#211 |
Drives: 2013 86 white
The clip really show how it work. During low rpm speed or low pressure, the smog exit more at the first left outlet pipe. At higher rpm w/ higher pressure flow the smog is pushed straight to exit at the right outlet pipe tip. So basically it work fine but the smog flow will never be balance at both outlet pipes
| The Following User Says Thank You to TRD_86 For This Useful Post: | 86_ZN6 (02-26-2013) |
#212 | |
Drives: 86 ZN6
when we fixed the height issue of the tips, the depth got misaligned you can try to further adjust it. but if you still cant, you can bring the car to the shop and we'll adjust it for you |
#213 |
I Love custom Turbo kits
Drives: Limited BRZ
#215 |
Drives: 2008 EVO X
Get videos. I love that you are in the Bay area. (i'm in Sac). So I'll definitely PM you guys when i'm ready.
#216 |
Drives: DGM BRZ
Hm... I just installed mine last week... my right side hangs much lower than my left. I'm only using one of the hangers on the left side as well... with both hangers on, the left is even higher up and noticeably more uneven.
Could I bring it into the Works shop and see if they'll adjust it? I live in San Ramon and can drive it to wherever. ![]() Other than this small issue... I love the AB-M. Car sounds so much more aggressive but not overbearing. Like others said... when you're just cruising you don't really notice it... but when you get on the gas you can hear the growl. Also love the way these look... car just looks so much better. This is with no hangers attached on left so it sits a lot more even... just don't know how safe that is!
#217 |
Drives: 86 ZN6
#218 |
Any sales coming up soon? hehe
ScionFrsFan
#219 |
Drives: 86 ZN6
#220 |
ScionFrsFan
#221 |
Hello,
Maybe I read it wrong lol but I thought you posted on the works drop in thread that you would toss one in with a order of the ab-m? Or am I crazy? ...on a side note I tried to PM you but your mailbox is full lol
ScionFrsFan
| The Following User Says Thank You to ScionFrsFan For This Useful Post: | AllDayJonRay (03-04-2013) |
#222 |
Drives: WRD BRZ Limited
The amount of vapor leaving each tip is really asymmetrical, which I guess isn't very surprising considering the design. I'm not saying it's a good or bad thing for performance, but I would like to avoid the dummy-dual look where you have an exhaust tip that doesn't appear to be doing anything.
| JDL Header & Exhaust System Development | JDLAutoDesign | Engine, Exhaust, Transmission | 1650 | 01-17-2014 12:00 PM |
| AIRAID FR-S / BRZ Cold Air Intake system Sneak Peak / Development Information | AIRAID | Engine, Exhaust, Transmission | 396 | 10-04-2012 07:27 AM |
| subaru brz navigation system wire diagram? watching movies usb works !! | SgtBolt | Audio/Visual, Electronics, Infotainment, NAV | 3 | 06-21-2012 11:31 PM |
| Essex/AP Racing Competition Brake System in Development | JRitt | Brakes, Suspension, Chassis | 1 | 06-14-2012 01:32 PM |
