Old 03-10-2013, 09:00 PM   #1037
vtmike
vtmike's Avatar
Drives: Scion FR-S
Originally Posted by sierra View Post
I would say something like Ecutek solved the problem?
Wasn't under the impression they were including a tune on their claimed gains with the axleback and downpipe combo. Would be interesting if that was the case.
Sent from my Nexus 7 using Tapatalk HD
vtmike is offline   Reply With Quote
Old 03-10-2013, 09:11 PM   #1038
sierra
Drives: Skoda Yeti DSG diesel 4x4
I'm sure the initial gains for the axleback helping to fill the torque dip and the overpipe/downpipe power gains at the top end were without a tune.
The latest headers and exhaust would have been severely limited, maybe even detrimental without a tune. I remember reading that they tuned the ECU for that but felt they could improve on that tune given more time.
Hope i'm right and not getting into deep poo?
sierra is offline   Reply With Quote
Old 03-10-2013, 09:17 PM   #1039
vtmike
vtmike's Avatar
Drives: Scion FR-S
That's what I was thinking.
If you dig way back in the thread their is a link to another dyno thread where Jason was saying their testing with the downpipe and axleback wasn't yielding power gains and speculated it was the ecu. Then fast forward and their is a dyno for those parts that show gains.
Maybe it was oil temps or something dragging the numbers down but couldn't find an explanation in my searching. Might ask him myself Monday. Just curious.
Old 03-10-2013, 09:24 PM   #1040
sierra
Yes, me too.
I get the impression the ECU and mechanical limits of the engine are very high because a turbo running up to 8psi can be accommodated by a tune.
The self learning limits of the ECU seem very tight and restrict gains.
If we could raise those restrictions would it mean the ECU would adjust to modifications over time?
Old 03-10-2013, 10:18 PM   #1041
vtmike
vtmike's Avatar
Drives: Scion FR-S
Yes, me too.
That's what I was wondering. If they reset the ecu for each dyno run, but then does the ecu start limiting power later?
Old 03-10-2013, 10:41 PM   #1042
sierra
I think the reverse happens. The reset limits the power and the relearn increases the boundaries over several hundred km's.
Try a reset on yours, by the book and see what you think?
I did it on mine expecting a power increase and got the opposite. Even the throttle delay was back and it took some time to get back to full power.
It felt flat, almost lethargic by comparison.
Maybe that's how they enforce a run in period from new?
Old 03-10-2013, 11:06 PM   #1043
OrbitalEllipses
Drives: Attitude
That's usually what occurs after time, but from what I've read the first pull is often usually best (IAM resets and knock learning from prior are forgotten).
Old 03-11-2013, 07:19 AM   #1044
mad_sb
Drives: 2013 Asphalt FR-S
the first will only be the best if a tune is involved and the IAM has been set to an intial value of 1.0 (100% ignition advance map added to base ignition timing). With a stock tune IAM is .7 (70% of advance map + base timing).
The two main things that settle in after an ecu reset are IAM (either up or down depending on how it is set in the tune) and Fuel trims (which are applied in open loop).
There are some learned values for throttle fully open and fully closed and i believe cam position offsets etc but i belive those are set during the first 30 seconds after reflash / reset and restart. not 100% sure on those.
Old 03-11-2013, 08:54 AM   #1045
vtmike
vtmike's Avatar
Drives: Scion FR-S
Interesting. Is it recommend to do a reset after installing modifications?
Sent from my Galaxy Nexus using Tapatalk 2
Old 03-11-2013, 09:15 AM   #1046
mad_sb
The honest answer is it depends...
If you have the ability to monitor fuel trims and AFR etc in real time I would not be so worried about it as everything will adjust over time. These cars with stock tune can stack up a large long term trim for the high load (WOT) area very quickly due to how long they hold closed loop on the stock tune. IF that trim is negative, I would reset.
It's ceratinly not going to hurt anything to do a reset in most cases but i would want to monitor afr WOT after making any changes. And you can do that with any obdII utility.
Old 03-11-2013, 09:21 AM   #1047
FR-S Matt
Probably a stupid question, but would driving spirited POST local tune be a dumb thing to do for the next 50-100 miles or would that even matter? Not sure how this ECU learns things but it is certainly strange to me how it functions.
Old 03-11-2013, 09:45 AM   #1048
vtmike
vtmike's Avatar
Drives: Scion FR-S
I have the torque pro app, I'll have to start monitoring that.
Old 03-11-2013, 10:03 AM   #1049
OrbitalEllipses
Drives: Attitude
Oh god I never want to reset the ECU ever again. Throttle dead spot is goddamn terrible.
Old 03-11-2013, 06:15 PM   #1050
FR-S Matt
Just got word my Axleback was delivered to Titan today and will be shipping to me tomorrow.
The Nameless guys are super busy, but I got a chance to talk to Jason again today. This is all I have:
BRZ performance driving demo - looks great Oriental Life BRZ Photos, Videos, Wallpapers, Gallery Forum 26 04-11-2012 02:20 AM
What type of performance parts will you be looking to buy first? bFreed Engine, Exhaust, Transmission 12 11-09-2011 05:51 PM
Performance automatics madfast Engine, Exhaust, Transmission 118 08-25-2011 03:26 AM
FT-86 Article on Performance magazine 4agze Scion FR-S / Toyota 86 GT86 General Forum 7 01-09-2010 11:33 AM
