Old 03-12-2013, 08:15 PM   #169
Ad8707
Ad8707's Avatar
Drives: 2013 frs whiteout
Those rims look good on the firestorm...maybe i shouldve bought that one..A drop would bring it in but it would depend on the tires to make it flush..right?
225/40up front (less poke) and 245/35 rear..anything wrong with this set up I plan to do on mine ...should I just go square with 225/40 ..H&r super sports springs is my choice for the drop..Would I need adjustable lower control arms in the rear cuz of the 245 or the natural camber would be ok..will be doing an alignment when springs settles...Any help on this would be appreciated
Ad8707 is offline   Reply With Quote
Old 03-13-2013, 08:26 AM   #170
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
I'll test fit the rears tonight but I think we have more clearance there without going to control arms or bushings.
The front are the real test, so I'll quickly fit the front rim again to see how much play I have if I install a crash bolt.
Will post some more pics later tonight.
Slick is offline   Reply With Quote
Old 03-21-2013, 03:04 PM   #171
Slick
Slick's Avatar
I test-fitted the wheels again, this time both front and rear and wanted to account for the change in camber with a crash (camber) bolt.
Good news is that the rears fit quite nicely at stock height, so with lowering springs it should bring the top of the wheel/tire in a bit more. I'll be running 245/35ZR18 all around with these wheels.
Fronts are always a bit tighter, but the crash bolt makes a big difference in the camber needed to make it fit. I didn't really think it would amount to enough camber to allow the wheel to pull in enough but it does.
The before pics are on my post higher on this page, see below for the after pics with the crash bolt in place.
I'll post some more pics in a few weeks once everything is mounted and springs (Eibach ProKit) are installed also.
Old 03-26-2013, 11:30 PM   #172
Slick
Slick's Avatar
Installed on the car (well for an hour).
Still waiting on springs to be installed and more importantly spring to come!!!
18x9 +35 on Continental Extreme Contact DW 245/35R18.
Wheel/tire combo weight came in at 40.6lbs vs 41.2 for stockers.
Tire shop was impressed at the weight of these wheels and mentioned they balanced very nicely.
Quite a bit of poke for now but will be lowered on ProKit springs and also crash bolts installed, so it should tuck in, just.
Pics (pardon the dirty car):
The Following 2 Users Say Thank You to Slick For This Useful Post:
Ad8707 (03-27-2013), hmong337 (02-08-2014)
Old 03-27-2013, 12:24 AM   #173
jedichimp
OG <FR-S'less> Member
jedichimp's Avatar
Drives: yes
wash & drop, then more photos. Looks good tho.
Flickr // SarapBuhay
merrill.joes@gmail.com
panda cheez
Old 03-27-2013, 01:28 PM   #174
Ad8707
Ad8707's Avatar
So plenty of inner clearance with an inch drop from a pro kit? I have similar set up and also waiting for springs so I didn't mount my wheels...
Old 03-27-2013, 03:33 PM   #175
Slick
Slick's Avatar
Springs are not installed yet, but should be fine.
Loads of clearance on the inside rear inside. Inside front is quite a bit tighter. Only 12mm clear of the tire, or 8mm with a crash bolt installed.
With an extra inch of drop, should have enough room.
The Following User Says Thank You to Slick For This Useful Post:
Ad8707 (03-28-2013)
Old 03-31-2013, 03:13 PM   #176
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Looks great!
NotSoJDM is offline   Reply With Quote
Old 03-31-2013, 04:14 PM   #177
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
looks very nice, good choice
Killerbee is offline   Reply With Quote
Old 04-01-2013, 05:35 PM   #178
NotSoJDM
NotSoJDM's Avatar
Anyone in the states buy from influence import? If so, how's their service? I called the number and got a Spanish cell phone carrier recording. Also real slow to reply to emails...
Old 04-18-2013, 09:56 PM   #179
Slick
Slick's Avatar
Looks much better with a drop.
Old 04-19-2013, 01:49 PM   #180
Lakers86
Lakers86's Avatar
Drives: Asphalt FRS
Anyone have trouble purchasing from influence imports? Just want to make sure before i purchase. Thanks!
Lakers86 is offline   Reply With Quote
Old 04-19-2013, 02:58 PM   #181
jedichimp
jedichimp's Avatar
Drives: yes
Better @Slick, any other plans?
panda cheez
Old 04-19-2013, 06:34 PM   #182
Slick
Slick's Avatar
Not much.
Maybe a front splitter, side sills & rear spoiler down the road.
We'll see how she does on track soon.
Fortune Auto Gen 4 500 Series Coilovers! Lisa@TrueStreetIndustries Brakes, Suspension, Chassis 29 12-05-2012 05:46 PM
***FORTUNE AUTO COILOVERS*** FT-86 SpeedFactory **EXPERTS** FT-86 SpeedFactory Brakes, Suspension, Chassis 32 09-21-2012 10:42 PM
Freed Engineering - Fortune Auto coilovers FreedE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 08-01-2012 01:45 PM
**Echelon Autosports** -- New V4 Gen Fortune Auto Coilovers NOW AVAILABLE! Echelon Autosports Brakes, Suspension, Chassis 8 07-28-2012 01:27 PM
