Old 03-03-2013, 06:21 PM   #1807
Visconti
Drives: 05 STi
Originally Posted by kenward View Post
Please define "very" for us.
I can't comment on the numbers
but i think the curve looks more like this
Visconti is offline
The Following 8 Users Say Thank You to Visconti For This Useful Post:
Calum (03-03-2013), Chewie4299 (03-03-2013), civicdrivr (03-03-2013), kenward (03-03-2013), mxsled (03-03-2013), Sonolin (03-03-2013), Starscream15 (03-03-2013), zigzagz94 (03-03-2013)
Old 03-03-2013, 06:25 PM   #1808
cmss2000
Drives: 2013 BRZ Premium 2012 Acura TSX
That can't be right....it's not "Digitized"!
Can you comment on whether this looks closer to stage 1 than stage 2?
cmss2000 is offline
Old 03-03-2013, 06:26 PM   #1809
Visconti
Drives: 05 STi
Nope.. but trq is pretty flat
Visconti is offline
Old 03-03-2013, 06:46 PM   #1810
nonicname
Drives: it has 4 wheels and a motor
this is something you CAN answer...
when will you be allowed to release a dyno chart?
nonicname is offline
Old 03-03-2013, 06:48 PM   #1811
XPR Small Block
Drives: Scion Frs
i would say that would be stage 1 tune do to the fact that this sc on a 2 liter motor at 8000 rpm at 10 psi "should" make 265 hp atleast thats what i got from sprintex. i need to know the diameter of the stock pulley to figure out what sc pulley it needs to make the 10 psi
XPR Small Block is offline
Old 03-03-2013, 06:59 PM   #1812
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Very interesting to see all the guesses coming along. I wonder how many will be satisfied/disappointed when numbers are released? I think whomever's guess is down on earth with the numbers will be ok. There are some people posting sky high numbers that won't be met.
Sportsguy83 is offline
Old 03-03-2013, 07:07 PM   #1813
XPR Small Block
Drives: Scion Frs
yea im just going off of what sprintex is saying.. yea i think 265 is good chunk of power specially on a stock block.. but myself will be squeezing every hp i can out of this set up. i know sc can be just as good as any turbo out there you just have to know how to build an modify the blower to make more boost, i have a whipple sc on a ford 302 making 35 psi putting 550hp to the ground on pump gas!! this car could easily make 350+ ph if there was some forged internals and lower cp ratios
Old 03-03-2013, 07:15 PM   #1814
djliquidsteele
Drives: Scion FR-S
I'm guessing March 15th is going to be the date we will know all.
djliquidsteele is offline
Old 03-03-2013, 07:18 PM   #1815
XPR Small Block
Drives: Scion Frs
this is what i was basing my numbers off of
[/IMG]
The Following User Says Thank You to XPR Small Block For This Useful Post:
Calum (03-03-2013)
Old 03-03-2013, 07:24 PM   #1816
Carwhisperer
Drives: A lot of supercars.
If its pretty flat, i dont expect it to make over 190trq then. Realistically around 170-180 wouldn't surprise and disappoint me at all on pump gas.
Carwhisperer is offline
The Following User Says Thank You to Carwhisperer For This Useful Post:
Sportsguy83 (03-03-2013)
Old 03-03-2013, 07:43 PM   #1817
Sonolin
170-180 on pump would be awesome if its as flat as Visconti is posting!
Sonolin is offline
Old 03-03-2013, 07:54 PM   #1818
Carwhisperer
Yeah if it can hit 170ft/lb at 3-3.5k then this will be exactly what im looking for.
Also...If i keep up(running e85) with my buddies stock 11' Wrx then with this kit, i can see our cars keeping up with a Sti. There are advantages to power/weight ratio.
Old 03-03-2013, 07:56 PM   #1819
Visconti
Drives: 05 STi
The newer Wrx is faster then the sti..
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
Carwhisperer (03-03-2013)
Old 03-03-2013, 07:57 PM   #1820
cruzinbill
Drives: Argento 6spd FR-S
Bahaha let the fist pumping continue.
My question is will it be possible to get ur tune with the kit instead of the silly base tune?
cruzinbill is offline
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 02:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 09:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 05:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 06:10 AM
