Old 03-01-2013, 01:14 AM   #239
Auto-Hauss
Auto-Hauss's Avatar
Drives: 2013 Scion FR-S-Asphalt
Sorry if this has been asked before but is the Whiteline diff cradle bushings allowed in STX?
Auto-Hauss is offline   Reply With Quote
Old 03-01-2013, 01:25 AM   #240
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
I think whataboutbob uses one in his stx build...
enjoyminutemaid is offline   Reply With Quote
The Following User Says Thank You to enjoyminutemaid For This Useful Post:
Auto-Hauss (03-01-2013)
Old 03-01-2013, 01:35 AM   #241
whataboutbob
AutoX-10/10ths every run
I've got it on order, but it hasn't shown yet.
@Auto-Hauss
http://www.scca.com/assets/2013%20Solo%20Rules.pdf
14.8.D - "Differential mount bushings may be replaced but must attach in the
factory location(s) without additional modification or changes. Dif-
ferential position may not be changed. The amount of metal in a
replacement bushing may not be increased relative to the amount of
metal found in a standard bushing for the particular application. Solid
metal bushings are specifically prohibited."
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Old 03-01-2013, 09:33 AM   #242
Auto-Hauss
Auto-Hauss's Avatar
@Auto-Hauss
My comprehension of the rule would make these illegal. The metal in the bushing increases and you can potentially change the mount point depending on which slot you use.
Old 03-01-2013, 10:47 AM   #243
whataboutbob
Maybe. I haven't had a set to compare to the factory ones to see if there is a difference in the amount of metal. I'd say that although they offer an adjustment in the mounting location, if you keep the diff in the same place as the factory ones you aren't in violation.
The other Whiteline bushings I've put on the front LCA and steering rack didn't increase the amount of metal and that's why I am hesitant to say/agree that these will as well. I suspect that Whiteline is aware of the rules in SCCA as well and probably wants to provide upgrades that are legal to get sales.
:happy0180:
Build thread:Here
Old 03-01-2013, 11:58 AM   #244
Auto-Hauss
Auto-Hauss's Avatar
Oh yeah I'm sure they want the autoX sales. I believe this is why they are the only company making RCA with bushings instead of ball joints. Its just a risk right now to install them without knowing if they are illegal. I don't want to buy another set of stock bushings. IMO it should be ruled as adding more metal. The stock bushing is nothing but rubber except the outside ring. But we'll see.
Cheers aswell!
:happy0180:
The Following User Says Thank You to Auto-Hauss For This Useful Post:
whataboutbob (03-01-2013)
Old 03-01-2013, 12:19 PM   #245
whataboutbob
Cheers aswell!
:happy0180:
Agreed. I'm not sure the stock one is only metal on the outside ring only as the other bushings I've replaced had a metal cylinder/sleeve where the mounting bolts went through.
Build thread:Here
Old 03-01-2013, 12:36 PM   #246
Auto-Hauss
Auto-Hauss's Avatar
They do have a sleeve. I guess one could argue in favor of the Whiteline bushings to be legal based on that. Please post up a picture when you get them. The high res picture of them might over state how big the metal puck is on the inside of the bushing.
Also when you installed the subframe collars, did the subframe shift down(away from the car body) 5mm after everything was tightened?
Old 03-07-2013, 11:33 AM   #247
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Okay, ran into an issue with rear camber--which, evidently, is not adjustable...
LR 1.79
RR 2.55 (!)
Any one else having this issue?
What LC arms do I need (it seems)?
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 03-07-2013, 11:39 AM   #248
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
I went with the SPC lca. Does the job well, and it's affordable!
Here's a pic installed.
RiskyTrousers is offline   Reply With Quote
The Following User Says Thank You to RiskyTrousers For This Useful Post:
EN2_Squirrel (03-07-2013)
Old 03-07-2013, 11:56 AM   #249
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
I will be going with Whitelines... But for now.. I adjusted it with Ride height..
Bill
Scooby South is offline   Reply With Quote
Old 03-07-2013, 12:15 PM   #250
GTB/ZR-1
GTB/ZR-1's Avatar
Bill
Well, considering this was after corner bal/alignment--that would throw that out the window. Lol. I'm really scratching my head trying to figure out why such a disparity when ride height is very close. Bought car brand new & it's never been damaged. Strange & frustrating!
Old 03-07-2013, 12:42 PM   #251
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
At stock height mine is symmetrical (-1.7) but when lowered to corner balance I was off by .3.
TomR
ABQautoxer is offline   Reply With Quote
Old 03-08-2013, 10:24 AM   #252
GTB/ZR-1
GTB/ZR-1's Avatar
So, if I don't get LC arms by event, should I chuck corner weight in favor of even rear camber?
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
