Old 01-08-2013, 12:41 AM   #141
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
Originally Posted by so26 View Post
Installed the Perrin crank pulley and I have to say that it definitely improves the feel of fast down-and up-shifts by removing some of that rotational inertia that our cars seem to have too much of.
One con that I have noticed however is that if I go to gun it at idle without a load on the motor (like you would do to show off your exhaust to someone in a parking lot) that the rpms will momentary dip followed by a chattering noise before the rpms recover. This is most likely due to air within the intake manifold stalling because of the sudden onset of WOT. The additional rotating mass of the stock pulley would keep things spinning and therefore making this a non issue. Note, this issue does not seem to be a problem actually driving the car and can be avoided by gradually applying the throttle initially.
FYI, you may not need to purchase a breaker bar if you can slip a 3/4" black pipe (3' in length) on the handle of your ratchet.
Also you don't need a fancy torque wrench for this job a bar-type wrench will work fine; however, you may want to use a 12-pt socket to get the best angle for applying the required force on the handle.
Mine dips just a bit now if I do that and I don't have this pulley on it. I am going to buy the pulley though. Or see if the machine shop at work will mill me one out for free! lol...
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
ravenblackfrs is offline   Reply With Quote
Old 01-25-2013, 07:26 PM   #142
efactor84
efactor84's Avatar
Drives: 2015 Scion FR-S
Great write up for possible first mod to come.
efactor84 is offline   Reply With Quote
Old 01-28-2013, 02:06 AM   #143
Vukodlac
Vukodlac's Avatar
Drives: Asphalt FR-S
damn, is this mod worth it? Doesn't look like it....
-2013 Scion FR-S-
K&N drop in.
Motiv overpipe, hfc. Perrin unresonated. Stage 1 NA Tune ( Thanks Drift Office )
Vukodlac is offline   Reply With Quote
Old 02-05-2013, 01:02 AM   #144
Cj_Staal
Drives: FR-S/92 3kgt VR4
Does the stock pulley double as a harmonic dampener-- or because this is a boxer engine it does not need dampening? I'm purchasing an FR-S next month and this may be one of the first mods I do to it as long as it doesn't ruin the harmonics of the crank-- even just a little.
Cj_Staal is offline   Reply With Quote
Old 02-18-2013, 03:25 AM   #145
GTS86
GTS86's Avatar
Drives: Black GTS86 Aero
Another trick:
[ame="http://www.youtube.com/watch?v=7G-adEVjfWI"]Crankshaft Pulley Removal Trick - YouTube[/ame]
EDIT: Guys, I'm NOT suggesting anyone tries this with their 86.. it is intended for entertainment purposes only - I had a good laugh and I hope you do too.
I also HIGHLY recommend you check out this Series for more great "How To's and DIY's"
[ame="http://www.youtube.com/watch?v=hjhZx-9wjtM"]The Bush Mechanics - The Chase Part 1 of 3 (complete version!) - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=H-tsKPlDn7U"]Bush Mechanics - YouTube[/ame]
You can buy the DVD here:
[ame="http://www.amazon.co.uk/Bush-Mechanics/dp/B002P84Q3M"]Bush Mechanics: Amazon.co.uk: Film & TV[/ame]
It's seriously one of the best programmes I've ever seen (I'm Australian and might be biased) ENJOY!
GTS86 is offline   Reply With Quote
Old 02-18-2013, 04:00 AM   #146
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I've thought of that with this car, I've seen it tried with other cars, and trucks.. And it doesn't always work.. Some bigger trucks engines have the torque in the starter to break it lose, but smaller cars didn't... Easiest way is this ... If you have air..
http://www.ingersollrandproducts.com...-drive/2025max
It's like a pneumatic ratchet but works like a impact..
[ame="http://m.youtube.com/watch?v=Y2_-SNw5Mi0"]IR HAMMERHEAD IN ACTION - YouTube[/ame]
Gixxersixxerman is offline   Reply With Quote
Old 02-18-2013, 11:40 AM   #147
Marrk
Drives: Honda Fit
Originally Posted by GTS86 View Post
Another trick:
Stupid is as stupid does. But, like all stupidity, it makes great YouTube viewing.
Marrk is offline   Reply With Quote
Old 02-18-2013, 01:45 PM   #148
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Another trick:
Please, please, please don't do this. There are so many things that can go wrong.
Old 03-07-2013, 04:33 PM   #149
Cjs_
Cjs_'s Avatar
Thanks for the write up helped out alot.!
Cjs_ is offline   Reply With Quote
The Following User Says Thank You to Cjs_ For This Useful Post:
neutron256 (03-07-2013)
Old 03-07-2013, 08:34 PM   #150
efactor84
efactor84's Avatar
Just installed mine. I was paranoid at first, but this install was a breeze without hesitation. The belt easily came off when you release the tension pulley after you turn it clockwise. This install took me about 10 minutes. My car is more awake now and hardly lags at all in the RPM's in first and second gear. This should be a priority engine mod before going to exhaust or intake.
Old 03-07-2013, 10:20 PM   #151
Yruyur
Yruyur's Avatar
Had to swap mine hack to stock to return it as its a lemon. Have had the perrin pulley on for about 15k miles. I can tell the difference going back to stock for sure. Rev matching and throttle blips are not as snappy. Cant wait for the new car so I can put it back on.
Sent from my GT-P3113 using Tapatalk 2
Old 03-11-2013, 03:12 PM   #152
rainmonkey
Drives: BRZ - Dark Grey
How long did the whole install take?
local shop told me roughly 4 hours :/ doesnt seem like it'd take that long from what i've read and stuff.
rainmonkey is offline   Reply With Quote
Old 03-11-2013, 03:42 PM   #153
Yruyur
Yruyur's Avatar
Literally 15 minutes. I couldnt find the breaker bar.
Old 03-30-2013, 09:36 PM   #154
kykiee
kykiee's Avatar
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
I struggled to get my crank bolt out, but I did eventually got it out. It's a simple mod and doesn't take long at all. I would suggest doing the pulley and the intake both at the same time.
2013 Subaru BRZ Limited - GBS - 6MT - VIN #01197
kykiee is offline   Reply With Quote
brz, crank pulley, diy, frs, perrin, raceseng
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
