Old 03-13-2013, 11:21 AM   #225
mad_sb
Drives: 2013 Asphalt FR-S
What tuning solution are you using that requires the maf?
I assume your not going ecutek since i believe those tunes are speed density. If you were going stand alone I would assume speed density as well. That leaves BRZedit (what i am using for my na tuning, and they are working on a speed density patch i hear) or unichip.
The Following User Says Thank You to mad_sb For This Useful Post:
Silverdub (03-13-2013)
Old 03-13-2013, 04:51 PM   #226
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
i was going to get vistonti but he is not coming over just yet, so i need a basemap and then be able to drive my car... i need to get back to him, if he tells me that he has a 5psi base map mafless i can get this thing running in no time!
other solutions are Treadstone performance has a maf housing, but thats too many couplers in my engine bay, or KStech has a maf flange in stainless but it says WRX 02-07 so im not sure it is going to fit
Silverdub is offline   Reply With Quote
Old 03-13-2013, 06:51 PM   #227
mad_sb
Right on,
Must respect to you for taking on a project like this!. One of these days I'll get around to buying some welding gear so I can start doing my own builds :happy0180:
Old 03-13-2013, 10:33 PM   #228
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
have you asked KStech if they can machine you an 08+ flange in stainless? I'm sure they could.
JP is offline   Reply With Quote
The Following User Says Thank You to JP For This Useful Post:
Silverdub (03-14-2013)
Old 03-14-2013, 07:41 AM   #229
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I did and they said no, not enough people asking... I am buying the treadstone complete housing kit for now, just waiting on them!
Old 03-14-2013, 07:50 AM   #230
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
I made my own when I was going to run stainless piping, I had 3" stainless bar and bored it out then parted it off. Was just a disk that I welded onto the pipe and then drilled the holes lol
jet86 is offline   Reply With Quote
The Following User Says Thank You to jet86 For This Useful Post:
Old 03-14-2013, 08:42 AM   #231
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
i was thinking of making mine but the problem was de 1.02 inch bore hole, if not it would of done it...
Old 03-14-2013, 10:03 AM   #232
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
26.3mm. I just used a small boring tool.
Old 03-14-2013, 08:16 PM   #233
wWaldo
Drives: Asphalt Frs
loving your black out! lol.. the plan was to trailer it to my buddys dyno and get Visconti to tune it, i talked with him already one the phone and then i sent him an email to confirm dates and he never got back to me... this is way i am not rushing things up anymore, simly because i dont know hen he will be able to come down or if i can get it tuned somewhere else...
i also talked to Lachute Performance, they say they can do it no problem but they asked for 2 full days of dyno tuning at 120$ an hour because i would be the first frs turbo they do... that doesnt make me feel safe and seems pricey as well.. i will see, i have time to think about it...
If you get Visconti to come down. I wouldn't mind a tune, for me and my buddy so we can make his trip worth it at least!
wWaldo is offline   Reply With Quote
Old 03-14-2013, 09:53 PM   #234
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
As of now i am buyinv his basemap and i ll see from there. Is it needs adjustments but runs good i might drive down there and pick up parts stateside plus ball game somewhere, redsox perhaps
Old 03-15-2013, 05:27 PM   #235
Turbowned
Turbowned's Avatar
Good choice :happy0180:
The Following User Says Thank You to Turbowned For This Useful Post:
Silverdub (03-15-2013)
Old 03-22-2013, 07:23 PM   #236
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Just waiting on parts to showup from treadstone to finish this up
Old 03-23-2013, 07:37 PM   #237
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I finally welded my BOV adapter and installed it! I also built my turbo inlet pipe and ordered my K&N filter. I will be welding the inlet this week and once the filter shows up i can put the bumper back on for good!
Old 03-27-2013, 07:45 PM   #238
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Not much to brag about but i got my air filter and wideband o2 plug. As soon as i get my maf housing from treadstone i can drive!
Silverdub firestorm 6mt Silverdub Member's Car Journals 26 07-23-2012 06:13 PM
86-X project phenom86 Scion FR-S / Toyota 86 GT86 General Forum 1 07-11-2012 03:57 PM
Project continue 4agze Other Vehicles & General Automotive Discussions 37 11-15-2011 03:55 AM
New Project x2 S2KtoFT86 Other Vehicles & General Automotive Discussions 9 10-25-2009 12:17 PM
