Old 03-01-2013, 06:24 PM   #127
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Originally Posted by ButtonPuncher View Post
Those that are worried about the 12.5:1 CR shouldn't be. That what the stock Ford Contour SVT 2.5L Duratec was running. They boosted them to 350HP on stock internals and were only 220HP stock. Having it fully intercooled will make it very safe.
I just can image how insane that thing would look fully polished.
It's awesome that they chose the TVS series. They are really efficient and have a big power range. For instance, the TVS900 has a max flow of 1000m^3/hr or about 406HP. It's a bit on the small side but it's still be perfect because that's almost exactly what our cars would make on 14.7psi of boost.
I doubt it, but if they went with the TVS1320, then we'd see a max flow of 1400m^3/hr which equals a max of 568HP. That'd be nuckin' futz. We'd have to have forged everything and a 8.5:1 CR because that much flow would mean we'd be at 29psi of boost.
BP
depending on the pulley of course! a 1320 at 11 psi should be good for about 330-350whp if using a lotus elise 1.8L at 11.1 compression is a decent example. i could see our car putting down around the same with a much lower Redline (1000 less) and probably 10 psi (1320's peak efficiency). 29 psi and you are making way too much heat. and imo this engine will never need to be dropped below 10.5:1 or even 11:1 compression for boost. no sense in losing throttle response.
FreshFRS is offline   Reply With Quote
Old 03-01-2013, 06:38 PM   #128
tjoy
This is a super built for a specific race car if I understand correctly.
The released TRD super for the FJ Cruiser looked like this:
Notice the fit and finish, it was also a 45 minute install. That's what Toyota does.
tjoy is offline   Reply With Quote
Old 03-01-2013, 07:10 PM   #129
brocktwalker
Drives: Scion FR-S Black
I hope that is what toyota does again and I hope that it produces good numbers too!
brocktwalker is offline   Reply With Quote
Old 03-01-2013, 11:54 PM   #130
jflogerzi
jflogerzi's Avatar
you can't have both.
Old 03-02-2013, 05:47 AM   #131
brocktwalker
I have a feeling it won't be worth the money
The Following 2 Users Say Thank You to brocktwalker For This Useful Post:
Alhammadi (03-02-2013), Murseman27 (03-02-2013)
Old 03-02-2013, 10:28 PM   #132
serith
serith's Avatar
Drives: 2009 Scion tC RS 5.0
The TRD supercharger for the 1st gen tC's yielded a measly ~40hp increase, if memory serves me--and they wanted thousands for it.
09 RS 5.0 -- #862 of 2000 -- 5spd
serith is offline   Reply With Quote
Old 03-02-2013, 10:31 PM   #133
stilletto
Drives: 2008 Mitsubishi Eclipse GS
..was also discontinued since it was an EPIC FAIL.
stilletto is offline   Reply With Quote
Old 03-03-2013, 07:38 PM   #134
brocktwalker
Ya I know about the tc super charger and that is why I don't have much faith the frs one will be worth a damn.
Old 03-03-2013, 11:08 PM   #135
whtchocla7e
Drives: 2013 FR-S Hot Lava
Big difference between the TC and the FR-S though.. two different markets, two different sets of expectations. I doubt Toyota would release anything for the FR-S that doesn't live up to the standards of a sports car.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 03-05-2013, 01:37 PM   #136
ButtonPuncher
Drives: '06 V6 Mazda 6s
Yeah, it's all about flow. That 1320 would be nuts. You'd have instant boost right off idle.
With those dual intercooler cores, they are planning for big power with future upgrades. I could still see them only have 60-80HP gain in a stock setup just because they have to keep the warranty. But even with the .9L TVS, you've got enough flow for 400HP at the crank. Tons of room for growth for the tuners.
2006 Mazda 6s - 3.0L 6-speed
Saving up for a shiny blue BRZ.
ButtonPuncher is offline   Reply With Quote
Old 03-05-2013, 02:03 PM   #137
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
As excited as you all are I have heard from a vary reliable source at scion that there will be no super charger I repeat no super charger. At least as a dio ( dealer installed option)
Living life one HPDE at a time
Touge Monster is offline   Reply With Quote
Old 03-05-2013, 02:15 PM   #138
Dezoris
Dezoris's Avatar
Looks too fast. Needs to be powder coated pink for me to consider it.
Old 03-05-2013, 02:47 PM   #139
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
thats very pretty much it. though idle - 2000rpm efficiency would be absolutely terrible. the R900:.9L can flow 400hp but is not efficient in doing it. again no more than 10ish psi is going to run peak efficiency and that could feasibly be around 250whp.
Old 03-05-2013, 02:52 PM   #140
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
husker741 is offline   Reply With Quote
Mod Update.... UM FRS CANADA 12 12-25-2012 01:50 PM
Update on alarm ? Dkittrell Electronics | Audio | NAV | Infotainment 4 06-26-2012 02:48 PM
86 Pricing Update newft86 AUSTRALIA 3 06-12-2012 11:52 PM
HQTScion Rep Update on FR-S HQTSCION REP Southeast 0 06-06-2012 11:18 AM
GT5 2.0 Update!... MF_DEUCE Off-Topic Lounge [WARNING: NO POLITICS] 11 10-15-2011 02:53 PM
