Old 03-15-2013, 01:38 AM   #29
Margovincent_22x
Margovincent_22x's Avatar
Drives: Lightning Red BRZ MT Limited
Originally Posted by OmegaKnight View Post
Yea, you will be fine with 235's and coilovers. The only concern was with stock struts.
I just changed my mind and I'm getting TE37SL Black Edition 18x8.5+35 / 18x9.5+40 staggard set-up. They said its the perfect fit, I do hope so.
Margovincent_22x is offline   Reply With Quote
Old 03-15-2013, 01:55 AM   #30
WendyCity86
Drives: Asphalt
Like your set up. I am looking to attend FR-S and BRZ events,if you hear of any let me know and I will do the same.
Thanks
"burn rubber not your soul"
WendyCity86 is offline   Reply With Quote
Old 03-15-2013, 09:25 PM   #31
OmegaKnight
Nice, I would have probably done the same if I were buying new.
Thanks
Thanks, I'll probably be at the Touge Factory meet on May 5th.
http://www.ft86club.com/forums/showthread.php?t=30021
OmegaKnight is offline   Reply With Quote
Old 03-16-2013, 01:13 AM   #32
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
What rubber do you plan on running? Nice set-up. Who is "they" that calls this the perfect combo, not that I'm disagreeing?
Thanks for sharing.
- When men make plans the gods laugh.
Brzzee is offline   Reply With Quote
Old 03-16-2013, 11:42 AM   #33
OmegaKnight
That staggered setup was made specifically for this platform by being flush all around and having plenty of clearance on the inside as well. This 18x9 +45 was meant for WRX's but is probably better performance wise by keeping a square setup.
Old 05-17-2013, 06:51 PM   #34
alexromero.dc
Drives: Toyota GT86
How do you feel the car with those wheels? It is slowly or is the same?
alexromero.dc is offline   Reply With Quote
Old 05-18-2013, 10:32 AM   #35
OmegaKnight
It actually felt faster because they're lighter than stock lol.
Old 05-19-2013, 09:54 PM   #36
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
I want say that your BRZ looks great! Sorry for thread jacking but would some 17x9 +45's have the same clearance with stock suspension as these 18x9 +45's or would there be a little more space for a wider tire? Thanks.
TRD_07 is offline   Reply With Quote
Old 05-19-2013, 10:56 PM   #37
OmegaKnight
Thanks, I would say it would be about the same, you might get away with a 235 or even 245 depending on what tires since some run wider than others, but that would be pushing it without testing it first hand.
Old 05-20-2013, 07:38 PM   #38
TRD_07
TRD_07's Avatar
Thanks, I am thinking about playing it safe and get some 5mm spacers so that I can run a 245/40 and then the offset would be +40. Is there a detriment to the wheels or suspension by using spacers? I've noticed that alot of people don't like to use them.
Old 05-21-2013, 01:58 PM   #39
OmegaKnight
Should be alright using a good quality spacer. People don't like them because it is just something extra that could possiby go wrong. I'm thinking of using a small spacer in the rear so it can sit a bit more flush all around.
I think a few people run the 17x9 +45 Enkei rpf1s maybe you can search what setups they use.
Old 06-29-2013, 02:36 AM   #40
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I purchased a set of TE37SL Black Edition 18x9s ... Now am considering the rubber choices while I wait for them to arrive. I'm on stock suspension currently, and was thinking about going with 245/35 ... what are your thoughts on clearance?
TrogDor the Burninator is offline   Reply With Quote
Old 07-01-2013, 09:46 PM   #41
OmegaKnight
Sorry just saw this. I didn't have these wheels long with the stock struts but after looking around the forums I will have to say with 245's you will have to run a small spacer for clearance.
Old 07-10-2013, 10:03 AM   #42
tinma
Drives: '13 BRZ
ahh love these wheels...but on stock suspension im just worried about rubbing
tinma is offline   Reply With Quote
Volk Racing TE37 thread quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 364 04-01-2024 08:43 AM
Wheel Directory: Volk TE37 17x8.0 +38 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 08-11-2016 04:49 AM
Wheel Directory: Volk Racing TE37 17x8.0 +44 Tanuki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 60 09-19-2013 10:28 PM
Volk Racing G12 alternative? DIREWOLF Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2012 10:43 AM
Volk TE37SL (Super Laps) now available in FR-S/BRZ sizing 18x8.5 and 18x9.5 5x100 Jordan Innovations Wheels and Tires 0 07-26-2012 09:12 PM
