Old 03-09-2013, 02:29 PM   #1
Spencer
Water in trunk
I went into the trunk of my BRZ and took off the rug on top of the spare tire I saw that there was a lot of moisture and took out the spare and there was a puddle of water and decided to take out the jack and all of the foam panels and there was also puddles of water under then. I took out the back seat to see where the water was coming from and there was even more water dripping under the rear seats . I called subaru and the guy there said that I needed to drop it off for a day or two just to see where it's coming from so I said screw that and took it to a car wash and dident see where it was coming from then I saw that is coming from behind the taillights on both sides Name:  ImageUploadedByTapatalk1362857193.105402.jpg
Drivers side
Passanger
Here's some of just the water when I found it Name:  ImageUploadedByTapatalk1362857260.005338.jpg
Size:  162.7 KBName:  ImageUploadedByTapatalk1362857269.654333.jpg
Size:  115.6 KBName:  ImageUploadedByTapatalk1362857278.821733.jpg
Size:  158.1 KBName:  ImageUploadedByTapatalk1362857290.221762.jpg
I called subaru back and they said that I still had to drop it off to see where it was coming from and why so I guess I'll have to make an appointment for later this week but is anyone else having this problem ?
Spencer is offline   Reply With Quote
Old 03-09-2013, 02:48 PM   #2
acetothermus
Drives: Flying in a Blue Dream
I would imagine we'd have more wide spread reports of this by now if it was a major issue. Unless the gaskets used around the tail lights are just starting to fail and we'll start seeing more of this.
Do you keep your BRZ in a garage or out in the elements?
acetothermus is offline   Reply With Quote
Old 03-09-2013, 03:50 PM   #3
DeepHunta
Drives: '05 Outback Wgn, '05 Lotus Elise
I think the little foam that surrounds the tail light housing has a hole or maybe the bolts for the housing is not tight enough that the foam is not snug to the metal body.
I just changed my tail lights and found out that how water is kept away.
Proud ex-owner of GBS 6MT BRZ Limited. Pre-ordered on Feb-29-2012, got VIN on 5/19 with ETA 6/6, arrived early on 6/2, but still didn't pick it up until Jun-6-2012. Recently sold the Buuurz as of 4/21/2014
DeepHunta is offline   Reply With Quote
Old 03-09-2013, 04:58 PM   #4
andrew20195
Drives: 2013 Subaru BRZ
This is related to the recently updated "Moisture in the taillights" service bulletin. Make an appointment with your Subaru dealer. If they give you any trouble, tell them to read the bulletin again. They should replace both taillight seals and install new, larger nuts, as well as inspect the taillight housing for cracks. Edit: The updated Service Bulletin explicitly states that the problem does not have to be present to perform the repair, so even if they can't reproduce it, they should still repair it. Edit edit: Is anyone else having trouble with post editing not saving formatting correctly?
andrew20195 is offline   Reply With Quote
Old 03-09-2013, 06:54 PM   #5
RandomFRSguy
RandomFRSguy's Avatar
Drives: Whiteout Scion FR-S
I had this issue with my FRS, after i did my taillights and put them back on. The issue for me was the wire was closer to the car then the foam. IT should be under the foam or the water just run along the wire to a certain spot then drips into the trunk.
RandomFRSguy is offline   Reply With Quote
Old 03-10-2013, 01:52 AM   #6
Spencer
My garage actually just collapsed on the brz and i just got it back a few days ago
Old 03-10-2013, 03:59 AM   #7
acetothermus
Holy crap. Hopefully no damage (or if any only minor.)
If it was painted and they baked it that could cause the seals to fail. However I think it has more to do with the service bulletin than anything else.
Old 03-10-2013, 12:49 PM   #8
Spencer
There was about 3,000 in damages and I think that the guy at my dealer doesn't know what he's talking about or dident read the bulletin
Old 03-10-2013, 01:26 PM   #9
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Had the same problem on my car, the water under the spare tire is because these
they do a terrible job in keeping the water out, so I sprayed some flex seal under both plugs. Water has stopped. You might also want to check this thread out
http://www.ft86club.com/forums/showthread.php?t=29193
Juanito08 is offline   Reply With Quote
Old 03-10-2013, 02:37 PM   #10
Spencer
Thanks for the info
Old 03-15-2013, 02:44 PM   #11
gily25
Drives: Silica BRZ 6MT
Bad drain plugs? Are you in a hot climate?
gily25 is offline   Reply With Quote
Old 03-15-2013, 04:12 PM   #12
Spencer
I live in New England so it's still like 40s -50s
Old 03-15-2013, 04:19 PM   #13
Spencer
Originally Posted by vubaru View Post
Yes, I've had this problem. Subaru refused to address it along with the condensation in my rear tail lamps. SOA blamed the fact that my car was rear ended, however there was condensation in the rear tail lamps prior to the accident in August 2012.
At present the body shop seems to have repaired the leak as they have taken up the warranty claim where SOA has refused it.
Currently no leaks, but you're not alone.
The guy at my dealership is a **** because he ALLWAYS lies about everything on the car and what they are going to do. I had a. Garage collapse on top if the car and they gave me two options ether bring it to a Body shop near my house or have it put on a flatbed and brought up to there specialty body shop so I discussed it with my dad and we agreed that if the tow was free we would do it because we would be sure that all subaru parts were used so I called back and set up a time that we would drop it off so the FLATBED could come and pick it up. Then when we dropped it off he said the FLATBED is on its way and that we just needed to get a rental so we got picked up by enterprise and we left the dealership( this is my first car by the way ). We come back when the repairs are done and I really wanted they weren't driving my car beating the piss out of it and I look at the odometer and there's another 55 miles and a paint chip in the door and we go inside and the guy at the desk is like YEA ! WE DROVE IT THERE ! So they drove the car when they said it was going to be trailered. I don't think that I will be using that dealership anymore.
Old 03-15-2013, 07:21 PM   #14
Dorb
Drives: 16 LM STI/13 LM BRZ/04 AVALANCHE
I had water in my trunk last weekend, but took it out when I got back home from Sam's Club.
Dorb is offline   Reply With Quote
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 03:27 PM
WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk R0ME0 Exterior Parts (Aero, Lighting, Etc.) 3 01-07-2014 09:36 PM
WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing wollview Exterior Parts (Aero, Lighting, Etc.) 1 12-30-2012 03:14 PM
WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing wollview Southern California 0 12-16-2012 02:46 AM
WTT: DGM BRZ Limited trunk w/ spoiler for wingless DGM trunk No Limit Motorsport NY / NJ / CT / PA 6 09-27-2012 10:14 AM
