View Poll Results: Do Your Coilovers Knock?
Yes, and I have BC Racing Coilovers. 41 44.09%
Yes, but I do not have BC Racing. 13 13.98%
No. 39 41.94%
Voters: 93. You may not vote on this poll
Old 03-09-2013, 12:13 AM   #1
636
636's Avatar
Drives: '23 CWP BRZ
BC Racing Coilovers - Knock?
Let's get a general consensus for BC Racing owners. I have talked with 3 other people who claim that their coilovers are making a knocking noise in the rear over bumps. I'm also hearing this noise. So, post if you have the problem.
If you have different coilovers and still hear the knock(kind of like a pinball noise) comment as well!
636 is offline   Reply With Quote
Old 03-09-2013, 01:38 AM   #2
NickFRS
Drives: 2013 Asphalt FRS
Your top bolt has simply come undone. Common. Go tighten it down.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
The Following User Says Thank You to NickFRS For This Useful Post:
winsometang (12-08-2015)
Old 03-09-2013, 07:25 AM   #3
636
636's Avatar
Drives: '23 CWP BRZ
We took out my coils and retightened every bolt..still making the noise.
Old 03-09-2013, 01:12 PM   #4
stancypants
stancypants's Avatar
Drives: FR-s
i mean mine make a lil noise but its aftermarket parts its not going to feel like or sound like stock so it doesnt bother me but thats just me
stancypants is offline   Reply With Quote
Old 03-09-2013, 01:31 PM   #5
just86
just86's Avatar
Drives: 2013 genesis rspec
BC are low rating coilovers, you get what you pay for
just86 is offline   Reply With Quote
The Following 4 Users Say Thank You to just86 For This Useful Post:
jumbaco (03-14-2013), lightdir (05-28-2014), NyC Zn6 (02-18-2015), STV3 (09-10-2015)
Old 03-09-2013, 01:39 PM   #6
zex
zex's Avatar
Drives: Subaru WRB BRZ Limited
Mine makes a squeaky spring noise when it rains really hard
zex is offline   Reply With Quote
Old 03-09-2013, 03:57 PM   #7
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
I have BC's on both my cars, can get a slight "knock" in rear only going over bumps at slower speeds, cant find anything loose. dosent bother me.
Jesse is offline   Reply With Quote
Old 03-09-2013, 07:28 PM   #8
jammz
Drives: '13 Scion FR-S Agento
i had BC coilovers on my old car and my friend (who had an Infiniti G37x, G37s and now BMW 328i which he had BC racing on all of them) and I had slight knocking noises aswell. So i'd say its "normal"
jammz is offline   Reply With Quote
Old 03-09-2013, 08:08 PM   #9
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Bcs FTW
Old 03-09-2013, 08:15 PM   #10
636
636's Avatar
Drives: '23 CWP BRZ
Welp, seems like it's normal. Hahah.
Old 03-09-2013, 10:19 PM   #11
FRS2NV
Drives: 2103 Scion FR-S
+1
HSD would be my First Choice for what you pay
FRS2NV is offline   Reply With Quote
Old 03-14-2013, 09:10 AM   #12
p00mba
p00mba's Avatar
Drives: FR-S :)
This is my first set of BCs and i have the slight noise in the rear, my friend with a Genesis coupe with BCs had the same issue and tightening the top bolt (under the dampening screw) fixed his issue. I will try this tonight and post back.
BTW my issue is only the rear driver side, so i don't believe think the noise is normal, then again if after i tighten this screw doesn't fix the issue i will try to reach out to BC for their input.
p00mba is offline   Reply With Quote
Old 03-14-2013, 10:03 AM   #13
speed6sam
Drives: SWP BRZ Limited 6 Spd
I have one of the first production kits on my car. Zero noises under any conditions and my car is autocrossed/driven hard as much as possible.
You guys with slight noises need to isolate where its coming from and contact BC about it so they can help you figure it out.
speed6sam is offline   Reply With Quote
The Following User Says Thank You to speed6sam For This Useful Post:
p00mba (03-14-2013)
Old 03-14-2013, 10:43 AM   #14
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
try tightning the lower bolt more (way bast the recomended torque spec)
on cars with similar lower attachment points that's usually the issue with aftermarket pieces.
BC Racing coilovers help! chuyjr85 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 08-27-2015 10:01 PM
GI: BC Racing Coilovers RavenFR-S Brakes, Suspension, Chassis 13 02-07-2013 10:53 AM
BC Racing Coilovers Dustin@Dynosty Brakes, Suspension, Chassis 5 01-27-2013 02:36 PM
BC Racing BR Coilovers Blaster Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-22-2012 06:11 AM
