Old 03-14-2013, 12:24 PM   #547
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
Originally Posted by nigel-jdmparts View Post
How much longer do we need?
I will talk to the factory and try to see if I can get them longer for you guys in the next shipment.
let me know if 50CM extension enough for you guys, I might able to get it for you all.
im not sure how long but, just need a extra wire to reach the left panel part.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
The Following User Says Thank You to 86 FRS For This Useful Post:
nigel-jdmparts (03-15-2013)
Old 03-14-2013, 07:47 PM   #548
calis5nest
calis5nest's Avatar
Drives: scion frs firestorm
Comparing the new switch from nigel to the stock trunk button
-Alan
calis5nest is offline   Reply With Quote
The Following 3 Users Say Thank You to calis5nest For This Useful Post:
mezdup (03-14-2013), nigel-jdmparts (03-15-2013), OmarGC (03-14-2013)
Old 03-14-2013, 07:56 PM   #549
Cjs_
Cjs_'s Avatar
finally got my harness today from @nigel-jdmparts.!
Cjs_ is offline   Reply With Quote
The Following User Says Thank You to Cjs_ For This Useful Post:
Old 03-14-2013, 08:05 PM   #550
b$m1th91
b$m1th91's Avatar
Drives: 2013 Asphalt Scion FR-S
Looks much better than the old bigger switch.:happy0180:
Current Mods- [Fog lights, Takeda CA Intake, LED swaps(Dome, Reverse, Trunk)..., Painted Calipers Red, Beatsonic Shark Fin Antenna] Future Mods- Takeda Exhaust, Perrin Crank Pulley, Reverse Fog light, Rota torque wheels, Custom Sound System:happy0180:
b$m1th91 is offline   Reply With Quote
The Following User Says Thank You to b$m1th91 For This Useful Post:
Old 03-14-2013, 08:13 PM   #551
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
if anyone interested to tap the trigger switch to the ignition key so u can turn on the fogs without turning on to parking lights, let me know so I can post up a photo where to tap it in, looking for it is kinda bitch.
Note: tapping it to ignition key wont drain any battery unless u turn the ignition key
The Following 2 Users Say Thank You to 86 FRS For This Useful Post:
calis5nest (03-16-2013), nigel-jdmparts (03-15-2013)
Old 03-14-2013, 08:35 PM   #552
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
Think that might fit in the space where the usb/aux is with a little work?
abutterman is offline   Reply With Quote
Old 03-14-2013, 08:48 PM   #553
calis5nest
calis5nest's Avatar
interested in pics. Is this where you tap it to?
-Alan
Old 03-14-2013, 08:52 PM   #554
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
yes. atleast u can turn on the fogs anytime without turning on into parking lights or headlights on. u can do DRL + fogs, and it looks good lol
calis5nest (03-14-2013)
Old 03-14-2013, 08:54 PM   #555
calis5nest
calis5nest's Avatar
Looks like a perfect fit or a really tight fit
-Alan
Old 03-14-2013, 09:26 PM   #556
abutterman
abutterman's Avatar
that would be awesome. i know the slot behind the aux/usb has tabs that stick out which i assume would probably have to be filed down a bit if anything. My stuff should be shipping on the 20th or so according to Nigel (waiting on the bezels to come in) and i'll see what i can do with it.
Old 03-14-2013, 11:19 PM   #557
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
does the new fog switch actually light up when on?
lbroskee is offline   Reply With Quote
Old 03-15-2013, 12:15 AM   #558
nigel-jdmparts
nigel-jdmparts's Avatar
Drives: 86
Ok! Will get a 50cm extension one for all of you guys.
nigel-jdmparts is offline   Reply With Quote
The Following 2 Users Say Thank You to nigel-jdmparts For This Useful Post:
JD213 (03-15-2013), mezdup (03-15-2013)
Old 03-15-2013, 12:03 PM   #559
b$m1th91
b$m1th91's Avatar
Can't the button sink back further than that so it is flush with the panel?
Old 03-15-2013, 12:07 PM   #560
calis5nest
calis5nest's Avatar
Nope it cant
-Alan
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
FINALLY - Got my FR-S SkitterSkotter Scion FR-S / Toyota 86 GT86 General Forum 28 08-03-2012 05:16 PM
FINALLY GOT IT! Ayaz2589 NY / NJ / CT / PA 8 07-28-2012 02:52 AM
Finally got it!! percyng CANADA 21 06-17-2012 01:50 AM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 07:29 PM
