
Old 03-17-2013, 04:29 PM   #571
mdf4uk
Drives: 13 Firestorm FRS MT & 09 DGM WRX
Originally Posted by 86 FRS View Post
if anyone interested to tap the trigger switch to the ignition key so u can turn on the fogs without turning on to parking lights, let me know so I can post up a photo where to tap it in, looking for it is kinda bitch.
Note: tapping it to ignition key wont drain any battery unless u turn the ignition key
Yes i would like to know a wire i can jump onto (that only works with the key in the "on position"so i can connect my red wire for the on/off switch for the fogs as i am not using the stalk and do not care if the light on dash comes on with the fogs. Thanks in advance to anyone that can help.
mdf4uk is offline   Reply With Quote
Old 03-17-2013, 05:10 PM   #572
mdf4uk
Can anyone help?
Old 03-17-2013, 10:31 PM   #573
calis5nest
calis5nest's Avatar
Where did you guys tap the positive switch wire to?
-Alan
Old 03-18-2013, 01:00 AM   #574
outlaw121
outlaw121's Avatar
Drives: 2013 scion frs blue
I need help with where to wire the switch power side inside the car
Sent from my HTC VLE_U using Tapatalk 2
outlaw121 is offline   Reply With Quote
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
FINALLY - Got my FR-S SkitterSkotter Scion FR-S / Toyota 86 GT86 General Forum 28 08-03-2012 05:16 PM
FINALLY GOT IT! Ayaz2589 NY / NJ / CT / PA 8 07-28-2012 02:52 AM
Finally got it!! percyng CANADA 21 06-17-2012 01:50 AM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 07:29 PM
