Old 03-05-2013, 06:37 PM   #29
blkwrxwag
Drives: DS FRS
Originally Posted by GC_Adam View Post
As long as I read the rules correctly, our stress bar is legal for STX for the FRS/BRZ chassis.
http://scca.cdn.racersites.com/prod/...lo%20Rules.pdf
"G. Strut bars per Section 12 are permitted with all types of suspension,
subject to the following constraints:
1. a 2-point strut bar may be added, removed, modified, or substituted,
but only with another 2-point strut bar.
2. A triangulated (3-point) strut bar may be removed, modified, or
substituted; substitution may be with either a triangulated or a
2-point strut bar. The connection to the chassis (i.e., firewall, bulkhead,
etc) must be in the standard location."
Please correct me if I misread/misunderstood the above information.
No, you are right. My mistake. What confused me is that there is no 2 point bar for the MX5. I'll edit my earlier post.
blkwrxwag is offline   Reply With Quote
Old 03-05-2013, 06:58 PM   #30
GC_Adam
GC_Adam's Avatar
Drives: '08 Impreza, 03 SV1000S
No big, I just wanted to make sure. :happy0180:
GC_Adam is offline   Reply With Quote
Old 03-05-2013, 11:32 PM   #31
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Actually, i think there is something to this. The version of the rules you link to are outdated. In the most recent version, that section has been edited to include this text:
"Subaru BRZ/Scion FR-S - The pair of OE strut tower-to-firewall braces are not considered to be a strut bar per Section 12.18 and are not allowed to be removed, modified, or substituted per Section 14.2.G."
This is at the bottom of page 270.
Now, not sure if this has anything to do with adding an additional brace, but maybe it does if it constitutes "substitution"
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 03-05-2013, 11:42 PM   #32
Gopherboy6956
But, just so we have all the information:
12.18 STRUT BAR
A transverse member connecting the upper or lower suspension mounting
points at the front or rear of the car. Strut bars may be mounted only
transversely across the car from upper left to upper right suspension
mounting point and from lower left to lower right suspension mounting
point. A two-point strut bar fastens only at the left and right suspension
pointing points. A triangulated strut bar has a third area of attachment
at the chassis (e.g., at the firewall/bulkhead). All connections to the vehicle
must be bolted. No connection point to the chassis can be welded.
and here's 14.2.G
Old 03-06-2013, 12:30 AM   #33
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
So the firewall braces would have been considered a strut if there was a stock strut mounted to between the suspension?
14.2.G.2 says a tri stut can be removed, modified, or substituted, but our cars don't have a tri strut. So I assume that that is the reason for:
Old 03-06-2013, 05:31 AM   #34
polancd
Drives: a few
I dont think GC strut bar modifies, removes or substitutes the tower to firewall braces. It connects camber plate to camber plate. and the camber plates do not touch the tower to firewall brace. So if im understanding the rules correctly you should be fine running any strut bar that doesn't change the factory brace (ie: cusco, gc) but cant use struts with the triangular design (ie: ft86speedfactory or pw jdm). Thats what i took from reading the rules.
polancd is offline   Reply With Quote
Old 03-06-2013, 09:32 AM   #35
Gopherboy6956
Well, i know for sure that:
A: For my local region, this will be the first BRZ twin around
B: they aren't very thorough when doing tech
So it probably won't matter for me.
Old 03-06-2013, 11:21 AM   #36
GC_Adam
GC_Adam's Avatar
I have had another client run his FT in STX with our complete (inc. Stress bar) system in several AutoX bodies in TX without having any negative repercussions towards any of his suspension modifications.
-Adam
Old 03-06-2013, 11:23 AM   #37
blkwrxwag
Drives: DS FRS
I truly doubt that anyone at a local event would care, but if you plan on running a national event, I would email Doug Gill at the SCCA to get a clarification.
The Following User Says Thank You to blkwrxwag For This Useful Post:
whataboutbob (03-11-2013)
Old 03-11-2013, 11:29 PM   #38
Gopherboy6956
Whoever you spoke to at KW was not properly informed. They are 340/400 for the off the shelf V3s.
For our RCE Tarmac 2's, we use 400/400 as the default rates, but allow customization firmer and softer depending on the user's needs.
Most good suspension shops will allow you to customize your coilovers and make recommendations on what will work for you. Some will have different ideas of what works.
I would stress again that using your budget completely on coilovers and then running stock bushings is not recommended. They really do make a solid difference. I would prefer a Koni + RCE Yellow spring set-up with some key bushings and maybe swaybars every time over 1500 in coilovers. Staging your build in phases is a common way to go and often a good idea depending on the user.
- Andrew
To expand on this - let's say I had more budget - and wanted to go KWv3 or Tarmac II - what bushings would you also replace?
Old 03-12-2013, 12:01 AM   #39
whataboutbob
AutoX-10/10ths every run
- Andrew
I've modeled my car build off of RCEs for the most part. Stock struts with RCE yellows, 20mm front / 16mm rear adjustable Whiteline bars with adj end links, Whiteline front STB, and Whiteline bushings nearly everywhere I could put them. Car feels very good now.
Build thread:Here
Old 03-12-2013, 03:15 AM   #40
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
I'm also curious what bushings should be first on the list. I am working within a budget, and probably won't go overboard, but I'd like to do things properly. What are people's thoughts on 'must-have' bushings? Ideally I would like to keep the NVH within reason. My car is used for extended roadtrips, and I don't want to be responsible for any of my passengers loosing their fillings
OjiGeorge is offline   Reply With Quote
Old 03-12-2013, 09:34 AM   #41
BEcause the bushings for this car were released over a period of 8 months and still being released, I, like many, had the benefit of installing these incrementally and seeing the effects.
My short list of wife approved/long trip/"I dont want too much NVH" kinda a person bushings are as follows:
Front control arm and caster bushings( WL or AVO) ( AVO makes one that doesnt change caster too)
WL shifter insert
WL rear subframe bushings
WL rear trailing arm bushings
WL rear camber bushings
Buy some good craft beer, borrow a friends press and have a bushing install party, with beer towards the end( some are 9-13% alc).
Alignment next day.
Myles
OjiGeorge (03-12-2013)
Old 03-12-2013, 06:36 PM   #42
OrbitalEllipses
Drives: Attitude
Buy Dogfish Head 90 Minute IPA. Install car parts. What could go wrong?!
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
Ro_Ja (03-12-2013), tech4pdx (03-12-2013)
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
What is your motivation? Why do you track/autox/etc.? What are your motorsport goals? CSG Mike Tracking / Autocross / HPDE / Drifting 22 02-20-2013 09:18 PM
Autox competetive street tire vs. RA-1 (or similar) for track use johhnc479 Tracking / Autocross / HPDE / Drifting 10 02-06-2013 02:49 AM
autox or autox school? engee Tracking / Autocross / HPDE / Drifting 10 06-12-2012 06:31 PM
