Old 03-05-2013, 03:15 AM   #1
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Stock FR-S Tune Just Done
As the title says, I brought my FR-S down to HG Motorsports in Sorrento Valley, CA this past Saturday to get a baseline dyno run and have the car tuned on all stock parts. The tuner is William or Bill Knowes, who happened to be lead tuner at Crawford for almost 8 years and personally tuned many of their famous cars such as those from Gymkhana 1 & 2.
Anyways, the dyno used was a very very old Dyno Dynamics, which according to Bill, is the heartbreaker of all heartbreakers.
I have all the dyno printouts, and will be posting them sometime tomorrow for all to see. For now, what I can tell you is that everything about the car is far better. Smoother in all gears, steady and stable idle, and last but not least, power. The average of 3 base pulls was 138.7whp at peak or so before the tune, and around 152.8whp peak after. At redline, I picked up 30whp. Instead of just dropping off at 5-5.5k like it did before, the car just keeps pulling and pulling.
I know, I know, this thread is useless without pics. Pics or it didn't happen. I will post all the dyno sheets tomorrow. Keep in mind that on a Dynojet, I'm guessing I would be around 175-180. Dynapacks read even higher.
PICS TUESDAY the 5th!
Zach3794 is offline   Reply With Quote
Old 03-05-2013, 03:16 AM   #2
Zach3794
^These are my car, before and after stock tune. Pink is before, green is after. All averages of 3 pulls.
^ These are my car after tune (green) versus a stock FR-S that belongs to someone else on these forums. This is significant because the FR-S represented with the grey curve was one of the first to hit U.S. shores and was clearly tuned a bit differently from the factory. The grey line is NO TUNE.
Aside - Yes I know it may say Flywheel HP, ignore it. It's WHP, and it's reading low because it's an older model Dyno Dynamics, as stated above. Deal with it.
The Following User Says Thank You to Zach3794 For This Useful Post:
suaveflooder (03-06-2013)
Old 03-05-2013, 03:50 AM   #3
Zach3794
Also, I apologize profusely for these being sideways, but I don't feel like putting in more effort so go ahead and snap your necks to read the graphs.
Old 03-05-2013, 08:07 AM   #4
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
All stock parts with a gain of 30whp? Really? Wow! What on earth was done to get results like that?
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 03-05-2013, 10:18 AM   #5
Zach3794
I'm not sure exactly, but of course when he was doing the pulls the graphs were made live and also had an AFR curve in there. I noticed that around the top where there was a 30whp gain, the AFR got so rich that is flatlined because the 02 sensor couldn't read any richer (before tune). I know he dialed it way back. I'll have to ask for a before an after for AFR too because the before looked like someone having a heart attack and after the curve looked stable and not too rich or lean.
Old 03-05-2013, 10:37 AM   #6
xjohnx
Grip>Slip
xjohnx's Avatar
What tuning solution did they use?
Yruyur (03-05-2013)
Old 03-05-2013, 10:53 AM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
Look at the baseline graph, it drops off way too early and quickly. The remap graph looks spot on but the massive gain is due to the original run being so poor.
Any idea what had been causing it to run so poor? Rubbish fuel maybe?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-05-2013, 10:53 AM   #8
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
I may have to give him a visit.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 03-05-2013, 11:25 AM   #9
jeebus
nice!
jeebus is offline   Reply With Quote
Old 03-05-2013, 11:36 AM   #10
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Fixed.
You're welcome
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following 6 Users Say Thank You to Kido1986 For This Useful Post:
Fast_Freddy (05-24-2013), Freeman (03-05-2013), shu5892001 (03-05-2013), SkullWorks (03-05-2013), swift996 (03-05-2013), tripjammer (03-21-2013)
Old 03-05-2013, 11:46 AM   #11
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
That's very impressive all stock gains. Perhaps you had a faulty sensor and its reading got tuned out? Otherwise why would this car be drowning itself in fuel up near redline? The O2 sensor should have been shouting shut the f***ing fuel off to the ECU lol
Either way that's stellar performance my man.
RandomHero is offline   Reply With Quote
The Following User Says Thank You to RandomHero For This Useful Post:
fenton (03-06-2013)
Old 03-05-2013, 12:18 PM   #12
Xdragonxb0i
Drives: ex500r
Looks good, a tune really unlock the potential, Theres probably some discrepancy in the first stock run, its really low. After a tune i expect our cars to be in the 160-175whp range depending on the fuel and aftermarket parts. 200whp for e85.
Xdragonxb0i is offline   Reply With Quote
Old 03-05-2013, 03:57 PM   #13
FrsSwag
Drives: Frs,civic
nice gains~!
FrsSwag is offline   Reply With Quote
Old 03-05-2013, 04:02 PM   #14
reeves
Originally Posted by Zach3794 View Post
..the AFR got so rich that is flatlined because the 02 sensor couldn't read any richer (before tune). I know he dialed it way back. I'll have to ask for a before an after for AFR too because the before looked like someone having a heart attack and after the curve looked stable and not too rich or lean.
be interested to see the before/after AFR too.
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Visconti vs FA20Club vs Stock Tune Dyno Results mechaghost Engine, Exhaust, Transmission 153 07-08-2013 11:35 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
Dynotronics and their E-Tune/ OTA tune. Ricepuddin User/Vendor/Sponsor Reviews, Feedback, Comments 5 12-24-2012 09:53 AM
