Old 01-30-2013, 09:36 AM   #71
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
Yes, my "sales"man told me after 5,000 miles. But when I took it into "service", I was told by the service advisor that it was every 7500 miles, but I could do my 7,500 mile service at anytime, or at 1,000 miles. I believe it is stated in the service schedule in the owners manual.
My middle age crisis started prematurely… at 16!
I'm also independently very, very..... dependent!
Kamran is offline   Reply With Quote
The Following User Says Thank You to Kamran For This Useful Post:
RallySport Direct (01-31-2013)
Old 01-31-2013, 12:58 AM   #72
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Very good info, thanks guys!
Rick
RallySport Direct is offline   Reply With Quote
Old 02-14-2013, 02:42 PM   #73
Mpowered
Drives: BR-Z
Originally Posted by Draco-REX View Post
I just installed a Fumoto Valve on my BRZ. I obviously haven't had a chance to use it, but I have used the valve on my other cars.
First off, the proper Fumoto valve is the 16mm version that the current Subaru Outback and '12+ Impreza uses. It comes in two versions, with or without a hose nipple. I recommend getting the one without.
I purchased the one with the nipple and the end of the nipple is flush with the skid plate. If I run over anything, I risk having the valve ripped out of the pan and running the engine dry. So at my next change I'll be switching back to the regular Fumoto that I've used on my other cars.
The Fumoto valves are great pieces. Unlike some other quick drain valves that just use a knurled plug within another plug, the Fumoto uses a true ball-valve. This gives two layers of sealing when closed. Additionally the lever for opening the valve is held in a positively locked position by an internal spring. An external spring clamp is available to add second layer of protection against vibration.
Using the valve is easy. You lift the lever out of it's seat and rotate it 90 degrees to open the valve. When done, just move the lever back and let it seat back into it's locked position.
I love the valve because it makes the draining process much faster and cleaner. When you pull out a drain plug your hand is momentarily in the way of the oil flow. And anyone who's changed a Subaru's oil will tell you that when you pull that plug, the oil comes out like a hose and even quick fingers will get splashed with oil. Using the valve, the smaller aperture slows the dpeed of the draining oil, and the level is on the side of the valve, letting you keep your hand out of the way and dry. And of course, no tools or loose drain plugs to deal with.
I highly recommend picking these up for your cars if you do your own changes. For the BRZ/FR-S get the F-108. There are valves for tons of vehicles available. But as this thread was started by a vendor, I won't post direct links.
Good tip. Saved for later.
Mpowered is offline   Reply With Quote
Old 02-25-2013, 09:44 AM   #74
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Originally Posted by RallySport Direct View Post
As per SOA FSM the torque spec on the filter is 10.3ft-lb, and 28.9 ft-lb for the drain plug
Kirill
RallySportDirect.com
what do you use to torque the oil filter? I have a torque wrench for wheel lug nuts but not sure if there's a way to use that to torque the oil filter. What kind of adapter do i need? if by hand, how do you know to torque to 10.3ft-lb?
chenshuo is offline   Reply With Quote
The Following User Says Thank You to chenshuo For This Useful Post:
RallySport Direct (02-26-2013)
Old 02-26-2013, 01:46 PM   #75
RallySport Direct
I always tighten the filters down by hand. I get them as tight as I can while still being able to remove them by hand 3K miles later. I have never used a torque wrench for the filter, although I suppose it would be ideal to use one. After more oil changes than I care to remember, I trust my hand torque method which I also call "Rick Spec"
Thanks,
Rick
Old 02-26-2013, 01:52 PM   #76
OrbitalEllipses
Drives: Attitude
Factory oil filter torque value: Gorilla spec.
The Following 3 Users Say Thank You to OrbitalEllipses For This Useful Post:
amram (03-25-2014), lupindub (09-06-2015), RallySport Direct (02-26-2013)
Old 02-26-2013, 05:07 PM   #77
RallySport Direct
HAHAHA this is awesome!
Old 03-02-2013, 10:08 PM   #78
MY13FRS
***** Super Senior Member
MY13FRS's Avatar
Drives: 13 FRS
Didn't see a post about removing the oil filter before draining the oil. Is it not the acceptable way to change the oil?
This is how I usually do my oil changes:
1. remove the oil fill cap
2. remove oil filter
3. pull up the dipstick about 1" inch
4. drain oil
I would imagine this removes the same amount of oil, no?
MY13FRS is offline   Reply With Quote
Old 03-04-2013, 06:42 PM   #79
RallySport Direct
4. drain oil
Yeah I think this method would work great. Having worked at a "quickie" oil changing place, I have always cracked the seal on the oil filter just as I was about to drain the oil from the pan. This technique usually works best on horizontally mounted filters, as it helps suck some of the oil out of the filters. But I think on this car either way would work.
Thanks,
Rick
Old 03-09-2013, 10:36 AM   #80
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Good stuff...thanks for the DIY
ecko04 is offline   Reply With Quote
The Following User Says Thank You to ecko04 For This Useful Post:
RallySport Direct (03-11-2013)
Old 03-12-2013, 10:00 PM   #81
runny_yolk
Drives: minivan
4. drain oil
Given that the filter is upside down and in the engine bay, wouldn't unscrewing the filter before draining the oil cause oil to leak? I accidentally spilled a tiny bit of oil on my exhaust manifold once, it stank for quite a while...
runny_yolk is offline   Reply With Quote
The Following User Says Thank You to runny_yolk For This Useful Post:
amram (03-25-2014)
Old 04-04-2013, 05:17 PM   #82
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Question for you: on the Fumoto Valve website, they listed that the part number for the BRZ is F-105 and for the FRS is F-103. I thought the drain hole size is the same? I drive a BRZ so should i get the F-105?
thanks
Old 04-04-2013, 05:45 PM   #83
Shinryu
Shinryu's Avatar
Drives: 2013 BRZ Limited
thanks
As stated in the post you quoted, you need the F-108 for either vehicle.
Shinryu is offline   Reply With Quote
Old 04-04-2013, 05:47 PM   #84
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
thanks
Their list is out of date. You want the valve for late model Subarus, the F-108.
Get the F-108 for just the valve, or the F-108S for a valve with a removable plastic nipple to attach a hose.
Oil Change Questions #87 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 06-28-2012 11:06 PM
Color Change Dark_Angle Mid-Atlantic 10 05-30-2012 02:00 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
I was able to change my pre-order. nkrein22 BRZ First-Gen (2012+) — General Topics 23 04-10-2012 04:16 PM
Can SOA change my preorder? Zaneman BRZ First-Gen (2012+) — General Topics 8 04-08-2012 02:06 PM
