Old 03-02-2013, 01:28 AM   #1
Techfl3x
Techfl3x's Avatar
Drives: Firestorm Red FRS/86 MT
DIY Beat-Sonic Backup Cam Install (FRS)
Installed the Beat-Sonic backup cam last weekend. Really happy with the product and support provided by the Beat-Sonic crew (Thanks Eric). Here's quick DIY for the install for the FRS.
*Getting the pics up first. Stay tuned for the narration & full DIY.*
Equipment:
Beat-Sonic BCAM7W Backup Camera
Beat-Sonic BCUS2 Backup Camera Adapter
References:
Beat-Sonic FRS DIY
Cam User Guide
Adapter User Guide
Passenger Door Sills
Trunk Grounding
Trunk Cover
License Plate Cam View
Reverse Test. It works!
Techfl3x is offline   Reply With Quote
The Following 5 Users Say Thank You to Techfl3x For This Useful Post:
Beat-Sonic (03-04-2013), FlyLow (12-01-2013), JonnyRocket (03-08-2013), normancw (03-02-2013), sinigang_guy (03-02-2013)
Old 03-02-2013, 01:33 AM   #2
WillBRZ
WillBRZ's Avatar
Drives: 2013 BRZ Limited 6MT GBS
exactly what ive been waiting for! was it plug and play? cant tell from pics
2014 infiniti Q50 Daily 1996 Mazda Miata Racecar
SOLD -> Galaxy Blue Silica Subaru BRZ Limited 6MT
SOLD -> 2003.5 Infiniti G35 Sedan Emerald Mist
WillBRZ is offline   Reply With Quote
Old 03-02-2013, 01:21 PM   #3
Techfl3x
Techfl3x's Avatar
Thx. It wasn't exactly plug and play since you have to tap 2 wires for the cam to activate when you switch gears to reverse. I should also add that additional copper wiring is needed to extend the wires provided by Beat-Sonic. Pretty cheap at any auto parts store and simple to extend with basic wire snippers. Once the wires have been run from the trunk to head unit, you should almost be home free.
Old 03-02-2013, 01:24 PM   #4
Techfl3x
Techfl3x's Avatar
Originally Posted by normancw View Post
Excellent DIY. One day too late for me, lol, I installed mine yesterday. I would have saved some (actually, probably a LOT of) time with this!
I agree - it's a great product.
Thx! Still incomplete but I figured some pics are better than no pics
I'm still waiting for my TRD license plate frame to arrive so I haven't finished tucking all the wires from the trunk, and fishing it through the car's rubber tubing. Have you done that? Any tips on how to do it easily?
Old 03-02-2013, 02:41 PM   #5
Dboe
Drives: 2013 Red FRS
Looks great. Its too bad I didnt get a BeSpoke.
Dboe is offline   Reply With Quote
The Following User Says Thank You to Dboe For This Useful Post:
Techfl3x (06-12-2013)
Old 03-02-2013, 07:06 PM   #6
DookDookDGM
BR-Zizzle
DookDookDGM's Avatar
Drives: 2013 BR-Z, 1985 AE86, 1986 AE86
Send a message via AIM to DookDookDGM
Will this work with the BRZ head unit?
A little addiction goes a long way...
2013 Dark Grey Metallic Subaru BRZ
1986 Toyota Corolla GT-SR5
1985 Toyota Corolla SR5
DookDookDGM is offline   Reply With Quote
Old 03-02-2013, 07:09 PM   #7
RWD-boxer
RWD-boxer's Avatar
Drives: Black
Can u update what camera and install kit we need (link not working)
Thenittis.com
RWD-boxer is offline   Reply With Quote
Old 03-02-2013, 08:53 PM   #8
zooki
Drives: waiting on a 2021...
I just installed mine today. The easiest way I found to get the wires through the trunk grommets was to unplug the wiring connector and pull the grommet loose from both the trunk and the body. That way you can straighten it out and push a straightened coat hanger through. Tape the camera wire to the coat hanger, and pull it back through the grommet, and untape. Simple.
zooki is offline   Reply With Quote
The Following 2 Users Say Thank You to zooki For This Useful Post:
normancw (03-03-2013), Techfl3x (03-03-2013)
Old 03-03-2013, 01:02 AM   #9
Techfl3x
Techfl3x's Avatar
Yep it works with the BRZ headunit. It's listed in their compatibility list also: http://www.ft86club.com/forums/showt...ght=Beat+sonic
Old 03-03-2013, 01:04 AM   #10
Techfl3x
Techfl3x's Avatar
I didn't try fishing it through - I just routed in the trunk panel and out the hole that is about 6 inches away from the rubber tube (on the drivers side). It doesn't look that good, but I'll leave it for now. My rear trunk opener stopped working (before the install) - I don't want the dealer to think I broke it while installing the camera.
Ah good call. Better to wait til after u get the trunk issue resolved by the dealer first.
Old 03-03-2013, 01:05 AM   #11
Techfl3x
Techfl3x's Avatar
Thenittis.com
Oops sorry. Link fixed!
Old 03-18-2013, 01:30 PM   #12
KitoBRZ
What hardware is required for this install? Thanks.
KitoBRZ is offline   Reply With Quote
Old 03-19-2013, 10:54 PM   #13
Techfl3x
Techfl3x's Avatar
You'll need:
- 10mm socket, socket wrench, extension
- Very small flat head screw driver (the ones used to disassemble glasses)
- Extra stereo wires (up to 7.5ft)
- 1 x Ring Terminal for wire ground
- Electric Tape
- 1 x Male 14-16 Gauge Bullet Connector
- Panel Removal Tool (or anything that can pry open the headunit (something thin and non abrasive) I used a plastic wax comb for surfboards.)
Old 07-07-2013, 08:25 AM   #14
jdm-az-fuk
Drives: 2013 Fr-S
Great write up.
jdm-az-fuk is offline   Reply With Quote
The Following User Says Thank You to jdm-az-fuk For This Useful Post:
Techfl3x (07-17-2013)
backup, beatsonic, cam, install, reverse
Beat-Sonic FR-S Photos Beat-Sonic FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 46 08-29-2013 10:35 AM
Beat Sonic Shark Fin Antenna | FR-S, 86, BRZ xravexboix Exterior Parts - The Rest 29 08-01-2013 07:42 PM
Beat-Sonic Backup Camera & Adapter for FR-S (Bespoke) & BRZ Special Price Beat-Sonic Audio/Visual, Electronics, Infotainment, NAV 60 07-15-2013 03:58 PM
Beat-sonic JDM shark fin antenna install. jadewbj Cosmetic Modification (Interior/Exterior/Lighting) 23 05-23-2013 01:12 AM
