#15 | |
Drives: '08 Impreza, 03 SV1000S
http://www.ft86club.com/forums/showthread.php?t=26890 http://www.ft86club.com/forums/showp...06&postcount=7 -Adam Last edited by GC_Adam; 03-05-2013 at 04:05 PM. |
#16 |
Drives: 13 BRZ Limited WRB
I guess one thing that turned me on to KW V3 was this thread - seems like the norm for these AutoX guys...
http://www.ft86club.com/forums/showthread.php?t=30303
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
| The Following User Says Thank You to Gopherboy6956 For This Useful Post: | Anthonytpt (03-21-2013) |
#17 |
Drives: On track
Interesting link. When I called KW last week, they said the normal V3s have 230 front/285 rear springs, while the Clubsports have 340/400 springs.
#18 | |
Drives: Some rust bucket
For a budget build, I'd probably go for Koni Yellow with Eibach ERS springs. |
#19 | |
KW gives you what ever they want of the shelf. GC will tailor the system to you, what you want and what will make you competitive. If you have any concerns or technical questions all you have to do is email/call us and you get to talk to a live person with an answer almost immediately. Try that with KW. Our complete system which about the same price as the KW V3 includes camberplates, stress bar (sharper steering), and rear shock mounts. Don't get me wrong KW has decent products but they are a bigger that can flood the market with their product hence the reason why you see more activity about them. I found another link in regards to a STX client of mine that I still stay in touch with. http://www.ft86club.com/forums/showp...06&postcount=7 |
#20 | |
Thanks,
#21 |
#22 |
Drives: DS FRS
My advice is to get an Eibach Pro kit for a couple hundred bucks, get an alignment, 8" or 9" rims and 245/40/17 tires (235 is too short), and go have fun for a while. That setup will win most local STX events if you have the driving talent.
That gives you more time to assess the coilover options as they mature, whilst still having a competitive setup. Now, if you're planning on winning Nationals this year, go get some coilovers pronto. Edit : you'll need the Strano front bar as well. It will help tame the rear end. Last edited by blkwrxwag; 03-05-2013 at 06:37 PM. |
#23 |
Nationals, in my first RWD car ever. Lol.
#24 |
Drives: White 2013 FRS
I'd suggest doing some more research on the Tarmac II's. I've heard nothing but great things about them across platforms. They are a tad above your $1500 budget but not by that much.
| The Following User Says Thank You to OjiGeorge For This Useful Post: | Racecomp Engineering (03-05-2013) |
#25 |
Drives: DS FRS
| The Following User Says Thank You to blkwrxwag For This Useful Post: | whataboutbob (03-11-2013) |
#26 | |
For our RCE Tarmac 2's, we use 400/400 as the default rates, but allow customization firmer and softer depending on the user's needs. Most good suspension shops will allow you to customize your coilovers and make recommendations on what will work for you. Some will have different ideas of what works. I would stress again that using your budget completely on coilovers and then running stock bushings is not recommended. They really do make a solid difference. I would prefer a Koni + RCE Yellow spring set-up with some key bushings and maybe swaybars every time over 1500 in coilovers. Staging your build in phases is a common way to go and often a good idea depending on the user. - Andrew |
#27 | |
Drives: On track
#28 | |
http://scca.cdn.racersites.com/prod/...lo%20Rules.pdf "G. Strut bars per Section 12 are permitted with all types of suspension, subject to the following constraints: 1. a 2-point strut bar may be added, removed, modified, or substituted, but only with another 2-point strut bar. 2. A triangulated (3-point) strut bar may be removed, modified, or substituted; substitution may be with either a triangulated or a 2-point strut bar. The connection to the chassis (i.e., firewall, bulkhead, etc) must be in the standard location." Please correct me if I misread/misunderstood the above information. |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| What is your motivation? Why do you track/autox/etc.? What are your motorsport goals? | CSG Mike | Tracking / Autocross / HPDE / Drifting | 22 | 02-20-2013 09:18 PM |
| Autox competetive street tire vs. RA-1 (or similar) for track use | johhnc479 | Tracking / Autocross / HPDE / Drifting | 10 | 02-06-2013 02:49 AM |
| autox or autox school? | engee | Tracking / Autocross / HPDE / Drifting | 10 | 06-12-2012 06:31 PM |
