#43 |
Rates will be 400/400 with optional 500/500 or 400/450.
Same lifetime warranty all of our Tarmac II's have had since we started working with KW back in 2006 on private label/ co branded products. Expect 4 weeks from now or less. I have found them very streetable with STI group-n fronts and oem rears. I got -2.6 front camber on oem crash bolts. +6.7 caster too. Camber plates yes would allow much more, but would introduce some NVH too. Just a thought. Myles |
#44 | |
Drives: Some rust bucket
#45 | |
We are using EQUAL (400/400) as the standard rates to ship with. The car is very neutral with equal rates we have found at the limit. Solid tire temps running Michelins at -2.6 and -2.0(front to rear) . Hoosiers will require more front camber. But some autocrossers like more rear rate. Some prefer the "loose" tail. Some will keep rear bar stock and use a HUGE front bar and yet still increase rear rates. Its not what I prefer but I'm not an autocrosser anymore either. Myles |
#46 |
Drives: 2013 Subaru BRZ Limited 6MT
Pre-ordered my set last week! Decided to go with camber plates for maximum adjustment flexibility.
#47 |
Drives: White 2013 FRS
Getting very excited to install these on the weekend! What is the lowest recommended drop on the Tarmac II's?
#48 |
AutoX-10/10ths every run
Any info on shock dynos comparing the STD V3s to these units? Really close to pulling the gun on these...
| The RaceComp Engineering BRZ "Clubsport" Build | Racecomp Engineering | Member's Car Journals | 100 | 12-18-2014 02:18 PM |
| Street/Clubsport brake pads for your BRZ and FR-S | HP Autowerks | Brakes, Suspension, Chassis | 4 | 02-20-2013 01:34 PM |
| Street/Clubsport brake pads for your BRZ and FR-S | HP Autowerks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 10-15-2012 07:03 PM |
| Racecomp Engineering coilover sales: JRZ RS1 and KW V3 | Racecomp Engineering | Brakes, Suspension, Chassis | 29 | 09-17-2012 10:46 AM |
| Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-12-2012 12:24 PM |
