Old 02-28-2013, 11:31 PM   #1
Red John
and True Blue
Drives: Red 2013 BRZ Limited MT--sold 8/9
Ignorance and a dead battery
I got up this morning and needed to get something out of my BRZ, first thing I noticed is that the window didn't bump down when I opened the door.
The rest was not so subtle, no electricity at all, battery so stone dead it wouldn't light the dome lamp...............
I retraced my steps to the last time I was in the car, I had turned it on Accessory with my Push To Start button and was exploring the touch screen functions.
When I was done futzing around, I got out of the car and it occurred to me as I walked away that I had not turned the car to "Off" from "Accessory", but having read about the battery saver function in the Owner's Manual, I wasn't concerned, "It'll turn itself off when the key gets out of range" says me to myself.
All very good unless you park next to your gun safe...........where you keep your extra keys.....and the spare fob that operates your car.
The car saw the spare key fob and thought I was still in the car, so It stayed on Accessory until the battery was completely drained.
I took the battery out of the spare fob and got a free jump start out of my free Subaru Road Service, after checking with the Dealer's service department whether the fob was an active (needs battery) or passive system (transponder)
Has anyone else done this?
Red John is offline   Reply With Quote
The Following User Says Thank You to Red John For This Useful Post:
ftc~brz (03-01-2013)
Old 03-01-2013, 12:06 AM   #2
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
LOL. You've sure left yourself open to some ribbing from guys that start their cars with the turn of a key.
whaap is offline   Reply With Quote
The Following 2 Users Say Thank You to whaap For This Useful Post:
LeeMaster (03-01-2013), strat61caster (03-01-2013)
Old 03-01-2013, 12:58 AM   #3
fistpoint
Drives: Supercharged Golf Cart
You keep you gun safe outside?
fistpoint is offline   Reply With Quote
The Following 2 Users Say Thank You to fistpoint For This Useful Post:
ftc~brz (03-01-2013), Sportsguy83 (03-01-2013)
Old 03-01-2013, 06:23 PM   #4
RoryTate
Drives: 2013 Subaru BRZ
Manual trans FTW in this case. The car isn't that heavy to push yourself.
Hrmm. I wonder if it would be possible at all with the transponder...
RoryTate is offline   Reply With Quote
Old 03-01-2013, 08:02 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I'm curious about this too... although with a dead battery no fuel will be delivered and IF there is any spark it'd be pretty weak... Although I'm not well versed in modern cars with newfangled computers so I could be wrong.
Who's willing to drain their battery and guinea pig this?
ineedyourdiddly
eckoflyte (06-13-2013)
Old 03-02-2013, 11:21 AM   #6
Red John
and True Blue
Update
I wasn't entirely correct in my diagnosis.
It turns out that the "interior lights on approach" (customizable default setting is "ON") is what killed the battery, I did not in fact leave the Ignition in "accessory" as I thought I did.
Therefore;
You guys who use a key are not immune.....(?)
This car doesn't use the transponder approach, but I bet if it did, the only option would be to keep the spare key out of range.
Old 03-02-2013, 11:26 AM   #7
Red John
and True Blue
yikes!
[ame="http://www.youtube.com/watch?v=5XZMC1M9o04"]The Mr. Obvious Show - The Critter - YouTube[/ame]
Old 03-02-2013, 12:46 PM   #8
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
Originally Posted by Red John View Post
Update
Therefore;
I think regardless of whether the smart key is in range of the car, the Accessory mode will turn off on it's own. I've washed my car with the radio on, and it pretty reliably turns off after an hour.
I would hope this also applies to anyone who leaves a key turned to Acc.
NRGBalanced is offline   Reply With Quote
Old 03-02-2013, 12:57 PM   #9
Red John
and True Blue
I re-read the Owner's Manual about the automatic turn off feature. It says that even when deactivated from the Accessory Mode battery depletion will occur. So it looks like counting on this feature isn't a good idea anyway.
Best practice is to change/turn Ignition Button/Switch to "Off" before leaving the vehicle unattended............and (original post subject) any remote access keys either out of range or battery removed from them.
even so, key switch in ACC would mean leaving the key in the car, since it can't be removed in that position.
Old 03-02-2013, 02:29 PM   #10
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Manual transmission. Hmmm, I wonder if would have been possible to push start it. Any hills nearby?
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
The Following User Says Thank You to Black Tire For This Useful Post:
chulooz (03-02-2013)
The Walking Dead DIM Off-Topic Lounge [WARNING: NO POLITICS] 286 11-03-2014 12:19 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
Argument from Ignorance. Asterisked Accolade Off-Topic Lounge [WARNING: NO POLITICS] 10 07-06-2012 07:14 PM
g35 brought from the dead bryansbestwax Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-26-2012 12:22 AM
Dead pedal height bqe-lie-fdr Scion FR-S / Toyota 86 GT86 General Forum 0 02-25-2012 09:21 AM
