Old 03-11-2013, 08:42 PM   #29
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
I got my wheels and tires.. got them on the car last night.. and had a nice little peak of sunlight to snap some pictures today.
NEEDS MOAR LOW.. I'll get the RCE Yellow springs installed in a couple weekends. That will help a bit. Need some tire shine as well..
eikond is offline   Reply With Quote
The Following User Says Thank You to eikond For This Useful Post:
MightyMeeple (03-22-2013)
Old 03-14-2013, 11:37 PM   #30
eikond
eikond's Avatar
I installed clear side markers today with amber bulbs.
Also put in a K&N panel filter.
I ordered a set of OEM mudguards as well. With the extra width from these wheels I want to prevent rock chips and scrapes down the doors as much as possible.
Old 03-15-2013, 07:26 AM   #31
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Looks good. Could definitely use the springs though.
kask2_6.0 is offline   Reply With Quote
Old 03-22-2013, 10:11 AM   #32
eikond
eikond's Avatar
The springs go on this Sunday.. and if time allows.. brake pads, lines, and some aero bits.
I did install my front lip last night. I think it looks nice.. definitely makes the front end a little more "angry" and aggressive.
Old 03-22-2013, 10:47 AM   #33
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
Your car looks great, and thanks for sharing the details and photos. May I ask how the lip installation went? Did you have to drill any, or is it simply blot into place?
MightyMeeple is offline   Reply With Quote
Old 03-22-2013, 11:08 AM   #34
eikond
eikond's Avatar
Lip install was a lot more time consuming that I thought it would be. You have to remove a couple of undertray panels so that you can get your hands on the inside of the bumper. You do have to drill it because you'll want to have hardware to bolt it on. It wouldn't hold up very well to all the wind you get at the front of the car with just tape.. plus you want to snug it up tight toward the front so there is no gap to the bumper. Once you get the undertrays removed and get over that fear of drilling holes in your new car.. it's a pretty easy process.
I did it myself. I used some double sided tape on the inside most edge so that i could test fit it and adjust.. Once I had it where I wanted I snugged up the tape nice and tight and the held it in place enough for me to start drilling. I started at the two points in the front on either side of the grill and then moved to center and then outside.
the worst part was being out in the garage for so long.. brr.. it was like 20* outside yesterday. I need spring!!!!
Old 03-24-2013, 04:09 PM   #35
eikond
eikond's Avatar
MOAR LOW
details to follow...
Old 03-24-2013, 04:40 PM   #36
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Throw on some pics of that lip!
Cjymiller is offline   Reply With Quote
Old 03-24-2013, 09:43 PM   #37
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Today @eikond & I installed a set of RCE Yellow's on his super clean WR Blue BRZ. Here are some pictures, starting with the "before" ride height:
RYE_6421.jpg by Ryephile, on Flickr
RYE_6417.jpg by Ryephile, on Flickr
RYE_6438.jpg by Ryephile, on Flickr
RYE_6439.jpg by Ryephile, on Flickr
RYE_6451.jpg by Ryephile, on Flickr
Here are the "after" pictures:
RYE_6457.jpg by Ryephile, on Flickr
RYE_6458.jpg by Ryephile, on Flickr
RYE_6470.jpg by Ryephile, on Flickr
RYE_6473.jpg by Ryephile, on Flickr
There are some suspension stroke measurements I'd like to share. All the ride height measurements are from axle center to the apex of the wheel arch. Note that I forgot to measure the rear motion ratio, so everything I'm mentioning stroke-wise in the rear will be wrong until it gets fixed. Thanks for your patience.
Stock Ride Height: 14 5/8" front & 14 3/8" rear
Stock damper full droop: 17 7/8" front & rear
Front damper free stroke [no bumpstop contact]: 3 9/16"
Front stock bumpstop length: 2 5/16"
Maximum possible damper stroke [100% theoretical bumpstop squeeze]: 5 7/8"
Rear damper free stroke [no bumpstop contact]: 3.0"
Rear stock bumpstop length: 2 3/16"
Maximum possible damper stroke [100% theoretical bumpstop squeeze]: 5 3/16"
RCE front bumpstop: 2.0"
RCE front free stroke: 3 7/8"
RCE rear bumpstop: 1 1/16"
RCE rear free stroke: 4 1/4"
RCE Yellow ride height [provisional]: 14.0" front & 13 7/8" rear
Translation: The stock suspension has 1 5/16" front and 1 1/16" rear free compression damper travel before becoming bumpstop active. Crazy as it sounds, this is more than many cars in this weight range. The RCE setup with the new bumpstops add back precious free compression travel, at the expense of a more aggressive bumpstop curve. As such, with the RCE setup at its ride height, there is 5/16" less free compression travel in front and 5/8" more free compression stroke in back versus stock.
Long story short, the RCE Yellows are about as smart as lowering springs get, in my experience. They keep a reasonable amount of free compression travel, which will keep ride quality decent.
The only install notes worth posting is the rear suspension appears to have implemented significant usage of stock rubber bushings put in torsion to add damping to both the control arms and anti-roll bar. We had to use a big-ole-2x4 piece of lumber to leverage the rear suspension to allow the coil-overs to be removed from the car. This suspension tuning strategy isn't terrible per se, but it will reduce the anti-roll bar wheel rate and effective damping level as the bushings wear out.
Cheers,
Ryan
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
The Following 4 Users Say Thank You to Ryephile For This Useful Post:
Cameronghanson (03-24-2013), eikond (03-24-2013), Mac1235 (03-25-2013), Trettiosjuan (09-16-2014)
Old 03-24-2013, 10:13 PM   #38
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Looks good. Classy mods. How much more do you expect the new springs to settle?
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
The Following User Says Thank You to Rampage For This Useful Post:
eikond (03-24-2013)
Old 03-24-2013, 10:39 PM   #39
eikond
eikond's Avatar
Cheers,
Ryan
^Yeah what he said..
I understand the big 'ol 2x4 part
I also understand that despite the lower ride height the I think the ride is smoother and more comfortable. My first reaction was that I thought it was "bouncier".. but after a little more time in the car, it's not that at all.. it's that when you hit big bumps it doesn't bottom out so harshly. It seems to absorb more in the springs before it hits the bump stops. I love the ride.. it feels more connected and more confident.
Ryan, you are awesome! Thanks a ton for helping me with this today. I would have been stuck on the rear suspension for a LONG time.
Old 03-24-2013, 10:43 PM   #40
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
looks very good. Drop lets the car really shine now
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
eikond (03-24-2013)
Old 03-24-2013, 10:50 PM   #41
eikond
eikond's Avatar
RCE says they are 20mm drop. I think Ryan measured about 16mm after a quick ride around the block. So if measurements are correct then it should settle another 4mm.. say about 1/8th of an inch.
I'm fine with it.. sure it's not as low as some of the other kits.. but I've never been a fan of super low dropped cars. With my driveway and the roads around here.. this drop is great.
Old 03-25-2013, 06:52 AM   #42
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Car is looking really nice. Can't wait to see it in person! Almost went with those wheels myself.
It won't settle too much more than your initial drive assuming you got to corner with it a little bit and load everything up. Did you end up doing the RCE sways as well?
The Following User Says Thank You to kask2_6.0 For This Useful Post:
eikond (03-25-2013)
GrimmSpeed Engineering's Daily BRZ Journal GrimmSpeed Member's Car Journals 34 11-13-2013 09:09 AM
Longo Scion Demo Build Journal - Car arrives next week xravexboix Member's Car Journals 12 06-15-2012 12:00 AM
AutoExpress BRZ Review - Follow up to the GT86 Review Zgrinch BRZ First-Gen (2012+) — General Topics 3 12-13-2011 08:03 AM
Request for a Member's Journal forum? ryude Scion FR-S / Toyota 86 GT86 General Forum 7 11-30-2011 04:47 PM
Wall Street Journal reports 2.5 l engine Sport-Tech Engine, Exhaust, Transmission 8 10-11-2010 10:44 PM
