Old 03-04-2013, 11:08 AM   #1
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Solo content: should STX Twin be setup like S2k, RX-8, MX-5?
Now that my car's suspension is on & ready to be set up, I'm wondering if we shouldn't try & emulate another car's setup that may be similar to our car, dynamically?
I've heard that the S2k may be a close match to our cars.
Since I've been in AWD mode since ~'05, I'm outta the loop for RWD.
Anyone have similar thoughts on copying what works?
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 03-04-2013, 11:19 AM   #2
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
The s2k does run a similar setup but there are so many variables it might be best to just get someone that is really good with suspension to take it for a spin and start getting advice from them.
Sent from my SGH-T989 using Tapatalk 2
Old 03-04-2013, 11:32 AM   #3
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
If you need second opinions on setups, I'll be glad to test pilot your beast
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 03-04-2013, 11:44 AM   #4
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Don't baseline a S2K, Miata, or RX-8, all use double a-arm style front suspensions. Geometry wise, we are at a disadvantage here on camber curve and keeping an optimal contact patch.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
The Following User Says Thank You to Sccabrz192 For This Useful Post:
Scooby South (03-04-2013)
Old 03-04-2013, 11:44 AM   #5
Racecomp Engineering
Completely different suspension designs....don't bother use those cars as a starting point.
EDIT: see above.
- Andrew
Old 03-04-2013, 11:49 AM   #6
ayau
Drives: Some rust bucket
Interesting subject. In terms of suspension, drivetrain, and chassis, what cars are similar to the twins?
Old 03-04-2013, 12:09 PM   #7
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
BMWs kinda...
GTM_Challenge is offline   Reply With Quote
Old 03-04-2013, 12:11 PM   #8
GTB/ZR-1
GTB/ZR-1's Avatar
Yeah, in uncharted territory on this car with this car, so I guess it'll be a work in progress trying to figure out what works on these cars as far as camber/toe/caster/rake etc. Thought I'd post this up as I'm sure many are trying to get a handle on things as we go into the season.
So when someone figures it out--pls share all of your 'proprietary' info w/ us--we sure you won't mind. lol
And Henry, strangely a lot of people share your sentiment & enthusiasm abt driving the car. lol
Old 03-04-2013, 12:14 PM   #9
ayau
Originally Posted by GTM_Challenge View Post
BMWs
Probably wouldn't be able to fit double wishbone with a boxer engine. This beg the question, would people prefer double wish and an inline 4 over boxer and strut?
Old 03-04-2013, 12:16 PM   #10
ayau
If there's any setup you should replicate, I'd say @robispec and @CSG Mike.
The Following User Says Thank You to ayau For This Useful Post:
SubieNate (03-05-2013)
Old 03-04-2013, 12:22 PM   #11
GTM_Challenge
Drives: On track
I thought BMWs had struts?
Old 03-04-2013, 01:00 PM   #12
xwd
BMWs and 911s both have struts in the front, albeit not a traditional design. There is probably room to design a front wishbone suspension but it would have required a lot of work. Most of what's on the BRZ is adapted from the Impreza and likely required a lot less R&D than designing something from scratch.
As for the car setup, I've heard from one national champ autocrosser who feels the car is close enough to his S2000 he'll use the settings off of it as a starting point.
Old 03-04-2013, 01:29 PM   #13
CSG Mike
CSG Mike's Avatar
We're set up for track duty, not cone dodging, so I wouldn't necessarily recommend following our setups. Additionally, it may kick you out of your desired class....
I've AutoX'd exactly once, and drove a few STR cars that were offered to me. These are my observations based on the STR cars i drove; my CR falls into STR as well. They kindly turned a blind eye to my pulled fenders, as they were of no performance benefit with the stern warning that if I were at a national championship, I'd be DQ'd for it.
- AutoX cars value ultra fast response and weight transfer
- That response and transfer typically comes at the cost of understeering during steady state cornering
- Because of that understeer, they believe in the slow-in fast-out approach, with a hard rotation after the slow-in
I noticed that a STR s2000 was slaloming nearly 7-8 mph faster than I was in my CR with stock suspension, but I could easily hold an advantage through sweepers using throttle steering. Unfortunately, due to the nature of AutoX courses, sacrificing a few sweepers for the tons of quick transitions makes the properly set up STR cars faster.
I was also chastised for my driving style (loose rear, but not sliding)... but still took 2nd fastest novice of the day; I lost to a guy who was ending his first season and was a novice by technicality. He was in a fully prepped car. Grr.
whataboutbob (03-05-2013)
Old 03-04-2013, 02:04 PM   #14
ayau
My bad. For some reason, I was thinking about a track setup when reading this thread.
Hello 818, bye BRZ? Kit car content. chulooz Other Vehicles & General Automotive Discussions 38 01-13-2013 10:07 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
More weight savings (wheel content) GTB/ZR-1 Tracking / Autocross / HPDE / Drifting 5 11-12-2012 10:03 AM
How's this for weight savings? (battery content) GTB/ZR-1 Tracking / Autocross / HPDE / Drifting 11 11-05-2012 10:27 PM
