| FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum All photos, videos and other media related to the Scion FR-S and Toyota 86 |
#225 | ||
Site Moderator
Drives: Stuff
This is a D2R bulb (assuming the site it's hosting on allows linking): ![]() Some older Acuras, Mercedes, Nissans, etc used them. Almost everyone uses projectors now as they are far superior but reflector based HIDs absolutely exist. Quote:
As for the rest, you can run halogens as highs as you said, or bixenon (no point in the expense of second set of housings, balasts, bulbs etc to run two seperate units one for low and one for high) and for bixenon a flap moves out of the way allowing light to bounce off the bottom of the projector making it a high beam, the bulb never moves. Obviously this is different from entertainment systems, but please don't spread misinformation.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles Last edited by Dave-ROR; 11-22-2011 at 11:19 PM. |
#226 |
Site Moderator
Drives: Stuff
He didn't say always, he said usually has halogen high beams as many HID equipped cars do, although I'd guess that trend is dying in favor of bixenons but I haven't exactly bothered to count :P
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#227 | |
Drives: Lexus IS300 / Lexus IS250 AWD
![]() Tada. OEM IS300 / GS400 Headlights. |
#228 |
Hot Dog
Drives: quicker than arghx7
It's true. The '02, '03, and '04 MINI's I owned with optional HID's used D2R bulbs in a reflector housing. '05+ MINI's with HID's use projector lenses whereas the standard halogens use reflectors. My Exige has a halogen low beam with a projector beam lens, and a halogen high beam with a reflector.
FWIW, bi-xenon are catching on quickly. It's becoming cheaper to pay for the motorized shutter mechanism than a whole separate bulb, wiring connector, and reflector/lens section in the light cluster. Add to that, they can charge an obscene amount to add one or two servo's for auto-level and/or steering lights. LED's, being so flexible, can be used pretty much however you please; direct, diffused, reflected, or projected.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#229 | |
Drives: 2013 Subaru BRZ MT Limited
The D2R was offered as a replacement on my Tacoma...I forgot about that...it's use however removed all High Beam abilities unless you bought it with a motorized Bi-Xenon kit and special shroud that it mounted in. The rest of my post however was still correct...HID's cannot be restruck while hot without special expensive ballasts, and most OEM HID's are ether motorized for high or low beam effects in some way or paired with a high wattage halogen in a separate housing.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
#230 | |
Site Moderator
Drives: Stuff
![]() Automotive lighting is clearly different from your industry in the way it's applied. I wouldn't even start to say anything about your industries application as I have no experience there. And if you want evidence of them being able to reignite instantly I can go shoot a video, I have a few balasts and bulbs sitting on the shelf in the garage.
-Dave
#231 |
Site Moderator
Drives: Stuff
$15 digital balasts reignite/restrike. I have both old school balasts and some new cheap digital ones, both reignite instantly. It's a mix now on bixenon and seperate halogens. Most are starting to go towards bixenons since it's easy and cheap.
-Dave
#232 |
Site Moderator
Drives: Stuff
lol no, nice matrixing effect though. (and I don't mean the movie lol)
-Dave
#233 | |
In the entertainment business, we use 700 watt to 1500 watt lamps (sometimes even up to 10,000 watts) with 700 or less hour lifespans...each strike takes about an hour of lamp life away so usually we strike all the lamps at the beginning of the day and leave them running for 12+ hours until the show is over...replacing a $400 lamp is not fun, especially 80ft in the air over a stage.
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake Last edited by Sony; 11-22-2011 at 11:38 PM. |
#234 | |
Site Moderator
Drives: Stuff
But yes, it's bad to turn them back on quickly because of the life issue although I'm at 8 years and my old bulbs are still rocking so it's not something to stress about in the automotive application... and I even bought mine used.. so they are likely have 10 years on those bulbs.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles Last edited by Dave-ROR; 11-22-2011 at 11:56 PM. |
#235 |
Site Moderator
Drives: Stuff
I know that. Matrixing is your brain seeing things that aren't there because you've seen them elsewhere before.. faces in windows/mirrors/etc, napkin stains that look like Jesus, clouds that look like cars, etc.
-Dave
#236 |
Site Moderator
Drives: Stuff
Well I see female genitala in the same image you see that.. sooo.. :shrug: except no tubes.. or you can see madona with her legs spread and that pointy bra she had back int he day, or likely 20 other things.
As compared to yours, one of the horns is missing as is the thing in the middle sticking out of it's head, and the scale is off. In other words, you are reading way too much into this.
-Dave
#237 | |
#238 | |
Elite Padawan
![]() I really see something but not a goat. LOL
Dark
| Awesome feature film/video featuring AE86 and other cars in drifting competition | Hachiroku | Other Vehicles & General Automotive Discussions | 3 | 07-06-2013 10:21 AM |
| Production Toyota FT-86 Details and Design Previewed by Toyota Sports Vehicle Boss | ft86cbx | Scion FR-S / Toyota 86 GT86 General Forum | 541 | 11-18-2011 09:04 PM |
| New Video: Frankfurt FT-86 II Trailer! | CyberFormula | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 91 | 09-13-2011 04:19 AM |
| Gran Turismo 5 - Official Toyota FT86 Trailer [HD] | Raiden | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 12 | 08-10-2010 01:05 AM |
| Toyota FR-S : Official Name for the FT-86 Concept? | Dark | Scion FR-S / Toyota 86 GT86 General Forum | 155 | 08-04-2010 11:05 PM |
