| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: FR-S MT
Torque Wrench options
Okay, I have only ever changed tires with the wrench they supply with the jack. Is it possible to get a battery powered wrench that I can dial-in the torque specs on? If so, what is a good brand and what should I expect to pay?
#2 |
head of infinite swagger
Drives: 2013 FR-S 6MT
I've seen plug in electric impact guns that allow you to set the torque rating (I bought one for my dad actually), but not cordless. I'm sure someone must make one.
Other option would be "torque sticks" and any cordless impact gun, but they're pricey. Personally I prefer to do it manually with a breaker bar, a socket and a real torque wrench. You don't need power to change your wheels quickly or easily. I have a cordless impact gun that I don't even use.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
#3 | |
i'm sorry, what?
Drives: Canada
You will torque your nuts, in a star shaped pattern, by hand or by a drill but not to the point of tightness, you want to seat the wheel with as equal distribution of force as possible. I myself do this by hand. Then you will use a standard arm-powered torque wrench to dial in to the correct settings. Happy driving.
#4 |
Drives: 2013 FR-S whiteout
What 7th gear said - learn what the proper amount of torque feels like by hand. It's not rocket surgery.
If I saw someone using a torque wrench on their lug nuts, I would kill their family in front of them and make them watch. If I was someone using an electric torque wrench for their lug nuts, I would do the same thing + frame them for the murders. |
#5 | |
i'm sorry, what?
Drives: Canada
arm-powered torque wrench meaning the clicking variety that you turn with.. your hands! ![]() you still need a tool that is designed to measure torque, just not in the cordless variety because the variance in power output is too great a variable when you want to be accurate if you're torquing your nuts "by feel" then i'm sorry to inform you you're part of the minority here and your to-murder list is gonna be pretty long.
#6 | |
Drives: '13 GBS Subaru BRZ
One thing to keep in mind with these is that you should still be tightening lugnuts progressivly in a star pattern like you always would. Even with a torque limiter you can warp rotors and cause damage when using an impact wrench.
#7 |
i'm sorry, what?
Drives: Canada
if you use torque sticks you MUST use them on a tool that has a consistent power delivery.
#8 |
Sorry I misunderstood. Seriously people actually use torque wrenches to tighten their lug nuts? This is news to me. I've never had any stud problems nor loose wheels in my ~21 years of doing my own maintenance/repairs. What's the matter with kids today?
#9 | |
i'm sorry, what?
Drives: Canada
the science behind fastners is rather specific, each material has certain tolerances which have allowed you to ignore them for the last 21 years but it doesn't magically make them disappear or give you an excuse to "murder" people who choose to use the correct tools for the job. just because you've been doing something wrong for a long time doesnt make it right.
#10 | |
Really should be using a torque wrench. I'll look into getting one. Check you later. K, bye. |
#11 | |
It's a hell of a lot quicker, but you've got to have the right tools, and use them correctly.
#12 |
i'm sorry, what?
Drives: Canada
Also be aware of the following practices that I have heard of experienced.
Scenario A 1. Person uses breaker bar/socket wrench to tighten a bolt or nut, really tight 2. Then that person sets the torque wrench to the desired amount and goes to tighten the nut 3. Torque wrench “clicks” and person assumes everything is to spec WRONG, person over tightened the nut/bolt initially and the only confirmation his torque wrench is giving him is that at the very least he reached his desired torque setting but it may be a little bit higher or way higher without a way to know this. Scenario B A scrutineer, marshal, race official wants to check your torque setting, so they use their torque wrench to apply further pressure to your lugs to “test it”, inadvertently tightening it beyond the required spec, not to mention you never knowing whether their wrench is calibrated. So don’t let anyone ever check your torque settings by torqueing it more. If they want to see the correct torque then you need to release the tension and re-torque them using your tools.
#13 |
NASA SpecE30 Racer
Torque sticks are only used at shops to approximate the torque while the vehicle is off the ground. The lugs are then torqued with a REAL torque wrench afterwards. That is the way I did every vehicle when I worked at a Walmart TLE. Buy a quality torque wrench and use it once the vehicle is on the ground and under its own weight. Ideally you then drive 5o to 100 miles and torque them again.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#14 |
Drives: FR-S MT
THanks... lots of good advice here, and some weirdly violent responses.
So, I only want to make a reasonable investment, what do I need? 1) Low profile floor jack 2) Lug nut wrench or socket wrench? 3) Torque wrench: beam or click type? |
| Torque Wrench Needed For Exhaust Installs? | FR-S Matt | Engine, Exhaust, Transmission | 13 | 02-13-2013 01:40 PM |
| Torque wrench... Vendors welcome | Freeman | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 01-23-2013 05:30 AM |
| Digital Torque Wrench - Holiday Special | blmw | Wheels and Tires | 11 | 01-14-2013 05:00 PM |
| Digital Torque Wrench - Holiday Special | blmw | Brakes, Suspension, Chassis | 4 | 01-14-2013 09:30 AM |
| Which type of torque wrench do you prefer? | Hanakuso | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 07-11-2012 04:17 AM |
