Old 03-04-2013, 01:52 PM   #1
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Lower Control Arms(CAMBER ARMS)- offset/angles comparision
So I am weak on my suspension basics:
if there is a thread you can direct me to that covers this, much appreciated, I'll delete this, PM Me
so...
how do I go and choose the right LCA? some are steel, some alum, some offset, some not, some look flimsy and are less money, some cost more, why buy them?
is aluminum a risk for r-compound use?
is having offset helpful, or not?
are some designs weaker from a failure angle?
is fatigue a concern with hollowed out alum? most oe alum isnt hollow looking at mini's and BMW porsches etc
I dont want to discount random posts, but there are guru's in this crowd, RCE, strano's etc type guys who I am looking for feedback from who can tell me why one is beneficial for someone with my needs
Money aside,
what matters as far as differences functionally between
http://deftmotion.com/stance-adjusta...ubaru-brz.html
and say
http://www.jhpusa.com/store/pc/viewP...62&idcategory=
or
http://www.frsport.com/GTSpec-Rear-L...Z_p_55869.html
or
http://ft86speedfactory.com/spc-rear...-pair-436.html
whats different there vs the above, etc?
using a lobed H&R bolt in the stock innermost factory location, I can get pretty close to symmetrical in the back, on an alignment rack, static rear camber close to -1.8L/2.0R with the stock LCAs, but I am dropped a bit over an inch front and rear(1.5) on GC race coilovers.
My shop didnt take a caster angle on the rear end, so I am clueless as to what if anything needs to be done.
Toe is fine in the back at present .005" each side
What do I need in a camber arm an why?
what else do I need to adjust?
Huehuecoyotl is offline   Reply With Quote
Old 03-04-2013, 01:56 PM   #2
NemeGuero
Good lord those SPC's are super skinny at the rod end. I'd dodge those.
NemeGuero is offline   Reply With Quote
Old 03-04-2013, 02:01 PM   #3
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
I have the SPCs.. They are a fine product.
tech4pdx is offline   Reply With Quote
The Following 2 Users Say Thank You to tech4pdx For This Useful Post:
ATL BRZ (03-04-2013), JoeBoxer (03-05-2013)
Old 03-04-2013, 03:51 PM   #4
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Stance, SPC, and Cusco are all great options. The Stance arms also give you the ability to go a bit lower if you want. SPC is great for those on a budget who need the camber correction.
FT-86 SpeedFactory is offline   Reply With Quote
Old 03-04-2013, 04:27 PM   #5
sw20kosh
Drives: 2013 Black FR-S
1. From reading the Stance description it seems the lowering is not adjustable? It just lowers the rear by 25mm. Is this correct? So with my RCE yellows I'd be at -25mm front, -50mm rear?
2. Does the lowering afforded by these arms negatively effect bump travel and geometry (ie. does it mess up handling like lowering springs that lower more than 1" on the stock dampers)
Old 03-04-2013, 04:31 PM   #6
NemeGuero
You raise the coilover to compensate. It adds more shock travel.
Old 03-04-2013, 04:52 PM   #7
FT-86 SpeedFactory
1. Correct, the lowering is not adjustable. These are designed to be used with coilovers to adjust the height so you will not have a wonky reverse rake.
2. No, these arms raise the hub mounting point to achieve the advertised lowering. This keeps the strut mounting position the same and therefore should not affect suspension travel.
Cheers!
-Yo
Old 03-04-2013, 04:54 PM   #8
Shit Luck
Drives: red frs
as he stated he does not have coilovers to raise....
Shit Luck is offline   Reply With Quote
Old 03-04-2013, 05:50 PM   #9
sw20kosh
-Yo
I am going to assume from this statement that I cannot use these arms with Stock shocks and RCE yellows.
Old 03-04-2013, 06:27 PM   #10
Calum
That Guy
Drives: 2013 asphalt FRS MT
oh, you could. It just wouldn't be a good idea.
The Following User Says Thank You to Calum For This Useful Post:
FT-86 SpeedFactory (03-04-2013)
Old 03-04-2013, 06:36 PM   #11
OrbitalEllipses
Drives: Attitude
Are you competing? Whiteline, Cusco, or similar milled aluminum arm. Not competing/on a budget? SPC arms.
Old 03-04-2013, 06:56 PM   #12
robispec
Drives: Black frs project
robi's arms are Front all the others are rear...
robispec is offline   Reply With Quote
Old 03-04-2013, 07:09 PM   #13
tech4pdx
Make love
tech4pdx's Avatar
I'm going to go ahead and call SPC and notify them that their arms are not worthy of competition. They might not know.
Old 03-04-2013, 07:12 PM   #14
NemeGuero
■■ Stance Lower Control Arms & Stance Coilovers ■■ FREE SHIPPING - Photos and Video. FT-86 SpeedFactory Brakes, Suspension, Chassis 338 09-30-2016 03:46 PM
Delete driver01 Brakes, Suspension, Chassis 11 02-06-2013 01:56 PM
cusco rear lower control arms for FR-S BRZ driver01 Canada Classifieds 3 02-01-2013 05:28 PM
Enjuku Racing - NRG/DME Rear Lower and Toe Arms ** New Product ** Enjuku Racing Brakes, Suspension, Chassis 0 10-17-2012 11:55 AM
