Old 03-06-2013, 07:35 PM   #43
jpit
Drives: Subaru BRZ
Hi, everyone.
Thanks for all your help getting me back onto the forum. It is appreciated. Hope you are all enjoying the armrests. Please no armrest business conducted here. I wish that they had gone with black screws also. I wonder if we could find some black caps to fit?
jpit
jpit is offline   Reply With Quote
The Following 18 Users Say Thank You to jpit For This Useful Post:
avusblue (03-07-2013), ChiefG (12-11-2013), civicdrivr (03-07-2013), Grimlock (03-06-2013), husker741 (03-06-2013), lbroskee (03-06-2013), Lonewolf (03-06-2013), lordtakuban (03-08-2013), microbionic (03-06-2013), MrAmalto (10-04-2013), newports (06-28-2013), raul (03-19-2013), Skippman (03-08-2013), spgrizz22 (03-06-2013), Subie (03-06-2013), The Slow One (03-08-2013), TouchMyHonda (03-27-2013), zzabbas (03-07-2013)
Old 03-06-2013, 07:37 PM   #44
spgrizz22
Drives: Scion FR-S
Originally Posted by jpit View Post
Hi, everyone.
Thanks for all your help getting me back onto the forum. It is appreciated. Hope you are all enjoying the armrests. Please no armrest business to be conducted here. I wish that they had gone with black screws also. I wonder if we could find some black caps to fit?
jpit
Dude I missed you! haha.
spgrizz22 is offline   Reply With Quote
Old 03-06-2013, 07:56 PM   #45
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Hi, everyone.
jpit
YES!!!!! He's back, ladies and gentlemen.
I told you we'd get you back.
husker741 is offline   Reply With Quote
Old 03-06-2013, 11:07 PM   #46
jpit
Drives: Subaru BRZ
A couple of members asked me to repost some observations when installing the armrest. Here are the Toyota instructions:
http://www.toyota-tech.eu/aimuploads..._002_827_0.pdf
Here are some observations: use the template but drill with a very small drill bit because you will probably be off a little (no need to start right off with the 5mm bit). You can use 13/64" for the 5mm and and 5/16" for the 8mm. I drilled the passenger side first because that is where the tabs fit into the center console. The holes to be drilled on that side are in a straight line so you can tell if you are off. You can put the armrest on its side and line up the tabs and holes to get a good idea how things are going. After the 8mm holes (and remember two holes stay at 5mm)are drilled on that side, put the armrest in and see how it fits. When you are happy with the fit use an awl or sharp nail to mark where all the other holes are to be drilled. I drilled both a 5mm and 8mm hole into a thin piece of metal that I had and held that over the scratch marks so the drill bit didn't walk. If you drilling is off a little remember that all the holes are hidden by the foundation. If the 5mm holes are off a little use a guide to help drill the 8mm holes. You don't want to make those holes too big or the rubber torx thing won't have any place to grab. There are two holes which are a little ackward to get to (marked with arrows). I didn't need to remove the upper piece as I used a thin torx driver and put a piece of tape along the edge of the lid to prevent marking. When tightening the torx bolts do not put any tension on the plastic foundation or the top might not close properly. Also, the color matches much better than the photo indicates.
Also, contrary to an earlier post I actually keep my BRZ very clean. Because it is my DD I have no qualms about taking my Golder Retriever along with me.
The Following 11 Users Say Thank You to jpit For This Useful Post:
Alfalasy (11-09-2014), avusblue (03-07-2013), BRZranger (03-07-2013), ChiefG (12-09-2013), HyperTech (06-27-2014), JPxM0Dz (06-24-2013), mikochu (08-14-2013), Screw Loose Dan (12-05-2013), SeanBlader (12-09-2013), soundman98 (02-15-2014), Sportsguy83 (03-07-2013)
Old 03-06-2013, 11:10 PM   #47
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Here are some observations: use the template but drill with a very small drill bit because you will probably be off a little (no need to start right off with the 5mm bit). You can use 13/64" for the 5mm and and 5/16" for the 8mm. I drilled the passenger side first because that is where the tabs fit into the center console. The holes to be drilled on that side are in a straight line so you can tell if you are off. You can put the armrest on its side and line up the tabs and holes to get a good idea how things are going. After the 8mm holes (and remember two holes stay at 5mm)are drilled on that side, put the armrest in and see how it fits. When you are happy with the fit use an awl or sharp nail to mark where all the other holes are to be drilled. I drilled both a 5mm and 8mm hole into a thin piece of metal that I had and held that over the scratch marks so the drill bit didn't walk. If you drilling is off a little remember that all the holes are hidden by the foundation. If the 5mm holes are off a little use a guide to help drill the 8mm holes. You don't want to make those holes too big or the rubber torx thing won't have any place to grab. There are two holes which are a little ackward to get to. I didn't need to remove the upper piece as I used a thin torx driver and put a piece of tape along the edge to prevent marking. When installing the armrest do not put any tension on the plastic foundation or the top might not close properly.
couldn't you in theory 3M tape the whole thing down so as to not drill into the car?
lbroskee is offline   Reply With Quote
The Following User Says Thank You to lbroskee For This Useful Post:
Old 03-06-2013, 11:11 PM   #48
sid325
Drives: Ultramarine FR-S 6MT
Jeff, good to see you back!
Jacob
sid325 is offline   Reply With Quote
Old 03-06-2013, 11:28 PM   #49
jpit
Drives: Subaru BRZ
I guess you could but it wouldn't sit as flush. I can't think of any reason I would ever take it out.
Old 03-06-2013, 11:31 PM   #50
lbroskee
lbroskee's Avatar
i just have issues with permanent mods lik that. bc with my luck itll go wrong. thats all thats keepin me from gettin this
Old 03-07-2013, 01:17 AM   #51
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Buy it, and get it installed by a dealer (at least give it a shot). Its a Toyota part after all.
Old 03-07-2013, 03:10 AM   #52
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
I want one!!
This is exactly what I have been looking for. Jpit, sent you an email. Need shipping to the UAE.
Thanks
RevoG
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Old 03-07-2013, 03:36 AM   #53
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Looks great. Do you have any pics/comments on how the latch works?
I also see what appears to be a slot for ipod wires etc.
cheers
smbrm is offline   Reply With Quote
Old 03-07-2013, 07:17 AM   #54
colHolm
Default User Title
colHolm's Avatar
cheers
The latch is a little button... push it in and lift the armrest.
Yes that is a slot for cables.
colHolm is offline   Reply With Quote
Old 03-07-2013, 09:35 AM   #55
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Originally Posted by ExWhyZer0 View Post
I still haven't found time to install mine yet
Me either and I was the one promising pics installed
supramkivtt2jz is offline   Reply With Quote
Old 03-07-2013, 10:44 PM   #56
FRSGT86
FRSGT86's Avatar
Drives: 2013 Raven FR-S, 2005 Dodge Ram
Jpit
I am very interested in this arm rest. If you're ever gonna set up another group buy or if I can get in on this please let me know!
And glad to see you're back on the forum, they should never have banned you just for trying to help out some fellow members!
2013 FRS 6AT in Raven!
FRSGT86 is offline   Reply With Quote
armrest, jpit
Carsmo Armrest - Short review and quick pics Bleevin CANADA 3 09-27-2014 12:21 PM
new armrest Derrick Cosmetic Modification (Interior/Exterior/Lighting) 3 01-24-2014 10:48 PM
86 Armrest CzechZA AFRICA 30 02-05-2013 06:44 AM
armrest!!! whitefrs Cosmetic Modification (Interior/Exterior/Lighting) 10 09-07-2012 03:16 PM
