Old 03-09-2013, 04:13 PM   #1
Number 6
Drives: Limited 2013 Pearl White - Manual
Quick Question when doing clutch Adjustment
When you're turning the 12mm nut to loosen the rod... do you turn the wrench towards the transmission or away from the transmission?
Number 6 is offline   Reply With Quote
Old 03-13-2013, 05:21 PM   #2
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Nobody says because you're all upside down and such when you're there. Look at the threads. When you make the bracket get closer to the firewall, you're also making the clutch go down, and vice versa.
Old 03-13-2013, 05:44 PM   #3
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
Once it is finger tight, grab the end of the clutch pedal with your fingers and you should be able to feel it move as you spin the nut. It will feel like it wants to go up or down. Have a second person watch if possible to get the height right as it is hard to tell when you are upside-down.
cmspooner is offline   Reply With Quote
Old 03-14-2013, 12:18 AM   #4
Number 6
That's not true... whether you're upside down or right side up, you could
still say which direction the bottom of the wrench goes... towards the Transmission or away from the transmission.
DIY - Easy clutch grab adjustment (~10 mins) Koji_Online DIY (Do-It-Yourself) Guides 745 11-09-2022 01:44 AM
Quick Question when doing Clutch Adjustment Number 6 Scion FR-S / Toyota 86 GT86 General Forum 2 03-09-2013 05:31 PM
Quick Question akuhei Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-04-2013 10:29 PM
Quick question.... be6sti Engine, Exhaust, Transmission 8 11-04-2012 10:53 PM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 06:01 PM
