#29 |
Drives: WRB BRZ
The part of the car that you drilling the hole, is that plastic or metal? if it's metal, would it start to rust in a couple of years?
#30 |
"New hotness"
Drives: WRB Limited MT BRZ
Plastic. It's just the wheel well liner.
#31 |
'Senior' Junior Member
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
If you don't want to remove the rear wheels, use Vise-grips to hold a short 5/16" diameter piece of round-bar (or an old 5/16" drill bit of proper length) and heat it with a torch. Use it instead of a drill to make the last hole in the plastic liners, just use a steady hand so as not to contact the tab or hole on the mud guards. Only takes a second to melt through the liner and makes a nice clean hole. Did my entire install with no lift, no jack and no wheel removal. Took longer to remove the original fittings and clean the areas than to install the guards.
Oh, and I did lay a wet towel over the rear of the tires just in case of inadvertent contact. It's close but not bad if you're careful and use a short enough piece of round bar or bit.
"You'll never know if you don't try" - Shinroko Momose |
| The Following User Says Thank You to Clembo For This Useful Post: | DrDuquette (08-25-2013) |
#32 |
Drives: '89 911, '06 GTI, '13 BRZ
I'm thinking of getting a set for my BRZ. I do have some concern about the spring clips. I'm thinking that as the spring clips are pushed in place the paint would be scatched and be a possible rust issue down the road.
Now I realize this is only for the front as the rear is all plastic.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe 2006 VW GTI/DSG 2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten 2014 Nissan Murano SV |
#33 | |
Drives: WRB BRZ
Also, as long as you clip it lightly it won't scratch off the paint to the base metal. I put the clip on and took it off the first time and touched the area by hand, the painted area was fine. |
| The Following User Says Thank You to chenshuo For This Useful Post: | DrDuquette (08-25-2013) |
#34 | |
Thanks again for your reply!
2005 Honda XR650L
#35 |
Drives: '13 FR-S Ultramarine
Thanks for the write-up I did mine yesterday, and it was the first "mod" to the car.
2013 FR-S Ultramarine
![]() -TRD Catback, UEL Header and Tune, Blitz Drop in Filter, Mishimoto Silicone Intake tube, Mishimoto Oil Cooler, 17x9 w/245/40/17 PSS, RS*R Coilovers custom track alignment, Check out my YouTube for more track videos https://www.youtube.com/channel/UCA9...O1T2Q3xu4m4bYQ |
#36 | |
86 Owners of New England
Drives: Toyota GT86
| The Following User Says Thank You to AG3NT_5CARFAC3 For This Useful Post: | Dadhawk (08-24-2013) |
#37 |
Drives: 2013 Premium White, 2006 TL
Excellent write up. Did mine. I had the concern about paint too. But they actually slip on well without scratching. Where I live nothing seems to rust, but I know other parts of the country and Canada need to worry.. Did anybody put side skirts on with the mud flaps? Thinking that it won't fit together.
#38 | |
RedBunny w/ Wing
| The Following User Says Thank You to Lverasky For This Useful Post: | DrDuquette (08-25-2013) |
#39 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Weird. Mine came with these stock. Am I missing somethng here?
#40 |
Drives: 2013 Scion FR-S Raven
Thank you for the excellent DIY!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#41 |
Drives: Subaru BRZ Sport Tech Satin White
All Canadian stock FRS come with "splash guards" installed. The only exception would be if a dealer installs a body kit as that uses the same pre drilled holes.
No BRZ comes with splash guards and Subaru dealers have no part number for them! Now that is weird in Canada given Subaru's tough guy reputation. Our friendly Canadian Scion dealers will supply a set of Scion splash guards complete with hardware and printed instructions for CDN$62.50 plus tax for you to fit to or have fitted to your BRZ. They have to order them in from Vancouver warehouse because they don't need to stock any! BTW, you only need to clean the fender and fender liner area to allow for a close and tidy fit. All the body contact areas are plastic so future corrosion cannot be an issue. No need to spray anything onto the car body before you fit the splash guards. |
| The Following User Says Thank You to Suberman For This Useful Post: | hmong337 (09-07-2013) |
#42 | |
The body kit uses the same holes so, no. Won't fit both but with the body kit you won't need splash guards anyway. |
| The Following User Says Thank You to Suberman For This Useful Post: | DrDuquette (09-06-2013) |
| Tags |
| flaps, guard, mud, mudflaps, rally armor |
| Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? | 07stealth350z | DIY (Do-It-Yourself) Guides | 8 | 08-27-2020 03:27 PM |
| Mud Guard Question | geb2391 | BRZ First-Gen (2012+) — General Topics | 36 | 03-01-2013 06:37 PM |
| Opti guard in or near oklahoma? | Flako | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 10-22-2012 07:00 PM |
| Opti Guard | ExWhyZer0 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 10-10-2012 03:22 PM |
| '13 BRZ | Opti-Guard fun! | michakaveli | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 09-02-2012 05:50 PM |
